New Brake Pads = Car barely moves!!! Help please...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tommerdoo, Aug 27, 2015.
  1. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Ok. So I pushed in the passenger caliper fairly easily with my regular brake tool (not the c-clamp). So the caliper piston on the passenger side seems to be responding fine and doesn't require heroic pressure to get back in.
    The driver's side caliper is very difficult to push in and bleeding the brake makes no difference in the amount of pressure required which is much much harder to push in than the passenger side one.
    So. The driver's side caliper appears bad. This goes along with the excessive brake wear that was only on the driver's side. So at some point it looks like this caliper failed.
    However....I'm still trying to understand one other point. If the driver's side caliper was the only bad one.....why would both brakes be locked up totally and fully and not just one side? It doesn't make any sense to me....The driver's side rotor gets hotter it seems when I touch it after driving a block than the passengers side (but that also gets hot....just not quite AS hot).
    So anyone have any ideas? See if this was a normal regular car, I could fix the caliper and call it a day, right? But I've heard the Prius brake system is crazy complicated with solenoids and actuators etc etc....namely, what I'm wondering is something not allowing brake fluid (besides the brake line itself) not to retreat from the caliper pistons, or am I over thinking this too much. Like, did this brake caliper fail, not on it's own but because something like a solenoid or something didn't allow the brake fluid to return upstream.
    Hmmmmmm.
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Some valve or some other weird problem just seems so unlikely. Did you open the bleeders when originally replacing brake pads? What’s the level of brake fluid in reservoir? Maybe you have too much fluid or your brakes need to be bled.
    Replace the caliper that you now know is bad and check that pads and sliding pins can move freely on both sides. Bleed the front brakes with the way I described earlier.
  3. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Ok, I am ordering the caliper because nobody in our tiny town has a caliper or a rebuild kit. The dealership does, but I'm not paying $500 (their price) for a caliper. Heck, even their rebuild kit was $50! Anyways, that's on it's way.
    I will say that I did clean up the slider pins and put new caliper grease on them. They seemed to be a bit dry of grease on them and they weren't very springy back. After lubricating them they seem to to be more responsive and travel a little more.
    I think the caliper slide pins at some point failed to do their job on the driver side leading to a failure in the caliper piston. Just a thought.
    As I purchased this car a few months ago, I'm hoping there are no other maintenance issues that aren't at hand. I did notice my CVT fluid a beautiful brand new shade of red so I'm quite pleased that I don't have to worry about that.
    For changing out the brake caliper, is it fine for me to clamp off the brake line with my needlenose vice grips, making sure the 12 volt battery and brake relays are disconnected and simply remove and exchange the caliper, then as you said bleed the system (gravity with tubing into a soda bottle style).....this won't get me into any trouble will it?
    Thank you again.
  4. ChapmanF
    15,161
    If the driver's caliper piston is hard to move even with the bleed screw open (so no hydraulic resistance), there's a good chance you're overthinking this. I would first take the caliper apart and look for signs of why it's hard to move. Disconnect the 12 volt power and use up the boost pressure first. Just barely loosen the banjo bolt before unbolting the caliper (easier to apply loosening torque on bolt that way), then lift the caliper as high as possible (up near top of strut) before disconnecting the brake hose. You can clamp a bit of rubber around the end of the brake hose and leave it stashed up high in the spring to minimize the amount of fluid you lose while investigating the caliper.
    My new policy regarding Gen 1 calipers is: always rebuild, repair, restore if possible instead of replacing with aftermarket because I found a ginormous quality gap between the Toyota caliper and an aftermarket reman: two things, namely, the reman that I bought had zero piston return, so right out of the box it dragged, and second, the reman lacked any corrosion resistance at all and was completely rust covered in a few weeks. It might be possible to just buy a better quality aftermarket reman, but the experience has turned me old-school and now I keep a spare rebuild parts kit on hand. :)
    Now, that second point might be specific to Gen 1 calipers, which are cast iron; I think yours are aluminum and I don't know the story on corrosion resistance for those, Toyota vs. aftermarket. Maybe there's less of a difference. Toyota does not seem to sell their own reman version of the Gen 2 caliper as they do with Gen 1.
