BACK UP CAMERA FOR 2012 PRIUS two TOUCH SCREEN- NON NAV
Discussion in 'Gen 3 Prius Accessories and Modifications' started by man2ing, Jul 4, 2012.
  1. priusbee
    priusbee Member
    125
    SF Bay Area
    Hi DumLong,
    I have problem removing the middle of the hatch panel? How did you remove the panels below the hatch windows?
    Thanks!
    Read more: http://priuschat.com/threads/back-up-camera-for-2012-prius-two-touch-screen-non-nav.111717/page-7#ixzz2GqQLB7hM
  2. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    There's 2 sanded grooves on the left and right side (get some plastic pry tools)/ Snapon has a nice one which I used..or Harbor Freight has some cheapies where you can put in and pry on the sides then on the bottom.
  3. priusbee
    priusbee Member
    125
    SF Bay Area
    Thanks! I will give that a try.
  4. priusbee
    priusbee Member
    125
    SF Bay Area
    Hi wildiin,
    I don't have a tone tester, do you mine sharing information on where the wire runs at. If you have a picture showing the location, that would be great too.
    Thanks!
  5. wildiin
    wildiin Junior Member
    OK
    No Pic. sorry. That is were the wires run to the headliner connection.
    Just run the extra wire to the drivers kick panel. Easiest place to connect the camera.
  6. Levelheadsteve
    Levelheadsteve Junior Member
    40
    I am the only one who thinks this sounds like an incredible pain in the neck to install? I am admittedly not very mechanical. I'll have to see if any local shops will install it.
  7. our1vue
    our1vue Member
    313
    58
    NY
    Levelheadsteve,
    It is mostly running wires and attaching the camera (which is designed to fit in the slot provided). It could be worse if you had to set some value in the body computer to say the camera is there. Not sure why Toyota is putting a 6V camera
    in a 12V car. A 12V camera would be nicer, but at least a 12V power source is near by to tap into.
    As for getting a shop to do it, that can be tricky. Some shops want to buy a "kit" that has all the parts and complete instructions. A shop that does custom work may be more accommodating.
  8. PriusTime
    PriusTime Junior Member
    53
  9. SLGeniii
    SLGeniii New Member
    Newbie here....Also been looking for Back Up camera...and don't want another screen in front of me for that...
    I came across this web site, and looks promising...
    Toyota Camry Factory Rear View Camera - OEM Backup Cam.
    They claim it works on GenIII Prius...Anyone have more information on this?
  10. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    For that price it should be packed together with IPA ECU :)
  11. priusbee
    priusbee Member
    125
    SF Bay Area
    $349 for a backup camera? Nah!
    The OEM from Toyota is 6V, not 3.3V.
    The previous posts that described the installation for the backup camera will work.
    There are several ways to do it, but the easiest way is use the following components:
    * 12 volt CCD camera that will fit perfectly in the camera cut out in the gen 3 hatch back.
    * 6 volt solenoid
    It does require some knowledgable with electronics and soldering iron etc.
    Knowledgeable on taking the trims off for the installation.
    I have been pretty busy, but once I have time, I will put it into a Gen 3 Prius.
  12. ray6088
    ray6088 Junior Member
    70
    You are correct! But it only works 2012 model. I'm not sure about 2013
  13. PriusTime
    53
    I don't think you understood my post. The camera I linked to (which is $20, not $349) has an integrated regulator that converts the car's 12V to a usable 3.3V for the camera. If you connected this to the stock 6V camera wiring, it would also regulate that down to 3.3V that the camera needs. This means the wiring is the same as OEM with no additional components necessary.
  14. priusbee
    priusbee Member
    125
    SF Bay Area
    Okay, got the correct link - that link is for a 12 volt and it is for $20.4o.
    I did not see anything regarding an integrated regulator in the description?
    Did you opened up the camera to see the FS1117 regulator in the camera?
    I looked up the spec sheet for FS117, according to the spec, you should be able to use the 6 or 12 volt to supply the camera power (link: http://www.ic-fortune.com/upload/Download/FS1117-DS-13_EN.pdf).
    If that is the case, no 6-volt solenoid is needed.
    If that works, then why then the description on the $12.40 camera say nothing about it?
    That is my theory, we just need some prove that it will work.
  15. PriusTime
    53
    Correct, I took apart the wiring and discovered the voltage regulator. It's located in the oval shaped "chunk" where the wiring splits into two separate connections for the power and video signals. The eBay listing just says this is a 12V camera, which is what most consumers care about because 99% of them will be connecting it to a vehicle's 12V system. If they said this is actually a 3.3V camera with a 12V regulator it would only add confusion and probably raise a bunch of unnecessary questions. To my surprise though, I discovered it's actually a 3.3V camera with the built-in regulator :)
  16. priusbee
    priusbee Member
    125
    SF Bay Area
    The next step would be to connect to the 6v supplied by the Camera video +v line, to see if that will work 100% of the time.
  17. priusbee
    priusbee Member
    125
    SF Bay Area
    If that works, then the relay will not be needed.
  18. PriusTime
    53
    And I will update when I do this. Unfortunately I destroyed the voltage regulator when I cut it out of the piece it's molded inside of. I have a new one coming, and will test it with 6V. I'd be extremely surprised if it didn't work with a 6V input.
  19. Dan4500
    Dan4500 Junior Member
    56
    2012 level 2. Just installed a camera that was a perfect fit. Bot from Ebay: seller is "carvideoauto" for $35.00. Took out the original plastic insert and snapped in the camera. Unfortunately it is a 12 volt so I will need to do the conversion circuit. Bot before the postings of the 3.3 volt camera with regulator. Is this one an exact fit? If so I would buy it and redo the install. I will need to do more study of this low voltage camera.
    Learned that replacing the plastic trim piece under the rubber strip is easier if you put masking tape under the rubber strip before replacing the trim piece; stick the tape to the underside of the rubber. Re-install the trim piece and pull the rubber over the outer ends with the masking tape. Carefully pull the tape off from each end towards the center and it pulls the rubber over the top of the trim piece. This will keep rain from running inside the trim piece and restore the original assembly.
    If the trim piece is installed over the rubber strip, rain and dirt can fall inside it and into the trunk lid holes, plus discolor the inside of the trim piece.
  20. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    The similar technique, which I learnt when windshield was not glued to the car's frame, but inserted to rubber seal. The plastic tennis string in the action:
