P0420 Check Engine Light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kswahl1, Feb 18, 2016.
  1. kswahl1
    kswahl1 Junior Member
    46
    I just typed out a long post then it got deleted when I tried to add a picture. Ugh!
    I dont have any performance issues the lack of acceleration, bad mpg's. My car has 293,000 miles on it and it uses about a quart of oil every 3,000 miles.
    Here are some graphs of my OBD2 scaner going down the high way at 60mph for approxamitly 10 seconds. I dont know what it means. Does this mean I need a new Catalytic Converter?
    Cat 1 and 2 temperatures
    File_001.png - Google Drive
    B
    oth Upstream and downstream sensor (o2) readings
    File_000.png - Google Drive
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Can't be of specific help to you other than passing this link on to you. I found this with the search function.
    Best of luck to you.
    P0420 code | PriusChat
  3. kswahl1
    46
    Thanks. I think I'm just going to get that Universal Cat and hopefully get me through inspection.
  4. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    We're in the Gen3 thread but yes for 2007 Gen2 you could have cat problem. Depending on where you live you have different options. CA you may need to bite the bullet but i'd give it a chance to clear itself and other fiddling around.
