DIY Transaxle Fluid Change
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by eric1234, Jul 12, 2016.
  1. eric1234
    eric1234 Active Member
    392
    201
    Hamden, CT
    Has anyone done their own Transaxle Fluid Change? Do you have pics of the drain & fill plug locations & ATF fill quantity?
    OR - is there anyone with TIS access that has downloaded the Transaxle Drain/Fill procedure that would be so inclined to post it up here?
    My prius just turned 10k miles, and I'm planning to change out the transaxle fluid sometime in the next 5k - but I'd like to be a bit more confident about the process before I proceed...
    Thanks,
    Eric
  2. h-dogg
    h-dogg Junior Member
    44
    South Bay
    I'm interested in this to for my wife's 2012 Prius v3. It has a little over 61k miles on it and was wondering when I'm suppose to change this.
    I think it is Toyota ATF WS and four quarts. Do you need a special tool for the two bolts?
  3. eric1234
    392
    201
    Hamden, CT
    There's a whole bunch of info on this in the GENIII forum. (I accidentally posted here while intending to post in the GENIV).
  4. CR94
    CR94 Senior Member
    2,751
    1,205
    Northwestern S.C.
    Yes, WS. No, no special tool is needed, just an ordinary hex key or equivalent.
  5. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Well, most people don't have a 10mm hex socket wrench in their toolbox. I know that I had to buy a set. Found a cheap Stanley set at Walmart.
  6. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Separate drain and full plugs are easier to access with the under cladding removed, which adds maybe 1/2 hour. Remember to get 2 new crush washers for reinstalling the drain and fill plugs. I found many of the plastic clip fasteners for the under cladding were missing, so had to return to dealer to buy more of those and fashion a couple new ones to make it sturdier when I re-installed it after the change. But I'm known to have a problem with OCD, so consider the source. Good luck!
  7. Mendel Leisk
    41,909
    Robert Holt likes this.
  8. mitchmarket
    mitchmarket Junior Member
    Johns Creek, GA
    Technology
    DId mine recently. Super easy. Just look up a YouTube vid to be sure you are following the steps...:)
