2011 Prius - A/C Compressor Dead
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Boyakasha, May 27, 2014.
  1. Boyakasha
    Boyakasha New Member
    So my A/C went out this weekend. It's been running fine, but one morning, it seemed warmer than usual and after about 10 minutes, it was blowing hot air. I turned the system off and took it to the dealer 2 days later. They inspected it for $110 (quoted $180, but said they didn't need coolant as it hadn't appeared to have leaked). They informed me that the compressor had seized and that it, and the drier would need to be replaced. They quoted the following:
    Compressor - $2169.10
    Receiver/Drier - $242.37
    Labor - $1377.50
    Total: $4,058.66.
    I was guessing it would be $1000-1500, but $4,000 is laughable. I told him "no chance". He immediately dropped the price to around $3600. I still declined. I took requested a quote from the other dealer in town, using the diagnosis of a failed compressor. They quoted the following:
    Compressor - $1917.94
    Drier - $134.21
    Coolant (if needed) - 44.40
    Labor $400-500
    Total: $2700 (est).
    They also mentioned after-market/refurbished parts. They said that they typically won't recommend them unless I'm planning on selling the car immediately. They said that refurbs still tend to have issues and that the hassle ends up costing you more than the new/factory parts.
    Sorry for the length, but here are my questions:
    1. Have any of you used refurbished A/C parts and how did they work out for you?
    2. How reasonable do you feel that the $2700 quote is?
    Thanks.
  2. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Someone that knows what they are doing could probably get one for a lot less from a wrecking yard. Underline "knows what they are doing".
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Where are you located? I'm guessing you're out of warranty now, right?
  4. Boyakasha
    Yes, I'm a high mileage driver, so I'm out of extended warranty already. I'm in South Florida. It's very hot here so my A/C runs most of the year.
  5. FrankB
    FrankB Member
    117
    53
    Not that I've used this company, but they offer a new compressor for $655.
  6. bisco
    52,258
    nice find, how much is the accumulator/dryer or install kit?
  7. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    I've used refurbished units on other cars and your first dealer is right...they don't hold up. Get an OEM replacement. Some of the charges that seem extreme are because depending on the type of failure, you might have to also replace evap and/or the condenser coils too. That is, if the compressor failure caused an explosion into those coils. Sometimes the coils can be cleaned out - sometimes not. If contamination reaches your new compressor, it won't be long for this world. But to your concern, get a few quotes.
  8. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I would shy away from refurb too, but maybe new aftermarket?
    My CRV's compressor failed after 4 years (part of a class action suit because many others had the same problem) and we replaced it with a brand new aftermarket compressor/dryer for under $350 in parts (labor was free from bro in-laws shop). That aftermarket compressor has been perfect for 7 years now...
  9. FrankB
    FrankB Member
    117
    53
    $35
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Did you buy the car used?
  11. Lore56
    Lore56 New Member
  12. Lore56
    Lore56 New Member
    I just had this happen on my 2012 Prius while traveling in Wyoming. The dealer I found (a 2.5 hr drive) quoted $1000-$2000, for ac compressor and other parts if metal fragments went in system. Not happy as this is at 45000 miles.
  13. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Start a new fresh post and you may get more help than hijacking an existing post. We would like to see the diagnostic codes the car threw (dashboard check engine lights log a Diagnostic Test Code the dealer has them) so we can see exactly what is wrong.
    Very rare incident. If metal fragments in system that implies catastrophic failure which at first glance tells me there was some damage to the front condenser. Is the car used?Is the car a salvage title? And lastly is the car missing the bottom plastic cover that prevents road debris from bouncing up and striking the front condenser. The front condenser is in front of the radiator and exposed behind the grill. If you look through the grill the metal box you see is the AC condenser. There have been some reports of rocks getting through the nose grill itself and striking the condenser puncturing it and then the freon leaks out and totals the compressor.
    Your not to far out of the 3-36K mile warranty mileage wise. You may contact Toyota for some good will participation on the total cost of the repair. That happens quite frequently.
  14. phoenixgreg
    1,157
    295
    66
    Phoenix
    And if it was a punctured condenser coil, consider this mod. I've been very happy with the protection it has provided so far:
    Rebound, edthefox5 and bisco like this.
  15. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Actually I thought about your thread but couldn't remember your name as you had a similar experience iirc.
    Excellent work. Looks incredible like there's a turbo in there.
    phoenixgreg likes this.
  16. phoenixgreg
    1,157
    295
    66
    Phoenix
    Thanks edthefox5 - here's my original thread on the mod:
    Grillcraft installation - protection from stones | PriusChat
  17. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Thanks for the site. Alas no G2. I would buy it if it did. Huge improvement on the looks. Highly recommend for G3.
    Does not take much of a rock at 70mph's to ding the condenser.
  18. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    OP, did you hear a noise from your compressor before it went out? I'm hearing a noise and just curious if in hindsight you heard any warning signs.
  19. LoreoS
    LoreoS New Member
    My 2011 Prius just did same thing. They reccomend replacing compressor & condensor w/ parts & labor $3600! Ridiculous! I wonder if I need to get the dryer replaced too? They didn't say anything about it!
  20. bisco
    52,258
    are you in a cool climate?
