The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
Replacing bulbs
(History)
Replacing bulbs
See 2004 Prius Light Upgrades for ideas from Tom Stangl's FAQ
License Plate bulb tips
- Check your manual on steps and search YouTube for example videos, if needed
- Use molding and trim removal tools, and be gentle removing the hatch cover.
- Remember to unplug the power connector, it's so much easier
- If bulb housing won't turn, use pliers but be gentle
- Add some lube to the bulb housing and trim clips before reassembly
XenCarta
