Horrible gas mileage :(
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Gun owning Prius driver, Nov 6, 2012.
  1. Gun owning Prius driver
    397
    78
    Downey, California (Los Angeles Area)
    Well I work over night security and I'm able to watch movies in my car or be on my lap top at work but I ruined my battery( didn't have the car engine on) and now that my battery is dying I noticed huge drop in gas mileage does it have something to so with dying battery?
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    It could be related. I think you learned your lesson to leave the car in READY mode. Some of the poor gas mileage from a bad battery is likely due to the car wasting energy to charge up the 12 volt. The rest seems to be from one (or more?) of the ECUs getting into a bad state. At least, that seems to be the hypothesis.
    Do you have a relatively slow charger (I think 4 amps is the limit) to charge up the battery to see if it can be revived? If not, you're going to need to replace it.
  3. Gun owning Prius driver
    397
    78
    Yea I need a yellow top, well I heard leavin it on ready with it ready to go is ok on battery but just putting it in acc mode is bad.
  4. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Yes. Leaving it on in READY is fine. Leaving it in IG-ON or ACC is bad.
    If you're going to go overnight security again and it's say 8 hours, you may as well leave it on in READY for 8 hours to see if that charges up your flat battery well enough.
    Even one of our resident repair experts has suggested READY for 8 hours (No sure where my battery is? 2006 Prius | PriusChat). I'm definitely no repair expert... not even an amateur.
  5. Gun owning Prius driver
    397
    78
    Yea it does than like a day later or if I get groceries and door is open for a few it drains real bad, I can tell the lights Are much dimmer. I wonder where I can get a good deal on a yellow top
  6. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Don't know about where for a good deal but Specializing in: dictionaries including the Collins Cobuild, Oxford English Dictionary (OED), Webster's & Random House is in So Cal. Battery at Optima DS46B24R Optima battery direct fit replacement for Prius 2004 + with Instructions.
    Another So Cal guy drove to them to pick up his Yellow Top. But... you're still going to need to keep the car in READY if you're going to run stereo, accessories or whatever for more than say 10-20 mins.
    There's a night security guard for a supermarket/mall area near me w/a Gen 3 Prius. I've seen him BLAST his stereo real loud when he's sitting in his Prius. It didn't look like he was in READY mode. It seems like he's doing it for an extended period of time (blasting when I go in the store, still blasting when I come out). If I see him do it again, I'll have a chat w/him about them. Maybe he's already learned the hard way that he's killed his 12 volt...
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,835
    Clearwater, Florida
    Advance Auto online. 15& off + $50 gift card. PU at store. Make sure its charged when pu as not big mover and may have sat on shelf. Call ahead & request charge.
    PriusGuy32 likes this.
  8. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
  9. Gun owning Prius driver
    397
    78
    R they located near so cal?
  10. Gun owning Prius driver
    397
    78
    Lol yea I have a double din monitor in my car and watching movies or doing homework is a blessing to make time go fast but I learned my lesson.
  11. cwerdna
    12,545
    2,125
    SF Bay Area, CA
  12. John H
    John H Senior Member
    2,208
    558
    F8L likes this.
  13. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I would bet that there is a pretty good chance to catch him off guard, his hearing is probably shot, and if he is in the car, even better, he will never hear you, or the bad guys!
  14. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Hasn't this been a common problem with people who have recently modified their stereos? Battery failure, poor MPG and even car not starting?
  15. Gun owning Prius driver
    397
    78
    Idk I haven't heard much but I left my car on about 8-10 hours lol with movie playing.
  16. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    In READY, IG-ON or ACC?
  17. Gun owning Prius driver
    397
    78
    I think acc, I know for sure not ready
  18. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    Deep discharging a lead-acid battery (the 12-volt in Prius) causes corrosion on the plates, consequently reducing the surface-area available for electron transfer. In other words, there's no fix available. The damage is done. Replacement is required once you start experiencing vehicle operation issues... which sounds like you're at that point now.
  19. Gun owning Prius driver
    397
    78
    Yes I see lights are dimmer and that red light sometimes when starting the Car I'm waiting for my check so I can get my battery. :(
