Who will be grill blocking soon?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Sep 13, 2013.
  1. Bill Collins
    Bill Collins Junior Member
    East rutherford N.J.
    2013 Prius Plug-in
    Thanks for the info..seems easy enough...i'll be trying it out
  2. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I have never blocked the grill and am not going to, temps in my winter do not justify this kind of improvisation.
    A properly designed dynamic blocker controlled by engine temp and tested in wind-tunnel for improving drag coefficient is most desirable, after all it is a win-win situation - when the blocking is needed most to protect from engine over-cooling (high speeds) - the drag is most dominant.
    This is especially true for a vehicle like the Prius which strives for efficiency. Its about time Toyota will "pick-up the glove" or maybe they did?
  3. markabele
    5,084
    1,782
    Nebraska
    You are fortunate. What do temps get to in the winter there?
  4. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Unless the temperature drops below freezing and stays there for an extended period of time, it's not cold enough to bother blocking. The benefit isn't there when all you need is a light jacket.
    Real winter is when they warn you not to lick any metal. :eek:
  5. CharlesH
    2,797
    1,164
    Roseville, CA
    Can you imagine how embarrassing it would be to have to get one's tongue unstuck from a metal pole by a fire rescue crew, with the TV news camera running?:)
  6. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    In the coastal area, where I live it is usually about 14-20C (57-68F) during day, can go high to 25C (77F) or more several days in a winter. Nights are cooler by 5-8C. Winter is relatively short.
    On the mountains it can go down to freezing 2,3 times a winter.
  7. CharlesH
    2,797
    1,164
    Roseville, CA
    Is the idea of the blocker to keep cold air out of the engine compartment? At least in prehistoric times, water was sent through the radiator under the control of a thermostatic valve, so in cold weather, the issue was the block itself getting too cold, since nothing was going through the radiator.
  8. john1701a
    12,818
    5,303
    58
    It happens every year.
    Retention of heat by any means practical.
    Blocking the grille in front has proven quite effective, as well as cheap & easy.
  9. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    lets see some pics guys....I am gonna do this finally this year, i was away alot last winter and never got around to it.
    thanks!
    Hi Burrito! likes this.
  10. john1701a
    12,818
    5,303
    58
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
  12. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    As I'm also live in SJ, I did the upper part grill block since two years ago. It rally helps keeping the water temp. a bit warmer in winter and MPG improved a bit.
  13. markabele
    5,084
    1,782
    Nebraska
    Did the bottom three this morning. Much of the top 4th slit is covered by the license plate anyway. I know there is one person against it in here, but does anyone else block the very top when it gets cold enough?
  14. bisco
    52,193
    60+ here today, i'm hoping i never have to block!:p
  15. Hi Burrito!
    Hi Burrito! Regenerative Farting
    68
    42
    Fremont, California
    Yes! Put me on the list of folks wanting to see some PiPs with the grill blocking installed.
    I won't do it, because I live in the SF Bay Area and it never freezes. But I think it's a neat idea!. And I'm always happy to hear of yet another use of foam pipe insulation (I keep sections of ½" and ¾" in my garage for all kinds of uses).
    davekro likes this.
  16. Mendel Leisk
    41,752
    The consensus is to leave at least 50% of the upper opening open, and to leave that portion of the blocking to the coldest times.
  17. john1701a
    12,818
    5,303
    58
    The key is "cold enough". For me, that means multiple daytime temperatures no higher than 10°F. Some never see anything that cold. It's routine here. So, there are understandable differences in suggestions.
    Not knowing whether or not owners actively monitor temperature is a big part of the recommendation hesitation. With the JUST DRIVE IT motto, that doesn't fit.
  18. markabele
    5,084
    1,782
    Nebraska
    I have Torque and can watch any temp gauge I need to. If I want to "push the envelope" a little bit in regards to blocking what are the gauges (and corresponding temps) I need to keep an eye on?
  19. rockerdan
    427
    83
    Wheatfield NY
    did mine a couple weeks ago....seems to help keep ICE from running more and also can run heater longer before ICE fires...
    My plate is lowered so I have less area to block...have not fallen out yet even on hwy!
  20. Hi Burrito!
    68
    42
    Fremont, California
    rockerdan, You Rock! These are just the kinds of photos I was hoping to see. Thank you.
    I live in the SF Bay Area where it never hits freezing temperatures. I'm going to hold off on this mod, but I will keep it in mind for friends who live in colder areas.
    Stay warm!
