Battery Module/Block Identification
Discussion in 'Gen 2 Prius Technical Discussion' started by chevsen, Oct 9, 2014.
  1. chevsen
    chevsen New Member
    SoCal
    Can someone tell me definitively how Toyota's nomenclature of "blocks" physically equate to the 28 module positions on the HV battery? I know there are many posts that state/debate sequential numbering starting at either the ECU end or the other, but this is not how the series circuitry is devised. It looks to me that the end modules are wired as a block and then every "pair" of modules in between forms a block. Given that the series voltage output is somewhere around module 7 or 8 (I do not have the battery in front of me at the moment to verify) if numbering sequentially from the ECU side , I have no logical idea as to how Toyota identifies the 14 blocks. I ask this because I am getting a P3024 code (block 14 weak) after replacing 8 of my modules about 1500 miles ago (discharge capacities determined, weak modules replaced, voltage "balanced", all modules load tested and configured accordingly across the pack, etc.). Incidentally, I pulled the pack out last night but the resting voltages provided no clue as to a weak module, hopefully a load test will reveal the individual. It will be comforting if my load test results and the answer to my question posed above coincide.
    I fear that many of the original 20 modules that I retained (they showed 4000 - 5100 mAh on a 2.0 amp discharge to 5v) are just too marginal for the 8 stronger replacement modules (avg. approximately 5700 mAh) to avoid throwing codes. I built blocks as best as I could based on load test voltage drop results, but there may just be too much variation in the pack. I have preemptively ordered an additional 6 modules (that are hopefully closer to the capacities of the other 8 replacement modules) in order to have a total of 14 relatively "strong" modules to minimize variation across the blocks.
    BTW, I am beyond grateful to all of the contributors on this forum who have provided invaluable information as to the process and pitfalls of module replacement. Could not have dreamed of doing this without this resource.
    #1 chevsen, Oct 9, 2014
  2. CARspec
    CARspec Junior Member
    53
    Eden Prairie, MN
    2014 Prius Plug-in
    A block is two modules. The car has 28 modules and 14 blocks. The way the modules are lined up in series means every other cell is the start of a new block (and where the battery control module sensing circuit is hooked up). #1 is closest to the battery module, 14 the farthest. All of the modules are in series. Count every other module until you reach the failed unit you saw on the data list.
    A load test will bring out the failed cell for sure. Sometimes even the DLC snapshop data for a P0A8o won't show enough variance to condemn the cells unless you load it down and watch the voltages manually.
    I commend you for rebuilding your pack, and attempting it again. Have you considered the long term savings of getting all-new factory new cells and self-installing instead of doing this every so often? I'm a fan of the longterm repair, although I really respect the DIY type. I'm of the opinion that module replacement is a great short term fix but I don't recommend it as a long term solution.
    #2 CARspec, Oct 9, 2014
    chronon likes this.
  3. RayW
    RayW New Member
    Eurkea, CA
    This is something of a follow up question to the above.
    I'm using EngineLink on my phone, and am just becoming familiar with it. I had assumed that the voltage coming off of a block would be in the 14v range, but am getting logs that return an average of around 44v.
    What am I not understanding?
    Thanks much,
    Ray~
  4. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    This is the first Prius specific use of that particular software I have seen, so perhaps it is a new one for the community to know about. There are plenty of cases of various Brand X readers giving false data, so I might question the software maker about it. You should see the ~14V range that Techstream reports for block (module pair) voltage.
  5. RayW
    RayW New Member
    Eurkea, CA
    Using the ieGeek WIFI Wireless OBD2 module, and after much fiddling, retrying, etc., I have sent an email to K Solutions, with a log file, so will wait to see, and report back.
    Thanks much
    Ray~
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I am using Engine Link on my Gen III and have the correct voltage for battery modules. I have seen several Gen II users with no problem.
    K Solutions is very responsive so should be able to tell quickly with the log file.
  7. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    Load testing should show you which modules are not performing up to par but block 14 should be the module pair on the far end of the pack furthest from the ECU (see pic).
    rbdigital likes this.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I know this is an old post, but when I linked it in another thread as to how to know which block is which, at least two people said that it is the opposite. They said that block 14 is closest to the ECU. See post #37 & #40 here. Red Triangle of Death | Page 2 | PriusChat
  9. MTL_hihy
    536
    261
    Maritimes, Canada
    If you have any question on which is the bad module you can just check the voltage and run a load test to identify which aren't performing properly.
  10. Mendel Leisk
    41,888
    Seems strange, that something so crucial should be so poorly identified.
    Jo-Jo Joseph Mims and Rodger C. like this.
  11. dolj
    dolj Senior Member
    8,553
    4,344
    Wellington, New Zealand
    The problem it is not consistent across generations of Prius–in some it is one way and in others it is the other way. As I have a Gen II, I just remember which way it is for a Gen II. I couldn't tell you what is is for other generations, I just know it is not all the same.
  12. Mendel Leisk
    41,888
    Yeah couldn't they have some sort of strap that runs over top, with clear labels. It puts me in mind of a Honda valve clearance instruction, with a totally messed up diagram indicating which end was cylinder #1 vs #4.
  13. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    On the 1st gen, block 1 is next to the ecu (driver side). However, in the 2nd gen block 1 is away from the ecu (passenger side). Again, just measure voltage at rest and under a load and you'll see which ones are weak or faulty.
  14. johnjohnchu
    johnjohnchu Active Member
    212
    105
    just want to make everything super clear at a glance
    #14 johnjohnchu, Apr 20, 2017
  15. Mendel Leisk
    41,888
  16. jerrymildred
    11,517
    14,157
    Tampa, FL
    Thanks, @johnjohnchu. That is super clear. (y) I know this is a Gen 2 forum, but it would be nice to specify that so people can be sure it's the right one for their car.
  17. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Another quick identifier....gen 1 has 38 modules and rubber vent tubes, gen 2 has 28 modules and the rubber vent tubes...gen 3 does not have the vent tubes(at least on the batteries I've disassembled)
    kdfchannel, MTL_hihy and Mendel Leisk like this.
  18. Old Wrench It
    Old Wrench It Member
    58
    51
    My 2010, gen 3 has the vent tubes, think they stopped a couple years later
    ic2embedded likes this.
  19. Hybrid Battery Exchange
    70
    Gresham, OR
    Vent tubes were being removed sometime in 2011 and all gone by 2012.
    Battery blocks are counted from the module which you attach the negative lead, voltage grows with each block. Voltage at block 1 will be ~16 volts, voltage at block 14 will be ~224 volts.
    Gen 2 and gen 3 are the opposite. Gen 2 uses a long negative lead and a short positive lead, gen 3 uses a short negative lead and a long positive lead.
    If you're working on a Camry or Lexus battery and are confused which block is which just follow the negative lead to block 1.
    #19 Hybrid Battery Exchange, Apr 10, 2018
    Old Wrench It and Mendel Leisk like this.
  20. myron/priuschat
    myron/priuschat New Member
    louisville ky
    this should be "stickier" to the top
    MrRedBeard likes this.
