Entering Diagnostic Mode
Discussion in 'Gen 3 Prius Fuel Economy' started by 2010vn, Jan 3, 2013.
  1. 2010vn
    2010vn New Member
    Hi all,
    I searched but did not find a post about entering diagnostic mode of Prius 2010. Is that possible at all?
    Thanks,
    VN
  2. gliderman
    gliderman Active Member
    751
    223
    I dont know. I couldnt find it either. What are you trying to do?
  3. 2010vn
    2010vn New Member
    In Generation II, we can see the voltage rating,... which is to me important. I may be wrong because I am new to this type of car but a Google search brings up a lot of discussions like this one on generation II.
  4. gliderman
    751
    223
    Get a Scangauge, you wont regret it. Then you can see most all of the important functions in your vehicle.
  5. 2010vn
    2010vn New Member
    Thanks for the info. It is really an interesting gadget. I can see the cable connected to it looks like an Ethernet cable. Where is the other end hooked to? Toyota should allow Gen III owners to be able to enter the Diagnostic Mode just like Gen II owners.
  6. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    2010'ers, yes, but you need the nav unit. Using the ScanGauge is easier.
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    OBD2 port
  8. 2010vn
    2010vn New Member
    Thanks to very useful information. Does Prius 2010 have one such port?
  9. cwerdna
    12,544
    2,123
    SF Bay Area, CA
  10. 2010vn
    2010vn New Member
    Thanks again for very detailed info.. Learned something new today :)
  11. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Besides the built in stuff to SG that can be displayed, there are XGauges. See Current Gen III XGUAGE list for SGII | PriusChat for a list of stuff you can display w/SG. I don't know if that's the current list.
    An example alternative would be to use something like the Torque app on an Android device w/a Bluetooth OBD 2 dongle. See GenIII Prius Custom PIDs for Torque app | PriusChat.
    If you simply want to get the 12 volt battery voltage and you have no factory nav system (on 2010 and 2011 Priuses), a multimeter is WAY cheaper than the above.
  12. ron007
    ron007 New Member
    Glastonbury, CT
    How do you check the battery voltage in the 2010 navigation system? I didn't know that was possible. Sorry if this was discussed in another thread. Thanks.
  13. 2010vn
    2010vn New Member
    I will need more time to digest all of this new stuff :)
    I understand that there are 2 different batteries in the car: the 12V and the high voltage one for driving? I want to measure both of them. Can this be done with a cheaper device than the Scangauge. The display screen of the car already gives info. about MPG.
  14. gliderman
    751
    223
    Yes, Scangauge will measure both batteries, and 100+ other things your car wont tell you.
    2010vn likes this.
  15. 2010vn
    2010vn New Member
    Thanks!
  16. JimN
    7,028
    1,116
    South Jersey
    Hold Info button down while flipping headlights on/off 3 times
    Don't adjust any settings you don't understand. If you are going to anyway then jot down the original settings so you'll be able to restore any "oops".
    If you don't have nav then you'll need to measure the voltage directly or through something connected to the OBD port.
  17. salyavin
    salyavin Junior Member
    39
    Littleton, Colorado
    Via this thread how to do this on gen 3? | PriusChat
    You must have NAV since you need an MFD.
    1) Apply parking brake
    2) Press Power Button twice, foot not on brake pedal. You are now in accessory mode.
    3)Hold down Info button on right side of MFD. and at the same time turn Headlights on and off 4 times.
    4) A menu will appear on MFD.
    5) Select Fault diagnosis to see battery voltage.
    I went into the screen using that thread, I am not where I can try it now but I remember doing it then.
  18. 2010vn
    2010vn New Member
    Prius II do not have NAV :( Can't complain because I paid less for it than other models :)
  19. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    I wonder if this works in the 2012 w/o nav on the II
  20. El Dobro
    El Dobro A Member
    7,003
    3,226
    I wonder if the Nav-Lite units in the base PIP has this capability.
