Musty smell from vent...2 months old
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by VicVinegar, Sep 11, 2013.
  1. VicVinegar
    VicVinegar Member
    264
    48
    Northern Virginia
    I did read the most recent thread on this, and while those lessons would be good if I was out of warranty, I'm about to go in for the 5k service after 2 months on the road.
    My smell is just a musty smell for about a minute when I turn the car on. Been noticing it for less than a week, but my appointment is tomorrow.
    I park inside at home and in a garage at work. It hasn't been particularly wet here recently. Judging by my mileage, you can see the car hasn't been idle too much.
    So based on age and environmental condition, I'm a bit stumped as to what could be the problem. Mold already? I had my old car for 11 years and never had this. I'm at least going to get it on the record tomorrow at the dealer. No idea what they will do about it.
  2. Former Member 68813
    3,524
    981
    US
    Turn AC off in the last mile of driving to prevent that smell.
    Gabriel Perez likes this.
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    If you leave the a/c on right up to turning off the car and do not turn it off a little before arriving at your destination it can lead to a musty smell in the vents. Happens to many people.
  4. VicVinegar
    VicVinegar Member
    264
    48
    Northern Virginia
    Even after 2 months huh? It just seems real early for it.
  5. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    I must say that I always keep the a/c on until right before I turn off the car, and have never had this problem. Knock on wood . . .
  6. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    Mine has the same problem. And I always turn off the A/C long before parking the car.
    Different car, but the same manufacturer. Toyota seems to have a problem with this. I bought the car in Feb 2013 and the smell started about a month ago. Dealer says they don't notice it. Hope you have better luck than I've had.
  7. VicVinegar
    VicVinegar Member
    264
    48
    Northern Virginia
    Well he probably won't smell it either. I only notice it after the car sits for a while. Like I did first thing this morning and heading home from work today. I'd bet if I hopped in it right now (got home ~2 hours ago) it wouldn't give you that nice blast of "damp cellar". I'll be heading to the dealership tomorrow after work, so I'll have put 40-50 miles on it by the time I get there.
  8. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I was also getting that blast of musty air first thing in the morning.
    Now I turn the AC off a few miles before the end of my trip- I just keep the outside air on till I turn the car off, it seems to work so far...
  9. TheEnglishman
    TheEnglishman Member
    180
    57
    Southeastern United States
    Like vinegar? Get an A/C duct cleaning spray.
  10. southjerseycraig
    438
    107
    Cherry Hill, NJ
    The Prius AC system is powerful enough that I am always able to switch the AC system from recirculated air to incoming air. Is the problem found just if one uses recirculated air to the very end?
  11. TheEnglishman
    180
    57
    I've experienced it in other cars when fresh air was supposedly coming in. Recirculating is great for the A/C, but I'm allergic to pollen so I sometimes HAVE to turn off recirculating. Cleaning your cabin air filter, which is easily accessible behind your glove box, may help some. ;)
  12. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
  13. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Same here. The important part is not to leave it in recirc constantly. It's not the turning off the a/c that does the trick.
    Merkey likes this.
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Dealer remedy is the same on a Gen 2 as a 3 I bet. Dealer stocks 2 spray can kit. One can has special hose attached. That can is spray microbial cleaner. You hook the hose to the ac drip hose under the car and spray the entire contents of that can back up the tube. It is foamy soapy cleaner. It fills the e-box under the dash and cleans the e-coils. Then it drips back out the hose as liquid. Result is nice smelling ac in car.
    The other can is disgusting really strong old lady perfume you spray into the air dam under the windshield while ac is on. It will really stink up your car. I do not recommend using it. Its just perfume. Dealers use it as its stinky and people notice it and think they got something for there money.
    Recommend you do this at least once a year to remove mold and keep the ac drip hose free of gunk.
    DIY Over the counter is $25 for 2 can kit.
    Dealer charges $100 OOW for kit & service.
    It helps to switch to recirc and shut ac OFF but fan on high before stop as that will dry out the box a little.
    Its the sitting with soaked coil and recirc door closed that creates mold.
    sdtundra, Merkey and phoenixgreg like this.
  15. longshot
    longshot Junior Member
    68
    Maybe was in a flood?
    SPH-L710 ? 2
  16. phoenixgreg
    1,157
    289
    66
    Phoenix
    +1 here and all good advice. Here's a picture of Kool-It which is a spray mentioned that I used on my e-box which worked great. You should have seen the junk that came out of the drain tube! You can get this on Amazon.com for just over $12.
    edthefox5 likes this.
  17. edthefox5
    10,096
    4,804
    Clearwater, Florida
    Thats the same stuff the dealer sells. $12 is great! Thanks alot for the info!
  18. Former Member 68813
    3,524
    981
    US
    Would this work?
    I used it on home AC coils once.
    $5 at HD or Lowes:
  19. edthefox5
    10,096
    4,804
    Clearwater, Florida
    For condenser not evaporator.
  20. southjerseycraig
    438
    107
    Cherry Hill, NJ
    I must remark that my family moved to Orlando, Florida, and my father bought a 1966 Chevy Biscayne with a/c. We ran it on "recirc" all the time and never had a trace of a problem. Perhaps technological advance is at fault?
