Prius Eco 58 MPG vs Prius 54 MPG - What's the difference?
Discussion in 'Gen 4 Prius Fuel Economy' started by cyclopathic, Nov 18, 2015.
  1. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Bob,
    Have the coast down numbers been posted yet? Where do I find them for previous generations?
    Merged
    One of the things that I noticed while looking at the Fueleconomy.gov raw data was that two 2016 Prius were tested. One was listed as Prius, the other as Prius Eco. But if you look further into the details, the battery type for each was listed. For Prius Eco, Li-Ion was listed. For Prius, NiMH was listed. The takeaway from that is that the Prius Two was the other one tested because only the Two has NiMH. So the 54/50/52 rating is for the Two and the 58/53/56 is for the Two Eco. The touring models I would expect would be lower than 54/50/52 due to the 17" tires.
  2. bwilson4web
    16,114
    Google "test car database epa.gov"
  3. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Interesting to note that the test weight for the Prius was 3375, but only 3250 for the Prius Eco. The EPA gives a 125 lb advantage to the Eco, when the base weight difference is only 65 lb.
  4. cjecpa
    cjecpa Member
    160
    58
    Wonder what the weight difference is compare to the Toyota website they have the curb weight ECO at 3010 and the Four Touring at 3080.
  5. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    So in reference to the tires that come with the Eco, are they the special ones that require more PSI or has toyota been shipping the Eco's with regular 'ol Prius tires?
    The special tires are / were a major sellin point and if they are not shipping them with those special tires well that would be disappointing..
  6. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    I am thinking that has been put to rest. Tires on the Eco are the same as on the Two.
    Need your help! Prius 4 tire information spreadsheet | Page 3 | PriusChat
  7. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    Wow, I did see something in the past saying some folks were not getting the special tires, but didn't realize they were dead in the water. I wonder why and if the Eco's will be getting them later on? Like I said major selling point and a disappointment if one was expecting such.
    So same tires as the two (are they recommending extra PSI still???) only diff is no rear wiper, lighter Lithium batt, some solar resistant windshield (maybe?) and...
    I am actually getting enticed by the Eco and the very impressive mpg's reported so I am trying to justify and understand. Thanks all :)
  8. Mendel Leisk
    40,940
    Don't forget no spare and (lower) uneven hatch floor. Could be plus or minus, but a factor.
    Blizzard_Persona likes this.
  9. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    Plus with the base two you save the $500 surcharge and that buys approx. 25+ tanks of gas at today's low gas rates which is anywhere from 13-20k miles of driving depending how good you can get at driving Eco! Tough choice..
    bentbow and Mendel Leisk like this.
  10. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Same tires, higher PSI in the Eco, 39/36.
  11. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    From what I've read about the "special tyres", you don't want them! The car doesn't handle well with them and they don't do well in rain. From what I've read.
    I wonder if they are not meeting the US tyre standards and that's why you aren't getting them.
  12. Tideland Prius
    16,493
    They must meet standards. Isn't the Mirage using them?
  13. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I believe when it comes to the most fuel efficient tires the most fuel efficient, at least in the U.S., is the 195x65x15 Michelin Energy Saver AS.
    65,000 mile tread life as well. On the 2nd set now with our 2010 Prius, and yes, they are more fuel efficient than factory Avid Yokohama and tread life is 65,000 or more, at least in my expeirence, with max sidewall pressure on all 4 tires @ 44 PSI, perfect even wear after over 65,000 miles on our 1st set. If there is a more fuel efficient tire available in the U.S. with 65,000 mile tread life lets hear it....
    aurelio and GaryD1 like this.
  14. tomnmeg
    tomnmeg Junior Member
    24
    Peoria, AZ
    Four Touring
    Did you guys read the question? Yeah, do the math... It's 4 mpg. ;)
  15. galownia
    galownia Previous master neon mechanic
    117
    73
    Can you describe this? Front/ rear? Love to see some pictures. Thanks!
  16. bisco
    51,502
    i didn't notice anything on the underside video.
  17. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Just drove a Two and Two Eco back to back. Identical color even. The salesman let me check the PSI before the drive, 62 degrees outside sitting all night both cars not warm.Eco was 38 and 36 in front and 38 in both rears. Two was at 38/38 across the board. Both cars had Toyo Nanoenergy 195/65/15. The only difference was the Two had the accessory body side moldings. Same route and speeds, 52.3 in Eco and 48.7 in Two.
  18. bwilson4web
    16,114
  19. bwilson4web
    16,114
    #199 bwilson4web, Mar 28, 2016
  20. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    I have had the Energy Saver on three different Pruii and have nothing but good things to say about them. With mostly highway miles it was easy to get 100k out of a set even though the UTQG is only 480. Recently I had to make a decision about tires for the 2013 v. The original Turanzas, UTQG 360 had 49k on them and were starting to hydroplane. The Energy Saver at Tire Rack was $132 each. Ouch! Then I checked the Ecopia 422+, UTQG of 600, only $75 each. I have been quite impressed withe the same tire on the Two Eco so I went for the Ecopias. So far I can say that they are noticeably better than the Turanzas. The Energy Savers may or may not be better, but with a significantly lower price point, and a higher UTQG, the Ecopias are the better value in my opinion.
    Mendel Leisk and GaryD1 like this.
