Any way to "override" the battery charging for hill climbing?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by The Swan, Jun 21, 2013.
  1. The Swan
    The Swan New Member
    i'm new here. someone please tell me if i'm posting in the wrong place, etc. thanks.
    i just bought my first prius. a 2012 four. i find it odd that i arrive at the top of canyons or long hills with well over 50% battery. in fact, unless i'm accelerating, the battery indicates being charged all the way up the hill. would love to know if there's a way (modification or add-on) to override this behavior, and cause the battery to more or less deplete when i know what's ahead. that way i don't start my decent back down with a nearly full battery, and nowhere to store all that nice regen. i can't possibly be the first person to wonder about this, but i can't seem to find where anyone has discussed it. thanks.
  2. soloflyt
    soloflyt Junior Member
    power mode maybe?
  3. telmo744
    telmo744 HSD fanatic
    2,168
    764
    Portugal
    I do a little more EV, but only if traffic allows such a slow pace...
    Surely there is a way to override that, but the pros (about 200Wh you can regen extra?*) may not make it viable.
    In the PIP by the way, also there should be a way of depleting battery even if at highway high speeds...specially if your chg point is nearby an exit.
    * 3gen has a 1400Wh battery, tipically floating at 60%SOC, when fully depleted you may be at 45%SOC, so you could get extra 15%SOC swing.
  4. The Swan
    The Swan New Member
    i'm already in power mode all the time. (getting ready to do cproaudio's mod to make power mode the default.) doesn't seem to matter what mode i'm in.
  5. markabele
    5,084
    1,782
    Nebraska
    As an aside question, I'm always curious what the power mode guys get for fuel economy. What is your lifetime MPG?
  6. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    I use power mode all the time, always have. You can take a look at my stats on Fuelly. I'm on your friends list as "inscottsdale".
  7. macman408
    1,179
    365
    No, there's no way to do this, unfortunately. There has been talk of a terrain-aware GPS in a future generation hybrid that could do this automatically based on your navigation route, but nothing serious.
    Your best options for improving fuel economy include making sure that the battery isn't low when you start up the hill and (on slower roads) using either EV mode (at <25 mph) or the left half of the HSI bar (at <45 mph, if you can get by with fairly low power requirements) for the last 0.2 miles or so, which should be about enough to drain the battery. Assuming, of course, that the downhill on the other side is more than enough to fully charge the battery so that the engine is revving to dissipate extra energy, even without B mode turned on. If it's not, you might as well just drive it like normal, and what the car chooses to do will be pretty good for the conditions.
    The engine has more than enough power to climb a hill on its own - you really only need full horsepower when trying to accelerate on a steep hill, so it doesn't use the battery just for a hill climb.
    The Swan likes this.
  8. FrankTiger
    FrankTiger Member
    63
    118
    Madrid, Spain
    Hi The Swan [​IMG]
    If you take a look at the new thread Ihave just started, it seems impossible to arrive at the top of the hill with any other battery charge than 60%. The HSD ECU is programmed to take the battery to 60% SoC regulating the current the HSD delivers/drains from the battery when the ICE is delivering power which is the normal situation when climbing hills.
    Big hugs from Frank
  9. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    If we could hit a button to drain the battery when we felt like it Toyota would be replacing more of them. I think they have tried hard to make them last 200k miles.
  10. telmo744
    2,168
    764
    Portugal
    Your 2010 does not have an EV button? :whistle:
  11. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    Nice overall consuption. if I didn't see your fuelly history I 'd not believe. :)
  12. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Thanks. Hypermiling is an addiction that I haven't been able to break. :)
  13. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    I suspect Toyota knows best on this one. The deeper you cycle the battery and the more deep cycles you do, the shorter the life of the traction battery.
  14. The Swan
    The Swan New Member
    i've only had my prius a few weeks, but i think i'm averaging around 60 mpg. (haven't got around to resetting lifetime mpg to erase previous owner.) i like the responsiveness of power mode, but still drive like a little old granny.
  15. adamace1
    1,403
    191
    Charlotte, NC
    It does but you can't hit it going over a "canyons or long hills" to drain your battery to charge it back up going down hill. The EV button only works if Toyota says it's ok. Alot of the time it doesn't work to protect the battery.
    GG707 likes this.
