TSB for oil change door
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by seilerts, May 17, 2011.
  1. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    where can I buy the aftermarket covers at $38 on RockAuto.com ?
    I can't find it
  2. Former Member 68813
    3,524
    983
    US
    You need to practice googling skills.
    2011 TOYOTA PRIUS Engine Cover
    ucsmfu likes this.
  3. Former Member 68813
    3,524
    983
    US
    Actually, it's more complicated than that. I found a picture of the improved part 51410-12103 posted by Den49 in this thread: Oil Change Door - Permanent Solution | Page 2 | PriusChat
    It clearly shows the transaxle holes covered. While the part I have 51410-12104/51410-12105 (not sure which) has them uncovered. Weird!
  4. ucsmfu
    1,498
    420
    canada
    my dealership gave me this part 51410-12105 #44033
    this is the part that I need for the bottom
  5. Former Member 68813
    3,524
    983
    US
    No takers on the holes vs no holes?
    BTW, I peeled the sticker with hand written "12105" (see my pictures on page 2) and the plastic cover has this puzzling designation: "51410-12104 with Silencer"
    I'm curious what they mean by silencer.
  6. ucsmfu
    1,498
    420
    canada
    so my 51410-12105 #44033 part is most likely the 51410-1204 part ><
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    So you are the one that caused it to crash...
  8. Den49
    Den49 Member
    498
    272
    Maryland
    The odd shaped approximately 8"X9" cover you are seeing in the upper right corner of the above new engine undercover photo is one that I fabricated to cover the two openings in question. It did not come with the new engine undercover. I did it as an experiment. Those two openings allow a lot of road debris to come up into the engine compartment. The openings also seem to counteract the thermal insulating function of the undercover by letting in heat from the road in the summer and cold in the winter. It seems to be working as intended with no negative effects. If you look at those openings, you will notice that they appear to be made to accept covers.
  9. Former Member 68813
    3,524
    983
    US
    They sure do. Den49, thanks for explaining the little hole mystery. Since my new cover is labeled "with silencer" I'm thinking what we are referring as thermal insulation could be actually sound insulation. No wonder Prius' engine is barely audible, unless pushed to work hard.
    I'm going to leave the holes open, sounds like they can help with tranny cooling. I live in hot climate. I can see why people in arctic climate may want to cover them.
  10. ucsmfu
    1,498
    420
    canada
    So the 51410-12105 #44033 part is most likely the 51410-1204 part right?
    Can anyone confirm? Thnx
  11. Mendel Leisk
    41,301
    Here's a pic of the older version of the undercover, for comparison. This one is viewing the face that's towards the engine, so mirrored from above. 5D_054-007.jpg
  12. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If those black patches are sound absorbing material, that explains the "with silencer" nomenclature
  13. Former Member 68813
    3,524
    983
    US
    Do you ever search yourself?
    51410-12104 - OEM Toyota COVER ASSY, ENGINE U
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You're not very friendly are you jack?
    xs650 likes this.
  15. Former Member 68813
    3,524
    983
    US
    If you are so much friendlier, how come you left ucsmfu hanging?
  16. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Aye lad you did give em the answer he was seeking, with a side of attitude. Well done.
  17. ucsmfu
    1,498
    420
    canada
    thanks. I searched but didn't get much results. Plus different sites say different things. Great now I can go and buy the $34 part to replaced my broken one. Thanks again!
  18. Former Member 68813
    3,524
    983
    US
  19. ucsmfu
    1,498
    420
    canada
  20. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    180 bucks I dont think so
