My transaxle fluid change and NEW custom drain and fill plugs...
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Mike500, Sep 8, 2014.
  1. Mike500
    Mike500 Senior Member
    2,593
    767
    The ECU -inverter loop contains coolant that dissipates heat from the transaxle.
    The transaxle fill plug does not need a magnet.
    The drain plug is the one that needs a magnet. It takes all of the steel and iron particles worn off of the gears and other metal parts of he transaxle. Otherwise, these friction particles circulate with the transaxle fluid and increase wear in the gears and other moving parts.
    Hope this 'splains it.
  2. xliderider
    xliderider Senior Member
    8,089
    3,239
    Honolulu, HI
    Delete. Didn't see later post. :p
    SCH-I535
  3. bigirish2
    bigirish2 New Member
    Kingsburg Calif.
    2014 Prius v wagon
  4. Mr Mik
    Mr Mik Junior Member
    47
    Australia
    i-Tech
    Rude person's (and anyone who installed a magnet), have you ever found anything on the magnets?
    Did experience prove you were right to install a magnet?
    milkman44 and Mendel Leisk like this.
  5. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Look at post #473. Pictures are worth a thousand words.
    ATF fluid changes ARE Required. | Page 24 | PriusChat
    Remember Gen2 Prius came standard w/ a weak magnetic drain plug. Gen3/C/vagons, have no magnetic drain plug.
    #25 exstudent, May 29, 2015
  6. CR94
    CR94 Senior Member
    2,674
    1,158
    Northwestern S.C.
    I can't answer directly, but anyway ... I recently changed the transaxle oil at about 48K. The old stuff came out black, but when I stirred it in the drain pan with a magnet, no visible particles stuck to the magnet, and none showed up in the bottom of the drain pan when I poured the oil off. Nevertheless, just in case, I replaced the original drain plug with the Rude person's plug I'd bought in advance. I can answer your question when I change next, which could be a fairly long wait.
  7. guruboy
    guruboy New Member
    Dallas, TX
    2015 Prius c
    These magnetic plugs look nice.
  8. Tom Dowdy
    Tom Dowdy New Member
    Hi Mike, I can't find this on eBay. Do you still have these for sale? If not, is there any set you recommend?
  9. exstudent
    2,214
    905
    Torrance, CA
    Your 2012 Prius uses Goldplug's
    Transaxle (AP-05), $18.99. Comes w/ 1 crush washer.
    18mm crush washer, replacement 5pack (SW-05 SW06), $3.99
    Drain plug is bigger, must use Goldplug's 18mm crush washer. OEM Toyota transaxle drain plug is smaller w/ a smaller crush washer.
    Engine oil drain plug (AP-03), $18.99/each. Comes w/ 1 crush washer.
    12mm crush washer, replacement 5pack (SW-03), $3.99
    Same washer size as OEM engine oil drain plug washer.​
    Cheaper to buy direct from Goldplug. Gold Plug LLC – Magnetic Drain Plugs Available from Amazon, but tax & shipping.
  10. Tom Dowdy
