FAQs | Troubleshoot - Need help? Ask questions here.
Discussion in 'PriiDash (TM)' started by 2009Prius, Jun 26, 2011.
  1. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    The vc_... version is native Windows version. Run it in a Windows command prompt.
    The "bad address" with the cygwin version is a known problem and has been solved by another user:
    PriiDash(TM): Enhanced Instrument Panel / Data Logger - Now Open Sourced! | Page 3 | PriusChat
    To compile the program for Cygwin I have been using NetBeans IDE. I have yet to learn how to do it from the command line. But the IDE is so easy to use that I may put it off forever. :)
  2. frankieomega
    frankieomega Junior Member
    Ponce Puerto Rico
    Another info maybe usefull to trouble shoot....
    Owner@FRANKIEOMEGA
    $ cygcheck -c
    Cygwin Package Information
    Package Version Status
    _autorebase 000065-1 OK
    _update-info-dir 01049-1 OK
    alternatives 1.3.30c-10 OK
    base-cygwin 3.1-1 OK
    base-files 4.1-1 OK
    bash 4.1.10-4 OK
    bzip2 1.0.6-2 OK
    coreutils 8.15-1 OK
    cygutils 1.4.10-2 OK
    cygwin 1.7.15-1 OK
    cygwin-doc 1.7-1 OK
    dash 0.5.7-1 OK
    diffutils 3.2-1 OK
    dos2unix 6.0-1 OK
    editrights 1.01-2 OK
    file 5.11-1 OK
    findutils 4.5.9-2 OK
    gawk 4.0.1-1 OK
    gettext 0.18.1.1-2 OK
    grep 2.6.3-1 OK
    groff 1.21-2 OK
    gzip 1.4-1 OK
    ipc-utils 1.0-1 OK
    less 444-1 OK
    libattr1 2.4.46-1 OK
    libbz2_1 1.0.6-2 OK
    libgcc1 4.5.3-3 OK
    libgmp3 4.3.2-1 OK
    libiconv2 1.14-2 OK
    libintl8 0.18.1.1-2 OK
    liblzma5 5.0.2_20110517-1 OK
    libncurses10 5.7-18 OK
    libncursesw10 5.7-18 OK
    libpcre0 8.21-2 OK
    libpopt0 1.6.4-4 OK
    libreadline7 6.1.2-3 OK
    libsigsegv2 2.10-1 OK
    libstdc++6 4.5.3-3 OK
    login 1.10-10 OK
    man 1.6g-1 OK
    mintty 1.0.3-1 OK
    rebase 4.1.0-1 OK
    run 1.1.13-1 OK
    sed 4.2.1-2 OK
    tar 1.25-1 OK
    terminfo 5.7_20091114-14 OK
    texinfo 4.13-4 OK
    tzcode 2012b-1 OK
    which 2.20-2 OK
    xz 5.0.2_20110517-1 OK
    zlib0 1.2.7-1 OK
    Owner@FRANKIEOMEGA
  3. frankieomega
    Ponce Puerto Rico
    Or this one.....
    Owner@FRANKIEOMEGA
    $ startxwin.exe
    /usr/bin/startxwin.exe: error while loading shared libraries: cygX11-6.dll: cann ot open shared object file: No such file or directory
  4. Mozencrath
    Mozencrath Junior Member
    50
    Im having an issue with the Cygwin version....Everytime I click GO it gives me "Error Cannot Open COM8 GUI Stopping* or something close to that. So I then loaded the windows version and voila it runs fine....Tried several times restarting and resetting everything and it just wont work...All of my .txt files are in the right place, everythign comes back fine with xterm. I am running PD2. Thanks for any help!
  5. 2009Prius
    2,705
    510
    63
    The name of the serial port under Cygwin is not "COM8", thus the problem. I will look it up and get back to you.
    From google:
  6. Mozencrath
    50
    Can someone tell me what sensor the obd port gets the IGN information from? My car is not charging the trac bat and the IGN is not going above 3 to 4 except above 3k rpm or 5 at idle.
  7. 2009Prius
    2,705
    510
    63
    For gen 2 Prius car problems please post here:
    Gen II Prius Care, Maintenance and Troubleshooting | PriusChat
    to get help. Good luck!
  8. vvillovv
    vvillovv Senior Member
    3,536
    1,246
    NY
    Is there more changelog for source version PriiDash20140411?
    The last entry in the log I see is dated 2013.
  9. 2009Prius
    2,705
    510
    63
    The included readme file is the current changelog. For the latest version I tested for a few months before releasing it.
  10. vvillovv
    3,536
    1,246
    NY
    it took a few seconds to get it, but I understand now.
    I've found in my changelogs it's helpful to list the release the changes refer to along with the dates of the changes. More experienced open source commiters usually also list the committers name along with the changes and / or patches to help reduce confusion when there are multiple authors working on the code.
    Just a couple of suggestions for you that I've learned the hard way, if they fit your coding style.
    Also, is it easy to split out the win source from the linux source.
    I'd just do it and watch for compile errors if I split out too much but I thought I'd ask in advance for suggestions from the author.
    And it looks like a nice piece of software. :)
    #150 vvillovv, Jul 17, 2014
  11. 2009Prius
    2,705
    510
    63
    The parts that are OS dependent are separated by #defines. It should be easy to figure out once you take a look.
    vvillovv likes this.
  12. dropper
    dropper Junior Member
    Round Rock, TX
    I just starting having some weird issues pop up, where the battery would seem to drain very low as well as seem to drain fast and charge fast at times. The HV fan ran very fast and it appears that I was having some sort of battery problem. I got the SX and checked the battery levels, and they all look great. The inverter temps don't look out of place.
    I'm not really looking for a diagnosis, but rather, is there anything that details what all of the different gauges are and what each of the fields are in the csv? This may aide me in figuring out what is really going on. Beyond the battery voltage differences (which are within hundredths of each other) and the temps, I am at a loss for what to look for next.
    Thanks,
    Keith
  13. 2009Prius
    2,705
    510
    63
    #153 2009Prius, Sep 28, 2015
  14. milleniaman
    milleniaman Junior Member
    61
    TN
    hello its been a long time since ive popped in 2009prius. my battery is finally giving codes. its been several years since obvious symptoms occurred such as those of the above poster. i now have a triangle and the p code is it 6000?. i would like to replace nodules but need the data priidash provides but is it safe to run the car in this condition?
    thanks for your advice
    john
    Vega S95_Meta ?
  15. 2009Prius
    2,705
    510
    63
    if you just turn the car on, leave it in Park, and run PriiDash to collect data, without actually driving the car on the road, then it should be OK I think. Good luck!
    milleniaman likes this.
