Gen II Prius Individual Battery Module Replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by ryousideways, Apr 24, 2013.
  1. LucasElectric
    LucasElectric New Member
    24
    East Lansing, MI
    After a couple more cycles (depending on the module) all of my modules fell between 6000 and 6300 mah. Pulling them all out and staggering them to average about 6150 per "block" seems to have done the trick. The battery is back in my car and has 100 miles on it with no lights or problems. It's actually getting a few miles per gallon better than before... though it was winter and lower mpg is expected in cold temps.
    Prius_Cub and CatsAreGods like this.
  2. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    Congrats on a successful rebuild. Did you use my first or second scenario for balancing the blocks?
    Gen II Prius Individual Battery Module Replacement | Page 11 | PriusChat
    I think averaging capacity per block (not per module) is the most important aspect of rebuilding since that is how the hybrid battery computer checks the health of the overall battery pack (thus no more CELs for weak blocks). I think as long as people are careful about the cycling and do a good job on the balancing capacity, there will be alot more successful DIY hybrid battery rebuilds in the future. I think it also has alot to do with the climate your are in too (ie if you live in a hot climate the battery capacity will go down much faster than if you live in a place that has longer winters).
  3. LucasElectric
    24
    East Lansing, MI
    I'm the second owner of my prius. It started life in Florida, then the owner moved to South Carolina 20,000 miles in. I purchased the car with close to 200,000 miles and took a gamble that it would last close to another 100,000 (though it was such a good deal it was hardly a gamble). I live in michigan so needless to say our winters are horrible. According to the original owner the engine, transmission, and battery are all original. I'm surprised that my battery lasted so long living in a mostly hot climate.
  4. flxcon
    flxcon Junior Member
    los angeles
    Hi very smart way to go. Can you please tell me what kind of 55watts halogen bolb you used for battery load, I am trying to used a load tester bolb as you did to know resistance in each module.
  5. flxcon
    los angeles
    I believe that module 28 is the one closed to hv computer in gen2. Contrary to gen1, where module #1 is closed to hv computer. If I am wrong please let me know.
    strawbrad likes this.
  6. LucasElectric
    24
    East Lansing, MI
    I think this is the case. Counting from the "non computer" end of my battery it was module "16" that was bad and my code was "Battery block 8 becomes week".
  7. LucasElectric
    24
    East Lansing, MI
    I used a headlight from a 1997 silverado... Worked for me.
  8. MTL_hihy
    536
    261
    Maritimes, Canada
    What did you notice about the bad module vs good ones when loaded? Voltage drop? How much?
  9. LucasElectric
    24
    East Lansing, MI
    The voltage on good modules dropped about .2v each while the "bad" module dropped over a full volt.
  10. MTL_hihy
    536
    261
    Maritimes, Canada
    Nice to know because after cycling my modules they all seemed to be able to hold capacity well (none less than 6,100 mAh) and they were well balanced for 24 hours (see balancing pic) but when I installed the packs again I got the same "weak bank 1" error I did before so I must have missed something. I wish I knew how the banks were counted on mine so I could narrow down which 2 modules were in question, but no one seems to have figured this out yet (please post if you do). Anyway I figured there must be an issue that only shows up when loading the modules since the capacities all seemed to test fine. I'm going to pull out the packs again and load test the modules individually to see if I find any with possible issues. I'll start by creating a 65W (high beam) headlight harness with a wall switch and multimeter to read voltage drops as you have to hopefully ferret out the bad one.
    On the bright side at least I had the smarts not to put the interior back in before I verified everything was working. :D
    Attached is a pic of balancing the packs........be careful of those leads or you'll be welding. ;)
    #230 MTL_hihy, May 14, 2014
  11. usnavystgc
    3,159
    990
    Tucson, AZ
    MTL, you have 6100mah on all modules, they were balanced for 24hrs and you still got a bank 1 error??? That sounds like it might be the voltage sensing line to me. Do you have miniVCI or something else that you can read the bank 1 voltage in real time? because if everything is as you say it is, there should be no reason to get a bank 1 error.
