Prius poor headlight bulbs
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Battery driven, Feb 25, 2016.
  1. Battery driven
    Battery driven Junior Member
    UK
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    probably not worth trying.
    Battery driven likes this.
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    No personal experience but from what I've read, you have the same 'light spray' that you get with HID bulbs and the lumens are less. You are better doing a retrofit like most here will recommend. But if you don't care about 'blinding' drivers, your better off with the HID and not the LED option for a cheap and easy upgrade.
  4. Battery driven
    UK
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    I did the cheap route when i first bought my car. HID bulbs and Ballasts from DDM. Lighting significantly improved but because I was using the halogen headlights with HID bulbs, I got lots of over-spill. ( not the OEM HID headlights are much better ) Honestly the retrofit is SOO worth it. Looks and functionality.
  6. Battery driven
    UK
    Thanks.
    Could you please provide link to the tread or the product for a retrofit and will check it out.
  7. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
  8. Battery driven
    UK
    Justdidit, many thanks for the links!
  9. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    :) no problem! Glad to help.
  10. Battery driven
    UK
    BTW Justdidit, your car in the avatar looks very well.
  11. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    Thanks! The Gen2 or Gen3 modding group is practically non-existent up here in Alberta. When I was living in SoCal, the Prius mod group was thriving and supportive!
  12. Battery driven
    UK
    Well GEN2 is quite old now, but I prefer it against the newer model because few reasons: better mpg, softer seats, cheaper insurance. However newer models do look better and sporty.
