You should change your Transaxle Fluid early
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PPENDOR, Oct 3, 2014.
  1. PPENDOR
    PPENDOR New Member
    Fayetteville, AR
    I did a transaxle fluid change on my 06 Prius last week. ODD# 110k.\
    I was thinking the 'lifetime' magic Toyota fluid quality will ensure my safety as long as I follow the maintenance manual.
    I was keeping my confidence until last week. To do the parts inspection while draining, I saw the 'mud' like black gooey stuff was adsorbed on the permanent magnet at the end of plug nut. It was a very very very thick deposition. It costs me 2 pieces of paper towel to clean. Color of the used fluid was bad, I don't know how to describe, like rusted steel.
    I'm not a crazy driver. I never push my Prius to its limit. I never even tried to do so. Always gently drive, and that's why I thought I could trust and follow the manual.
    I'm living in south. Humid in summer, dry in Fall, and wet in winter and Spring.
    I didn't prepare camera for this little project, but I definitely will change it again in next 12 month to make sure my Prius is okay.
    after this project, there was a little bit a MPG improvement been found(from 46 to 47?). Maybe better accelerating power at low speed. (feeling couldn't be accurate)
    anyway, honestly encourage you change it early if you planed on it. So many people in this forum doing so. I believe the reason is they are doing this project by themselves, so that they really saw how the fluid condition was.
  2. Mike500
    Mike500 Senior Member
    2,593
    763
    I changed the transaxle fluid on my 2012 Prius"v" at 13,000 miles.
    The fluid was already dark.
    To my dismay, unlike the photos of the drain plug on the Gen II, the little ceramic magnet is no longer supplied.
    So, I made a plug with a rare earth neodymium magnet that has a 15 pound pull.
    I'm happy that I did it early, now.
    My transaxle fluid change and NEW custom drain and fill plugs... | PriusChat
  3. Fishcrab
    Fishcrab Member
    152
    29
    I changed my transaxle fluid when I bought it used at about 145k, previous owner had not touched it.
    The fluid was thick and dark as you described . After I changed it , I put in the World Standard ATF from Toyota. I have noticed improvements in gas mileige and just seems to drive better. I have read some old threads on here, that some of the gen 2 cars have logged on over 200 k without changing ATF fluid.
    I'm a believer in changing.
    I didn't have a choice, bought it with high mileage .
    Good luck, really wish you the best.
  4. Mr Mik
    Mr Mik Junior Member
    43
    Australia
    This is the ATF WS fluid removed from my 2008 Prius I-Tech at 120000km, compared to the leftover fresh fluid.
    Fishcrab likes this.
  5. hesty24
    hesty24 Junior Member
    San Antonio, Texas
    Thanks for the heads up! I have 130 K on my 07 and just got around to changing the ATF and all coolants. I did my own plug change, next are the front brakes, but now you got me thinking about the Transaxle fluid. If you say its nasty at 110K, man I think mine is going to be ugly, because I drive my Prius like I stole it (highway speeds), but always grandpa it in town. If mine is really nasty, I am going to do a change again in a year to see if the new fluid has loosened up the old gunk and hopefully that will be it for awhile.
  6. exstudent
    exstudent Senior Member
    2,212
    900
    Torrance, CA
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Looks like you already replaced the transaxle fluid.
