Mudguards for the C?
Discussion in 'Prius c Accessories and Modifications' started by SILVERCwSUN, Jul 23, 2012.
  1. SILVERCwSUN
    SILVERCwSUN Member
    261
    77
    29
    Western North Carolina foothills
    Enjoying the C....but really would like Toyota to make the mud guards available for purchase..I wonder why the mother ship waits soooooo long to produce OEM accessories. New year model and design...I understand.
    This will be my next add-on for sure.
    Hellooooooo mudguard dept? How's about getting the plastic injector fired up and filling some mud guard molds/templates. :)
  2. priusCpilot
    priusCpilot Active Member
    631
    209
    LA
    Hehe.
    I did hear though no other accessories will be in the works for this year so we need to see what they add in the future models.
  3. SILVERCwSUN
    SILVERCwSUN Member
    261
    77
    29
    And you heard from whom?? Was it from Toyota corporate HQ or the rumor mill :)
  4. priusCpilot
    631
    209
    LA
    I forget but I think it was someone that contacted Toyota and found out that they won't have other accessories this year other then what is available. They posted here somewhere about it I think.
  5. robert c
    robert c Junior Member
    Justin Park likes this.
  6. maddog61
    maddog61 Junior Member
    44
    robert c ...where did u get the mudguards
  7. KaliforniaKid
    KaliforniaKid 2013 Prius v Five 2012 Priuc c Four
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    Robert C...
    Your link to JuicedHybrid.com (a ten star vendor in my opinion) are mudflaps for the Prius at $118.25.
    Are you saying that they will fit on the Prius C with "Lots of trim work on front guards rear were pretty easy."
    Can you clarify.
    Had to shave off some plastic for contour?
    Bolts or screw placement adhoc?
    Wonder if mudflaps for a Yaris would be a closer fit?
  8. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    I don't see any for the C on that site. I got to find some. These wide 7 inch wheels sit the tire out just a shade.
    Dan
  9. SILVERCwSUN
    SILVERCwSUN Member
    261
    77
    29
  10. SILVERCwSUN
    SILVERCwSUN Member
    261
    77
    29
    Went by my dealer and the Yaris mud guards seemed close, Parts guy let me do a dry run, but not a factory fit for the C so I passed on the purchase. I would like to know how Robert C installed his set. They really have to be secure, as they will take a lot of abuse from rain, snow and road debris. Maybe he will chime in and help us out. Did he use the existing mounting holes? Are there mounting holes? If so maybe the mothership has plans to produce flaps for the C.
  11. robert c
    Yes the Front splash guards took a lot of trimming, rear were easy fit. the link i supplied are the exact set I ordered. This was a four hour job to make these front splash guards work. But I wanted the look they provided. Good luck.
  12. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Robert C, could you provide a bit of play-by-play on the modifications you had to do? I'm sure there are a number of us that are up to the task but many would benefit immensely by having a coaching. Are the modifications self-evident and simply took a lot of time to do correctly? Are there ways NOT to do something?
    It looks to me that the contour of the body panels are pretty much the deciding factor in whether a set of guards would mate up. Do these mate well? Exactly? Almost?
    With the extensive modifications will they hold up to huge chunks of winter ice/slush that has frozen solid? I kick those chunks to knock them off, will I knock off the guards with them?
    And finally, are these a permanent fix or should we wait (and wait, and wait) for factory guards?
    Thanks much for your being a point man on this issue.
    ChinchillaGirl likes this.
  13. robert c
    OK first I started with the passenger side front guard. Place the guard up to the front fender the first thing you come in contact with is the lower plastic fender insert you must trim this around 2" starting with the inside to out, small cuts you will need a very sharp blade, make sure you do not cut the lower support on the guard. This is the tricky part because you need all the lower guard support for snow and mud that will hang on in the winter time. OK after snug fit against outer fender is achieved mark drivers side guard and cut. Mark and use the quick nuts that you will have to buy at you local auto zone. All of the quick nuts can be placed on the plastic inside fender well with a small cut with a utility knife 3 per guard, be careful here cut once measure and mark twice. The rear guards are easy maybe 15min. Front guards 3+hours but they are worth it.
  14. endar
    endar Junior Member
    Idaho
  15. Mr Incredible
    955
    506
    Neb
    I bought the Prius mudflaps to put on the C.
    The rears fit very nicely, though I had to grind off some of the backing nuts to they would fit the fender lip area. They are wider than the set for the Yaris. The Yaris rears really are too narrow. I have the wider wheels, so YMMV.
    The fronts I have not done. It will require thinking and I haven't been in the right frame of mind for it. Now it's gonna snow before I know it. I'd better get my mind right soon.
  16. danjag
    danjag Junior Member
    Western NY
    Thanks for the link, Robert C. I also found a 5% off discount code at retailmenot dott comm, enter "LINK" in the box at checkout on juicedhybrid.
  17. Justin Park
    Justin Park Junior Member
    61
    Fullerton, California
  18. danjag
    Western NY
    Robert C, would it be possible to see some close-up photos of the modifications you did to the front mud guards? I read your play-by-play, but I think a picture or two would help immensely. Thanks!!! Dan
  19. Justin Park
    61
    I don't think its gonna happen boys :/
    as long as he has those installed on his car, he wont be undoing it to take pictures
  20. danjag
    Western NY
    OK then, next guy to do this install, please take photos of the modifications.
