Fog light colour
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Simtronic, Aug 4, 2013.
  1. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I need to replace one of my fog light bulbs ( lamps for our US friends) so I will replace the pair. I want LED and of 2500K colour as this is optimal for actually seeing where you are going in fog. My problem is I can't find any decent LED's in this colour range they are all 5000K and above. HID conversions are illegal over here does anyone know of a decent yellowish LED bulb/ lamp available?
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    If you actually want a functional light, which it sounds like you do, then forget about LED and stick with halogens.
    LEDs simply aren't bright enough at this point, even those with a gazillion LEDs mounted in arrays.
    I've had some 2.5k Nokya bulbs in my foglights for a while now and am happy with them.
    Played around with LEDs in my foglights when I was using them as daytime running lights (DRL), so I am speaking from experience.
    SCH-I535
  3. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    Thanks, that is what I expected I was just hoping, I have got a pair of white LEDs fitted already but hopeless in fog ok as day running lights, one has just failed and just over a year old so much for the claimed 50,000 hours life expectancy
  4. xliderider
    8,140
    3,280
    Honolulu, HI
    Yeah, LEDs have lower output. They are also susceptible to failure from heat without proper heat dissipating measures like heat sinks.
    Here is a pretty bright LED bulb in the H11 size:
    What did you do to ur Prius today???? | Page 143 | PriusChat
    It is white though, you would have to apply some vinyl film if you want an amber or yellow light output though. Additionally, I'm not sure that the heat issue is adequately addressed with these bulbs, even though they have a heat sink and a small cooling fan.
    And they're also pretty expensive.
    SCH-I535
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    If 3000K HIDs are out of the picture, I'd suggest the 2500K Nokya bulbs as well.
    3000k HIDs ARE pretty awesome tho...
  6. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    Thanks to both of you a pair of 2.5k Nokya bulbs seems like the order of the day
  7. xliderider
    8,140
    3,280
    Honolulu, HI
    Remember not to touch the bulbs with your fingers when installing them. The oils from your hands will create a hot spot on the bulb leading to premature failure. Handle the bulbs by their bases only.
    SCH-I535
  8. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Let us know how you get on with them.
    Also, on this subject, is there an easy way of having dual function front fogs? 1, as a DRL and 2, as a fog? Dual filament bulbs or would it be too much hassle?
  9. xliderider
    8,140
    3,280
    Honolulu, HI
    You can wire your foglight relay to any wire that has power in Ready mode instead of the wire that only has power when the headlight/parking lights are on.
    I did that when I was using the foglights as DRLs. But I also modified 35w H8 halogen bulbs to fit in the H11 socket to reduce the heat from running 55w halogen bulbs in an enclosed foglight housing during the day.
    If you encounter a lot of fog though, you probably want to leave it with 55w H11 bulbs.
    SCH-I535
    GrumpyCabbie likes this.
  10. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I remember looking at a fitting in Halfords that was dual purpose it had two different lenses over each bulb the fog had a rippled effect that spread the light at low level and the DRL had a defuse lense. That was some time ago (pre-MK1 Prius) and wouldn't of fitted in a Prius anyway. The point being different spread of light as the fog light needs to cut under. When LED technology matures a bit I am sure they will make a combined unit that will be compact. The other alternative is to fit extra light fittings alongside
  11. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    like its been stated already, putting an led bulb into a normal housing is not the same as having an actual led fog light assembly. leds at this point, are only for looks. i would just throw some yellow 2.5k or 3k halogens in the fogs and have fun. you get good color for a good price and no hassle.
