My PiP - After One Year (Stats)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by usbseawolf2000, Oct 24, 2013.
  1. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    The claim was made that they operated at redline. A video was provided clearly showing that wasn't the case. In fact, it showed the operation wasn't all that different from the standard Gen3. There's just more electricity available.
    Think about all the power-carriers (aka gears) in the 6-speed automatic transmissions now being sold. What is their maintenance schedule? What about the 9-speed Chrysler will be rolling out this fall?
  2. drash
    drash Senior Member
    2,463
    1,239
    Upstate NY
    Sure. Why not? It can still be plugged in anywhere but looking at where it can go for me sure. Heck it even has a 7 passenger option.
  3. Bill Norton
    Bill Norton Senior Member
    1,823
    598
    MONW, Ks.
    Most (all?) Car Manufacturers have a maintenance schedule for changing the ATF in any automatic transmission.
    My Gen3 did not have that in the book.
    What does the PiP say about this maintenance? Are ATF changes ever discussed for PiP?
    Just trying to help you guys......
    My Gen3 would do maybe 47 mph in EV mode, the PiP can do 62 mph. Correct?
    What is happening in that box O'gears to allow this increase?
    As for "the Tesla as your only car" question, I personally need a car that I can go anywhere, at anytime. On the 'Supercharger Maps' those are One-Way circles of range.
    To each his own.
  4. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    My understanding is it's more to do with the kW/hp available from the battery than the gears.
  5. CharlesH
    2,785
    1,152
    Roseville, CA
    Just a nit: the Prius (Plug-in, or otherwise) does not a transmission. There is nothing like a torque converter or clutches engaging and disengaging gears. Obviously, the power split device has to have some sort of lubrication, but I don't know if this is anything like automatic transmission fluid. I am not a mechanic, but I suspect that the lubrication would be more akin to that in a manual gearbox.
  6. drash
    drash Senior Member
    2,463
    1,239
    Upstate NY
    Page 618 transmission fluid is Toyota genuine ATF WS. 3.6qt
    iPad ? HD
    CharlesH likes this.
  7. El Dobro
    El Dobro A Member
    6,974
    3,211
    I read somewhere on here that the transmission has a small pump to splash lubricant around, but that's about it.
  8. Bill Norton
    1,823
    598
    MONW, Ks.
    If you want a primer on the transaxle ATF change subject : ATF fluid changes ARE Required. | PriusChat
    There are no friction clutches or torque converters, just gears and bearings in a box with two motor/generators.
    And the gears are always engaged, no shifting.
  9. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    At the request of the OP, I have created a new thread for any further discussion on this topic.
    Does the Prius have a transmission? | PriusChat
  10. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    wow ! maybe we need a new thread or two
    This one is titled "My Pip After One Year - Stats"
  11. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Fixed.
  12. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Where do you get $0.05/kWh? The lowest PG&E E-1, E-6, or EV are about $0.10/kWh or higher. Also, if you have a bill that goes to Tier 3 you must consider that some of those Tier 3 kWh are there because they were "pushed" from a lower tier due to the fact you used more baseline kWh.
  13. CharlesH
    2,785
    1,152
    Roseville, CA
    I have the EA9 TOU for Low Emission Vehicle rate, which is no longer offered. Looking at my most recent bill, my Tier 1 rates are $0.05 Off Peak, $0.11 Part Peak, $0.33 Peak.
  14. CaliforniaBear
    1,179
    289
    Northern California
    Oh yes, I tried that for a while but changed to E-6. In any case when your off-peak kWh adds to the total and you have some in Tier 3, then the off-peak kWh "pushes" up the total so more kWh fall into Tier 3 hence the effective cost for the off-peak costs more. It is a complicated mess :(
    If you can stay in Tier 1 with solar things are much better :)
  15. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    If pricing is really done that way, it is a scam.
    It is no wonder that EV owners in CA embrace PV. I'm surprised it is only reported at ~ 40% rather than 100%
  16. CaliforniaBear
    1,179
    289
    Northern California
    The new EV rate has no tiers so what you use and when you use it is what you get.
    Peak - Part Peak - Off Peak
    Summer Usage $0.39274 $0.20933 $0.09709
    Winter Usage $0.26545 $0.15989 $0.09973
    However the time of use schedule is not favorable for us folks in the hot central valley using lots of A/C in the summer and considering the relative modest kWh usage of the Prius. For an all EV car with high kWh usage the EV rate is probably a good deal.
  17. Air_Boss
    Air_Boss Senior Member
    3,925
    1,073
    New Yawk
    Gotta love the market magic on utility rates...
  18. Air_Boss
    3,925
    1,073
    New Yawk
    <dupe for emphasis>
  19. CharlesH
    2,785
    1,152
    Roseville, CA
    PG&E has a "what-if" web page takes takes your individual usage history, as reported by your SmartMeter, and computes what your bill would have been with various rate plans. I ran mine with the new non-tiered EV plan, and it was significantly higher than what I am paying now. So I will stay with the old rate plan until they force me off of it, which they promised they would do at some point. :( I suspect that people whose cars have much larger batteries come off a lot better on the new rate plan.
  20. srl99
    srl99 Member
    113
    23
    2014 Prius Plug-in
    The CA utilities that are NOT "regulated" by CPUC charge reasonable rates (Public Benefit Utilities). The IOU's (Investor Owned Utilities) have a GUARANTEED return on capital (which, of course, they account) and charge some of the highest rates in the country.
