Map update?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mikenancy1, Dec 3, 2013.
  1. mikenancy1
    mikenancy1 2012 PiP (Base), '10 Highlander Hybrid, '05 Prius
    103
    Geneva, IL
    When was the last time the map was updated? I've read here that the map update can cost $169 (much more than the cost of a good stand-along GPS!), but I haven't seen any direct references about there being a new version. If it hasn't ben updated recently, does Toyota offer updates on a regular basis? How can I see what version of the map I'm running?
  2. Priusmpg
    Priusmpg Active Member
    628
    82
    Fremont, California
    2014 Prius Plug-in
    you cant get map updates as far as i know because its only for hdd systems
    i see you have a base prius plug in that cant get map updates
    correct me if im wrong, anyone?
  3. Tracksyde
    Tracksyde Member
    1,380
    668
    So Cal
    The new systems (flash or HDD based) get updated via USB port
    See this post: Map Updates | PriusChat
    Here's a specific post about the Display Audio/Harman unit (with part numbers): 2012 Prius v Navigation updates | Page 4 | PriusChat
