P1121, P1116, Changed Coolant Valve, now Red Triangle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bryan D., May 23, 2014.
  1. Bryan D.
    Bryan D. New Member
    Hey guys,
    So I drive a 2008 and a couple months ago I started getting the Check Engine Light. Codes P1121 & P1116. Found out it was most likely related to a faulty Coolant Control Valve or Electric Water Pump. Since the pump was just recently changed I went ahead and got the valve changed.
    The light is still coming and going but now when I go on the expressway that red triangle with the exclamation pops on with a little beep. Only pops on for a couple seconds and keeps coming back until I drive a bit slower.
    Any idea what might be going on and how it might relate to the Coolant codes? I've read about draining the coolant fluid and about topping it off. Coolant looks full and I don't hear any air bubbles.
    Let me know what you think before I spend another fortune trying to figure it out at the mechanic!!
    Thanks!
    Bryan
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    That's not a check engine light that's the Master Warning Light. I wouldn't drive the car far until you pull the codes. The car ain't kidding when it throws that one.
    How did you change the valve? Did you duckbill off the hoses or drain the entire coolant?
    Where does the coolant look full? Overflow or rad? The overflow is meaningless you must take the plastic cover off and open the rad cap to check the real coolant level.
    If you drained the entire coolant it is very difficult to bleed the air. I'm pretty good at it and have a ulift and still struggled when I did mine. The trick is to power cycle on the CHRS thermos as you bleed as air tends to get trapped in the thermos and at the top of the engine. Patrick Wong had a cool get around by pulling the CHRS relay and paper clip jump out the relay 12 volts acorss it to force the thermos to cycle a few times. I missed that on my bleed and it made a bleed difficult.
    This car is weird about engine overheat also. Sometimes it throws the master light but no one every reports the true overheat icon which is the thermometer in red.
  4. TampaPrius.com
    TampaPrius.com Active Member
    461
    296
    Tampa, Florida
    This is a great tool for burping the coolant:
    Thanks to Patrick I ordered one of these and it is a huge time saver and coolant saver. It attaches directly to the radiator and holds about 2 pints so you can squeeze the coolant hoses and burp out the air. You can also jump the coolant pump relay and run the coolant pump.
  5. Bryan D.
    Bryan D. New Member
    Thanks for all the help guys. Well I went to a Toyota specialist and had the coolant fluid bled and refilled with Toyota coolant. Hopefully that solves that problem for the moment. Surely enough now the mechanic says I have a leaky engine water pump. Another few hundred to fix. Not sure how a seemingly small problem just keeps unearthing new things to replace..
  6. TampaPrius.com
    461
    296
    Tampa, Florida
    Most water pumps seep a small amount through the weep hole. Verify that it is actually leaking. This may be something that can be put off for a while. Keep an eye on the overflow tank and see if you are losing coolant. It may be hard to tell because depending on how well they bled your cooling system it may still burp a few air bubbles over the next week or so.
  7. Bryan D.
    Bryan D. New Member
    Great, I appreciate that info. I'll check that leak myself today. Hopefully it's a small one.