    I think you also have phenolic pistons rather than metal. That's good in several ways (no rust, less transfer of heat to brake fluid) but they are vulnerable to scratching or chipping if not handled carefully (be especially careful when forcing the piston out, use thick padding). Although they don't rust, I've read that some old phenolic pistons might swell, which could be a reason to stick. Pistons aren't included in the rebuild kit, but are only about $17 each if needed.
    So, I would certainly start by making sure there's a working caliper there, bleed the system well, and then see if there's still some problem.
    -Chap
  5. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Thanks Chap. Phenolic pistons. Wow....I really DO learn something new everyday. Amazing.
    I've heard a good way to force the piston out is to simply use your brakes to pop it out. Is that bad on a Prius (like too much fluid loss?) Otherwise I can go to a friend's house that has an air compressor.
    I'm still confused though why both sides would lock up equally with such a strong force that the wheels would not rotate in neutral with the tires off.
  6. ChapmanF
    15,161
    Yikes! From Village Toyota it's $28.07 here in CONUS, I guess everything must be extra expensive on the island. (The whole caliper is more like $265 here.)
    Two things though ... (1) that rebuild kit has the parts for two calipers; (2) the aftermarket reman might be a lot lower than Toyota's price but, at least what I saw re: Gen 1, it still wasn't worth the step down in quality. (Maybe you ordered from a better quality reman supplier than I did, and maybe there's less of an issue with your aluminum calipers than with my cast iron ones.) If you have good repairable Toyota cores and can repair them with a $28 Toyota kit, it seems less of a gamble to me.
    ... but of course you don't know if one's in repairable condition until you dive in ...
    -Chap
  7. ChapmanF
    15,161
    It will make a bigger mess. :) Should be ok as long as you have powered down and used up all the boost pressure, so your foot pressure is in direct control of the shove you're giving. It's pretty safe for the piston, because it will push out under a semblance of control.
    That's a traditional approach, and that's where you want to be very careful (especially with a phenolic piston). Unlike brake fluid, which doesn't compress, the compressed air behind your piston will shoot it like artillery when it comes at last free. There will be a loud bang. The piston isn't likely to go very far, because the first thing it hits will be the metal far side of the caliper (assuming your fingers don't come first, which you don't want). But that's very likely to chip a phenolic piston. You should have many thick folds of rags or the like stuffed in there to pad it.
    Yes, that is a mystery. While you've got the bleeders open both sides, it might be worth pumping several strokes of fluid out and replacing with new at the reservoir. (I think you can do this without complications as long as all power is off and you never let the reservoir get empty). If there was any gunk up in the hydraulics department, maybe that could help, or maybe not. What it won't do, though, is flush any of the remaining actuator passages that are only in use when the power is on. Scan tool would be needed for that.
    -Chap
  8. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    So. Here we are. I've taken the caliper off. It was very easy and only lost a small amount of brake fluid. What was nice is that the boot inside the caliper piston allowed the piston to be pushed out but kept all the brake fluid inside until I removed it.
    Alright. So I've cleaned up this caliper, inspected the square cut seal, looked at all the walls of the cylinder, looked at the cylinder itself. Everything looks.....brand new. Everything looks perfect. There's nothing happening that's wrong here. This is crazy. I'm really stumped on what is happening that is not letting the brake pressure off of the system.
  9. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Also....I reseated the caliper piston by hand....but it won't budge any further. Would that be a sign that it's swollen, gotten fatter? Or should I just c-clamp it back in? It looks straight on so far, but it won't go on any further. I mean....maybe the only problem with this brake caliper is that the piston is bigger than it should be? It seems to be really really squeezed in there. I'm only using brake fluid to lubricate them back in. I'm hesitant to use force to get the piston back in because I've been told that the phenolic is resin and shouldn't be forced in, but there's no way it's going to go in by hand....that's simply impossible.
    At the moment, it seems as though perhaps both of my phenolic caliper pistons might have seized up due to expanding by being in some way in contact with water.
    This car was purchased in Hilo, Hawaii which receives 130 inches of rain a year. I'm not sure if that had anything to do with it but on researching I've come across people claiming that phenolic pistons do in fact swell up then cause brake drag if exposed to water/vapors.