  12. MTL_hihy
    536
    261
    Maritimes, Canada
    Yes I do have mini VCI and I'll take a few screenshots tonight so people can see what I'm talking about as I drive around. I kept good records on all the charging cycles and I will post those too just so people will have something to reference later.
    I wasn't sure if you could have good capacity on the module, but still have voltage drop too low when a load was applied.......sounds like no. I will also try loading the modules to see if that shows me anything. Another option may be to break the pack apart and shift the modules around to see if the issue follows a "bad module" or if it keeps saying there's an error on bank 1 despite the change (hence an issue with the computer or voltage sensing line). It would be nice if the battery turned out to be good after all since they aren't cheap as you all know.
    usnavystgc likes this.
  13. usnavystgc
    3,159
    990
    Tucson, AZ
    Sounds like a good plan.
  14. MTL_hihy
    536
    261
    Maritimes, Canada
    I only did 2 charge cycles on each in most cases since the packs typically went above 6100 mAh on the 2nd discharge cycle when charged to 7000 mAh at 2A current rate. Once they reached above 6100 mAh capacity, I considered them to be "good" so no further testing was done beyond that point besides a final (discharge>charge) cycle of 4500 mAh before balancing all modules together.
    Here's the test results on the packs as promised (start voltage, discharge 1st mAh, discharge 2nd mAh, discharge 3rd mAh, etc):
    Pack 1 (passenger side, 12 modules)
    10.88v, 5621, 6189
    10.85v, 5656, 6227
    10.83v, 5571, 6133
    10.81v, 5385, 6032, 6113
    10.79v, 5352, 6005, 6099
    10.81v, 5232, 5975, 6140
    10.79v, 5424, 6107
    10.79v, 5325, 6131
    10.80v, 5521, 6124
    10.81v, 5451, 6146
    10.85v, 5684, 6176
    10.86v, 5797, 6308
    Pack 2 (middle, 6 modules)
    10.87v, 5643, 6284
    10.87v, 5529, 6192
    10.85v, 5520, 6217
    10.85v, 5491, 6176
    10.85v, 5562, 6247
    10.88v, 5870, 6356
    Pack 3 (driver's side, 12 modules)
    10.88v, 5799, 6272
    10.86v, 5692, 6158
    10.85v, 5698, 6271
    10.83v, 5508, 6103
    10.82v, 5371, 6143
    10.82v, 5367, 6083, 6123
    10.81v, 5267, 6019, 6119
    10.83v, 5374, 5973, 6133
    10.84v, 5547, 6217
    10.84v, 5634, 6204
    10.86v, 5764, 6291
    10.88v, 5774, 6307
    Note: For people finding this later, these are 9.6V (8 cell, 6,500 mAh) Highlander modules so capacities are similar to the Prius, but voltages will be different
  15. ericbecky
    ericbecky Hybrid Battery Hero
    4,392
    3,261
    Madison, Wisconsin
    Good to note this!
    It'd be bad to see Prius modules up in this voltage range!!
  16. usnavystgc
    3,159
    990
    Tucson, AZ
    Yeah, with those capacities, there's no way you should have any faults. I would take a good hard look at that sensor.
  17. MTL_hihy
    536
    261
    Maritimes, Canada
    You mean the sensor wires coming off each block?
    I still haven't had a chance to load test them yet, will need to wait until this weekend to try that.
    #237 MTL_hihy, May 15, 2014
  18. usnavystgc
    3,159
    990
    Tucson, AZ
    The discharge capacity test is essentially a load test. You're showing good capacity. Yes, if those are the wires that measure/sense the voltage that's giving you an error.
  19. MTL_hihy
    536
    261
    Maritimes, Canada
    For some reason I thought the capacity and load tests were different, but hopefully when I test them I will be able to see what you are saying is true.
    Do you guys think that 65W would be enough of a load to see any issues with load testing on these batteries? Should I be using larger loads to check voltage drop?
  20. jdenenberg
    jdenenberg EE Professor
    3,940
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Your modules (8 cells in series) should have a series resistance of about 0.02 ohms. so with a 6 amp load as you specified, you will see about 0.1 volt drop in a good module. So a bad module should be detectable with your 65 watt load.
    JeffD
    abdelellah likes this.
