What every newb should know
Discussion in 'Newbie Forum' started by richard schumacher, Jun 8, 2008.
  1. JLX
    JLX Junior Member
    2018 Prius
    46 pages (and counting) of really helpful information - thanks to all of the contributors! You've already saved me from several embarrasing and potentially expensive rookie mistakes.
  2. JLX
    JLX Junior Member
    2018 Prius
    And thanks to the knowledge shared by this community, my 2018 Prius Four now has a full size spare! South Florida roads definitely seem less threatening now.
    jerrymildred likes this.
  3. Joseph Nguyen
    Joseph Nguyen New Member
    Tulsa, OK
    thanks toa ll the OGs, ive learned some realy good info. im about to pick up my first prius real soon.
    JLX and mikey_t like this.
  4. UggaDugga
    UggaDugga Junior Member
    Stoughton, WI
    Great stuff! Thanks!
    And yeah, I was curious how far the electric battery alone could carry me if I ran out of gas when I first bought my 2010 prius years ago. The answer as I learned it was, not far :LOL: only a few blocks I think. I had just bought a pint of frozen custard too... thankfully no damage to the car that I'm aware of so that was my greatest loss LOL
    vvillovv likes this.
  5. Swiick
    Swiick New Member
    NorCal
    Good knowledge!
  6. Beach Dweller
    Beach Dweller Junior Member
    38
    26
    The Beach
    2024 Prius Prime
    XSE Premium
    Whooeee! Do I have a LOT to learn about these EVs!
    And to think I was thinking of jumping straight into a Lucid Sapphire!
  7. PrimeCT2020
    PrimeCT2020 New Member
    Conception
    2020 Prius Prime
    On my Prime 2020, I can't get charging connector to insert fully into charging inlet; and no lock pin is visible.
  8. jerrymildred
    jerrymildred Senior Member
    11,491
    14,104
    Tampa, FL
    Welcome. IIRC, the PiP had an o-ring in the charging handle that sometimes got in the way. It was not needed anyway, so people just threw it away. Might it be that your charging handle has a similar o-ring? Another possibility is a damaged connector pin.
  9. Danimal_562
    Danimal_562 Junior Member
    Thank you for the info. Glad to be here.
  10. vvillovv
    vvillovv Senior Member
    3,536
    1,249
    NY
    After posting 4 times and having the forum Moderator check those posts, basically, a new member will be given normal posting status.
    The present workaround way to post images is to disable javascript within the browser one is using.
    Many / All priuschat user still are not fully understading why this extra step is necessary when comparing to the ease of posting images before the 2023 server migration of this forum.
    see other post:
    November 2023 Server Migration Notes | Page 8 | PriusChat
  11. Danimal_562
    Thanks for the info.
  12. Berserk DIYer
    Berserk DIYer New Member
    Chicago
    Thanks for the info. Now I'm curious...there has to be a contest somewhere on this site where everyone competes to have the best mpg. Right?
  13. jerrymildred
    11,491
    14,104
    Tampa, FL
    Not so much a contest, but there are lots of stats in this forum: Gen 3 Prius Fuel Economy | PriusChat
  14. AnotherPriusPerson
    AnotherPriusPerson New Member
    In case anyone doesn't know, you need 5 posts before you can share links.
    I'm literally using this post as my fifth one to be able to share links for the tools I used (not even affiliate links) to splice some wires and fix my prius lol.
  15. Flavio Nunes
    Flavio Nunes New Member
    Arizona
    Thanks for the great info, so what 2010 and up year models should I avoid in which one should I buy? do you recommend the one with the solar panel on the roof?
  16. jerrymildred
    11,491
    14,104
    Tampa, FL
    Welcome.
    The 2010 and '11 seem to have more problems and it seems like the 2015 (or was it 2014?) got improved rings.
    The solar panel on the roof only runs the ventilation fas to help reduce heat buildup in the sun. But that's a nice feature, that I wouldn't object to having.
  17. Berserk DIYer
    Chicago
    This made me smile immediately. Thank you sir.
  18. olefart
    olefart New Member
    Central, Fl. 32784
    2024 Prius Prime
    XSE
    This is my second Prius Prime, first one was a 2017, there were plenty around back then. I'm retired so I don't drive much. Round trips are most often around 30 miles. So I buy gas every 6 months, won't charge the battery to burn the gas up & fill it with fresh gas, I'm good for 6 more months I traded my 2017 Prime, 26,000 miles, on a full EV Ioniq 6, I've put about 2,000 miles on it & I'm afraid of it ! As the assist steering that seems to always "take over" anytime it wants, it'll just veer right or left for no reason, very scary, makes for tense driving.It may or may not be a simple fix but I don't think I'll ever be comfortable driving it... Not related, both rear tires are wearing like crazy on the outside. In my 20/20 hind sight, I should have never traded my 2017. I traded my 2016 Tacoma TRD Sport 4x4, 20,064 miles, in on the 2024 Prime, of course it had a dealer mark up. I'll try to sell the Ioniq 6 online.
  19. 1stTimerPrius
    1stTimerPrius Junior Member
    Billerica
    I must be missing something. I can not for the life of me find a Big Blue post button. I am on my laptop using a browser, Chrome to be precise. I am however not a frequent poster, (but have posted in the past) so not sure if my infrequency is part of the problem, and the button is hidden until I do something?
    Update: Ok, I see, I was not following the path to the precise Forum. You have to start from the Home page, scroll down until you find the Gen of interest, then select the Forum of interest within that Gen. Now I see the blue button to post a new thread. Thank you!
    #939 1stTimerPrius, Apr 15, 2024
