Traction control engages at high speed
Discussion in 'Gen 2 Prius Main Forum' started by polodude, Dec 13, 2014.
  1. Data Daedalus
    Data Daedalus Senior Member
    1,022
    1,182
    Wembley, London
    Thank you JeffD :). I genuinely did not know that, but it does explain why traction is so smooth and progressive over certain less than perfect surfaces. Ditto with very hard acceleration :D
  2. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    The torque limiter "JeffD" mentions is where the clutch is positioned in a manual car "attached to the flywheel" . It is of almost identical design as a clutch, but has no release mechanism.
    The clutch plate is held by just enough spring pressure to be able to transmit all the torque the engine can produce, but will slip if shock loads are transmitted to it by sudden speed or direction changes of MG1. This helps prevent mechanical failure of the transmission components. It does little or nothing to limit torque to the wheels this being done electronically by the computers controlling current supplies to the two MG's, and engine power output.
    John (Britprius)
    Data Daedalus likes this.
  3. Data Daedalus
    1,022
    1,182
    Wembley, London
    Thank you John, brilliant information. I did not know this either! The Prius II continues to amaze me with its technology 18 months after I purchased it. Impressed? Definitely!! Pleased? Absolutely :)
  4. GregP507
    GregP507 Senior Member
    3,002
    480
  5. polodude
    polodude New Member
    I am actually thinking that the struts may be going. Mechanic said the old tires were starting to get cupping wear.
  6. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    746
    Delaware
    could be you do need struts and/or an alignment, but that's not gonna affect traction control.
  7. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    That depends on how BAD it is.
    Either of those can cause the tires to "skip" if they are bad enough.
  8. Oldwolf
    Oldwolf Prius Enthusiast
    816
    106
    NC
    2016 Prius v wagon
    What is the wheel RPM deferential that will cause the TC warning light to turn on?
    #28 Oldwolf, Jan 12, 2015
  9. bigbearballs
    bigbearballs Junior Member
    57
    Austin, TX
    my prius is doing the same thing, any updates on your situation?
  10. R-P
    R-P Active Member
    804
    288
    Netherlands
    I had the same thing at 100kph (~60mph) when I changed two tyres to a slightly different size (195/65 to 205/60 iirc, 40% cheaper :eek:).
    It was fixed again when replacing the remaining 2 tyres.
    So not saying the OP's problem IS the difference in wear, but I can confirm a slight difference in circumference can cause this issue. (In my case the difference in circumference was 2% iirc plus what ever difference there was in wear, but I think the old tyres had more thread left than the new ones to begin with!!! They are still in my garage because it is a waste to toss them...)
  11. vaughnstark777
    180
    33
    Roy, WA
    2001 Prius
    I
    This happened to me after I reset my ABS/VSC System with my tech stream. Same tires as I’ve always had since I got it. It’s only as I approach 60mph, the light starts flashing and it acts as though I’m loosing power, like it would when the traction control kicks in when the front wheels start to spin? Weird.
  12. ChapmanF
    15,121
    You can use Techstream to look up the reasons for the most recent four (I think it's four) times the traction control was triggered. It will have the vehicle speed, g forces, speeds of all four wheels, etc. That will probably bring you very close to a conclusion on what's going on.
    When you say you "reset" your "ABS/VSC System" with Techstream, what did you do exactly? And was there a reason you did that?