    UPDATE: I just purchased new calipers and rotors and will install this Wed. Hopefully the cause of all this was faulty phenolic pistons. I'm greasy. I'm pooped. Time for a shower!
    #29 Tommerdoo, Aug 30, 2015
  10. ChapmanF
    15,161
    Thanks for the great pictures!
    You can trial-fit the piston in the cylinder without the seal or boot installed, just to simplify the feel of the business. It looks as if yours is not far in. The clearances can be tight enough (I've found this on mine, with the metal piston) that any imperceptible angle to the piston as you are starting it into the bore can make it feel as if it absolutely won't ever go in, and then somehow after a minute or so of random jiggling you finally hit perfectly straight and shoop! it slips right in.
    Naturally that's a lot harder to test when you are trying to contend with the rubber parts at the same time, so I'd recommend a trial-fit without them just so you can easily tell whether that's going to happen, or you really have a piston that won't go in at all.
    I have read claims that phenolic pistons can be swollen by moisture. (I've also read claims that they aren't ... hmm ....) In the claims that they can be, usually the writer doesn't seem to be talking about random ambient moisture, but moisture that's been absorbed into the brake fluid. Or maybe the square-cut seal is now just enough harder from heat/aging/etc. that your piston hangs up on it.
    I, for one, would be quite curious whether you could successfully fit a new piston into your caliper. I guess we'll only find out if (a) your replacement calipers don't come with a requirement for you to send in your cores, and (b) you're willing to invest in a piston (about $16 here in CONUS, for you $29?)
    If you're allowed to hang on to your cores, you might be able to turn them back into good working spare calipers for not much money.
    -Chap
  11. ChapmanF
    15,161
    There's a company that sells an inexpensive brake pressure gauge kit that would be one way you might be able to confirm whether that's really what's happening. (The important part of the kit is the set of adapters; the M7x1.0 is the one that fits in place of your bleed screw and lets the gauge attach. Pressure gauges you can get anywhere, I just haven't found any other inexpensive source for such an adapter.)
    -Chap
  12. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Hello board! Thanks for all your help and encouragement. After installing the two new brake calipers, my Prius is getting 51-55mpg and driving BEAUTIFULLY!
    Previously I called Toyota and the parts department had said that they rarely had people buying new brake calipers because the Prius seems to never have many problems there and he seemed highly doubtful that that was the source of the problem.
    But it was. And everything is working beautifully now. So just to recap, the phenolic brake pistons in the calipers DO at times seize up, in my case it was on both sides.
    Thanks again everyone!
  13. bisco
    49,076
    wow, in hawaii, no less. congrats!(y)
  14. ChapmanF
    15,161
    Great report! Did they want your old ones back as cores?
    -Chap
  15. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Yeah, I had to bring in the cores to get the $35 / each back.
    I tell my friends, there's no sadder car on the road (or driver on the road) than a Prius with a dragging brake! When your fuel economy is on par with a Toyota Corolla, you have a perma-frown on your face, for sure!
  16. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    For an update to my story about how (I believe) my brake caliper pistons died in the first place, please check out my RANT about how the 3,500 foot decent behind our house and how the braking in the Prius was not working how I hoped it would! Please add any comments thanks!
    3,500 foot decent = crazy HOT brakes and Burning Smells | PriusChat
  17. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Interesting thread and informative too. Glad to see Tommerdoo got it all sorted out.
  18. EdwardN
    EdwardN New Member
    South Bend, In
    Not an authority, but I have an opinion: Things you know are, you have good rotors,slide pins, pads but questionable caliper(s). If this was my car,before rebuilding calipers, I would drive carefully and allow things to "reseat". Most likely your brake job is done and you are being too analytical. The worst thing that can happen is you will ruin your calipers, but you are going to rebuild them anyway. Right?
  19. Mohammed zulfiqar
    Mohammed zulfiqar New Member
    Milton Keynes
    I go 1.5 Toyota Prius 2009 gas padal very stiff and very havey after changing break pads and disc front and rear
    After that I clean the bodythorat and tetracycline but is still the Same problem if anyone know about this so plz reply me thanx
