Gen 4 Noise and Comfort level
Discussion in 'Gen 4 Prius Main Forum' started by VicD, Jan 27, 2016.
  1. bisco
    49,010
    not officially. can you point us to sources? toyota has made no mention of soundproofing differentiation between models, but a few posters here have intimated the probability.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,018
    Westminster, Colorado
    To be clear, I drove a Four (non-Touring) and a 2015 with 15" wheels (and 1 mile on it) both against my 2004 with 140,000 miles and Ecopia's at 44/42.
  3. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    See my post here link below, post #96 on that thread. It's not too detailed as other have done this. I didn't cover up everything neither. More like 60% -70% on the doors only. It really changed the way the car resonates on the freeway. The car isn't transformed but the way it resonates on the freeway is clearly reduced. That resonance on the freeway was really getting to me! Search for "sound dampening" or "peal and seal". Just knock on your doors from the exterior and listen to that "gong"!
    Done deal, got my Blizzard White Persona!
  4. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    I plan on installing some sound deadening material in the front doors of my gen3 this spring. Seems rather "hollow"
    iPhone ?
  5. bisco
    49,010
    i make sure my door is closed before my wife slams hers. seems to ease the pain.
  6. Tande
    Tande Active Member
    498
    301
    Mich.
    Old habits are hard to break! :LOL:......I'm old enough to remember when it took at LEAST two swings to close/latch a "G.M." door.......
    Tandem Rider and bisco like this.
  7. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    Interesting. Curb weight of Gen 3 2014 Prius Three Touring is 3080 lbs and the tire is P215/45R17 87V. This includes the Bridgestone EP422 Plus which indeed was 87V. Other models get 195/65R15 89S.
    Curb weight of Gen 4 2016 Prius Three Touring is also the same exact 3080 lbsand the tire is also P215/45R17. This includes the Bridgestone EP422 Plus, which remains at 87V according to Bridgestone. The other models also get 195/65R15, but now that same Bridgestone EP422 Plus is 91H.
    So, depending upon whether you get Touring or other, the OEM load index and speed may be 87V (4806 lbs) or else 91H (5423 lbs). A four point load index difference is pretty large (617 lbs in this case), yet it's the heavier car that has the lower load index. Are these 87V and 91H specs reflected in the 2016 manual?
    EDIT:
    No they are not.
    According to the 2016 manual, it is still 89S for the 15" or 87V for the 17". So you can still safely get an 89 rated tire instead of having to jump up to 91 in 2016.
    Big difference in pressures though. For the 15", it's 39/36. For the 17", it's 33/32.
    #47 Eug, Feb 8, 2016
  8. Tideland Prius
    16,075
    39/36 is for the Eco model. I believe it's 36/35 for the non-Eco 15" models.
    #48 Tideland Prius, Feb 8, 2016
  9. vince22
    vince22 Active Member
    205
    249
    califorinia
    Tideland Prius likes this.
  10. Tideland Prius
    16,075
  11. cunnink2
    cunnink2 Member
    55
    Greenville, MS
    My 2016 Prius 4 came with Toyo NanoEnergy A29. I'm ordering 17" wheels and am considering the Toyo Versado Eco 215/45/17. I assume that's the consumer name vs NanoEnergy the OEM.
  12. fsu23phd
    fsu23phd Active Member
    185
    114
    Wilmington, NC
    I'm bored sitting in the dealership for my 5k service... I thought I would add that I do notice a minor noise comming from the left driver side ac vent, between the steering wheel and the window. It is a rattling noise, a little harder than the sound of crinkling paper. Nothing huge, but definitely there. It's a 2016 two eco.
  13. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Perhaps the built it noise maker ?
  14. dalea
    dalea Junior Member
    Washington, USA
    Four Touring
    I have a 2016 4T and have also noticed a noise in the same area. It's a resonate buzzing type noise at certain motor RPM/loading or on rougher pavement. I have tried pressing weight on various dash sections while driving but haven't found anything that affects it yet. It's low volume level and I usually don't even hear it when the radio is playing. I will keep trying to solve it.
    fsu23phd likes this.
  15. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    My UK Excel spec Gen 4 came with the 17" Toyo Nanoenergy R41 tyres and they are a lot quieter than the Gen 3 with Michelin Primacy tyres (supposed to be the quietest at the time) was on most roads but are quite noisy on rough surfaced bends.
  16. kenji4861
    kenji4861 Member
    136
    60
    The 4th gen Prius Two wouldn't make a difference. The Prius Two comes with the older batteries as the ones in the 3rd gen.
    This would explain why some people that test drove the 4th Gen Prius Two found no difference while anything else should be "somewhat quieter"
    "Yes, the outgoing Prius plug-in variant had a lithium-ion (Li-ion) battery, but this new model is the first regular Prius to offer one; it's standard with every version except for the base trim level, the Prius Two. At 54 pounds, the new Li-ion battery pictured here weighs 35 pounds less than the nickel-metal-hydride (NiMH) battery. And it uses only 56 cells rather than 168 because the Li-ion cells are rated at 3.7 volts versus 1.2 for the NiMH cells. The voltage of the two batteries ends up virtually the same at 202 volts (NiMH) and 207 (Li-ion)."
  17. kenji4861
    kenji4861 Member
    136
    60
    Alex on Autos on youtube should have a video detailing the Gen 4 this week, but I asked him about the road noise improvement. He said it's better but a mid-size sedan (camry, accord) is still better in terms of comfort.
    Here is a POV video of 4th gen where you kind of get an idea that the road noise isn't significantly different.
  18. jbkendrick
    jbkendrick Active Member
    232
    197
    Baltimore, MD
    My four has Bridgestones and the tires seem very quiet. What I do hear that I am not used to is a great deal of wind noise when driving 50 plus. Could be my hearing which is shot, and perhaps my hearing aids are exaggerating that frequency of sound. J
  19. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    My 2016 Three model has 15" Toyo tires. They were terribly noisy when new. After 4 months, and 3200 miles, they actually seem to be quieter.
    Or maybe I just got more deaf. :cautious:
    Great photos, Kevin. Does it say on the sidewall somewhere what is the Max tire pressure?
    #59 Coast Cruiser, Jun 25, 2016
  20. krmcg
    2,592
    2,389
    Whittier, CA
