Is my traction battery going bad?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jdonalds, Jun 28, 2015.
  1. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    But that means I save $150 by doing it now.
  2. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yes, but even with my significantly degraded HV battery (refer to the second figure in my previous post to see roughly how mine now behaves), I am getting hardly any loss of MPG. I'm currently at about 4.3L/100lm (55 MPG), pretty much the same as it always has been. So based on my own personal experience, I'm not totally convinced that a new battery will cure the MPG issue.
    Where I do lose a bit of MPG is where it charges to the "top referenced state" explained earlier, and then it subsequently undershoots, dropping bars 5 and 4 (and sometimes even 3) very rapidly. The Prius just behaves like a total slug when the SOC is down around 2 bars, and it really doesn't operate very efficiently for the next 5 minutes or so until it regains that charge.
    When I'm out driving on mostly flat roads however, the SOC just sits on six blue bars most of the time and you simply won't even know that the battery wasn't perfect. It operates totally normally and there is no degradation of MPG at all.
    Again, if you look at the graph from my previous post you will see why the SOC seems a bit erratic at times. Essentially it sometimes just doesn't have as much charge as it thinks it does (in what I've called the "top referenced" state), and this makes it plunge unexpectedly quickly at times. Particularly at start up when the engine is cold (which btw is when the demand on the traction battery is often very high).
    BTW. Talking about the engine being cold, I strongly recommend that you let the engine warm for 40 to 60 seconds before you drive off from a cold start (leave pruis in "P" and tap the accelerator to make the engine come on). This GREATLY reduces the stress on the HV battery. This is particularly important if you need to either climb a hill or accelerate quickly from a cold or cool engine. Please do give this a try!
    #62 uart, Jul 5, 2015
    wjtracy and SageBrush like this.
  3. jdonalds
    541
    225
    What I continue to notice is even with the battery at full blue bars charge I can't start off from a light without the ICE coming on immediately. I'm taking this to mean that the ECU is checking the HV battery for sufficient voltage/charge to be the sole means of propulsion but it determines it is not, so it kicks in the ICE. This goes along, uart, with your comment, "Essentially it sometimes just doesn't have as much charge as it thinks it does".
    I'm suspecting a single cell has gone bad, or mostly bad, causing all of this behavior. Leaving the car in the garage last night it was full blue, then it was purple this morning.
    On the way home from church this morning we got 27 mpg on the SCAN II.
    49,122
    maybe it's time to think diy?
  5. jdonalds
    541
    225
    Right. The DYI I'm thinking of is I receive the cable and software I ordered from eBay, due on the 14-15th. Find out that I have a bad cell. Buy a battery from Toyota and replace it.
    If the cable and software don't show a bad cell I will have to do some more troubleshooting. It could be the ECU I suppose.
  6. bisco
    49,122
    you have to test the cells under load, but i think you can determine the potentially bad ones.
  7. jdonalds
    541
    225
    I'm assuming I can do that while driving.
  8. bisco
    49,122
    me too, but i have no idea.
  9. dolj
    dolj Senior Member
    7,534
    3,785
    Wellington, New Zealand
    Bisco is correct that you should to test under load. You can do this easily with the HV Battery still in place in your car once you have your MVCI up and running by running the test in the following link:
    Predictive Battery Failure Analysis For The Prius Hybrid | Art's Automotive
    hope this helps.
  10. strawbrad
    953
    997
    NO:mad: When you are driving pay attention to driving! The charge and discharge (or load) test is done safely sitting still.:)
  11. bisco
    49,122
    you'd think the software would log it. i suppose someone else can drive.
  12. dolj
    dolj Senior Member
    7,534
    3,785
    See also strawbrad's post on the first page of this thread for a succinct test:
    This thread | post #12
  13. strawbrad
    953
    997
    Art's Automotive test does log and graph the min and max block voltages. A block is a pair of modules. That would be a safe test to do while driving as you can look at the data after you stop. The Toyota manual puts a little different spin on the tests. They are all variations of the same theme. Load the batteries, charge the batteries, look at the voltages in real time. I like to highlight (just click on the data line) of the three or four blocks that seem to stand out on charge or discharge. That makes them easy to watch on the other side, charge or discharge. The Toyota manual recommends replacing the pack if there is more than .3 volt difference between the max and min. That is not enough to light the triangle or trip a code. There are lots of Prius running with over .3 volt variation.
    Many Independent shops are now installing NEW Toyota batteries for far less than the dealers will. Waste bothers me. A failed pack will often have 20 or more usable modules. A Toyota dealer will send those good modules straight to the recycling yard. An independent shop will use those modules for rebuilds. The returned core will have truly junk modules fit to be melted down.
    Brad
  14. jdonalds
    541
    225
    I just sent an email to a local shop to see how much they'd charge to replace the battery with a new one.
    Thanks for the suggestion Brad.
  15. jdonalds
    541
    225
    My cable and disk arrived today, one week earlier than proposed. I'm excited to have this new tool. I stuck the disk in my laptop and it seems to work in my 64-bit windows 8.1 laptop. I suppose I might have to deal with 32 bit vs 64 bit but I'll just try it first. I'm anxious to hook it up to the Prius tomorrow...
  16. wjtracy
    wjtracy Senior Member
    11,317
    3,588
    Northern VA (NoVA)
    As far as engine coming on from a light, you have to know about of the stages of hybrid system warm up. Also Gen2 is not designed to go very fast on EV mode. Only if you are in the final warm-up stage and went extremely slowly should ICE not come on.
    As UART says, as hard as it is to understand, low MPG is usually not the big issue with weak batt.
  17. jdonalds
    541
    225
    Yes after 7 years and 152K miles I'm well aware of those aspects of the Prius. It has been quite a bit of fun learning about the car's behavior.
    What I'm talking about is conditions where the battery level shows all blue bars, the car has been driven for more than 20 minutes, and I'm starting off at a light in creeping mode but the ICE comes on.
    It seems to me that if the ECU thinks the battery is low, when the charge indicator shows it is not, and keeps the ICE running when it should not be that will effect mpg dramatically.
  18. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Uart was describing a gracefully ageing battery that has a (relatively) homogenous drop in capacity across the modules.
  19. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yes, that's exactly what I was thinking SageBrush. My battery has definitely lost some amp-hour capacity, however I seem to be fortunate in that it appears to have retained its "grunt".
    If jdonalds' problem is more related to higher internal resistance rather than a simple loss of amp hours, then that might explain the different behavior he is seeing. One thing that seems a bit odd about that however, is that I thought the Prius would throw a code pretty quickly if that happened. I know that the Prius will allow for quite a large loss of capacity without throwing a code, but I thought it was a lot less tolerant of other faults.
    Coincidentally, I'm just shy of 245000 km right now, which is almost exactly 152k miles as well. (y)
  20. jdonalds
    541
    225
    Well no progress today. I'm hitting the 64-bit CPU problem. We have three laptops in the house, all 64-bit. I don't want to go down the path of installing a virtual PC to create a 32-bit system so I've been trying the 64 bit fixes. Unfortunately the one I tried was three years old, not all the software components were still there, so I wasted two hours on it.
    I'm going to attack it again tomorrow. So far the software can not connect to the car.
