Grille shutter inoperative. Visit your dealer
Discussion in 'Prime Technical Discussion' started by stuyguy, Dec 23, 2017.
  1. stuyguy
    stuyguy Active Member
    170
    134
    Lakewood, CO
    2024 Prius Prime
    XSE
    Didn't know what to make of this message on the display initially. Took a look at the grille and found a 1" rock wedged in there, keeping it from opening fully. Once dislodged, all's well
    Engine code P05A0 reset with Carista
    #1 stuyguy, Dec 23, 2017
    Dael, I'mJp, sonomac and 4 others like this.
  2. Prodigyplace
    12,682
    11,832
    Central Virginia
    I am glad you found the problem.
    Dael, stuyguy and priuscatprimeguy like this.
  3. DavidA
    2,348
    1,823
    Chicago western burbs
    Good thing you didn't get a live bobcat or coyote stuck in there. A small rock is much less work to pry out.
    #3 DavidA, Dec 26, 2017
  4. bisco
    52,396
    nice that it sends a message. someone else ran their block heat cord through the shutters.:rolleyes:
    priuscatprimeguy and stuyguy like this.
  5. Mendel Leisk
    41,920
    You could probably notch one blade right where the cord comes through.
    I love my block heater: poor man's' plug in.
  6. Prodigyplace
    12,682
    11,832
    Central Virginia
    Yeah. The dealer in Alaska did that.
    Subsequently it caught fire and the source appeared to be that EBH cord.
  7. vvillovv
    vvillovv Senior Member
    4,332
    1,515
    NY
    Can you find out if the block heater has an effect on the inverter coolant?
    I'm pretty sure it was the inverter coolant temp or plane ole inverter temp that would start the ICE real fast in sub 0*C ambient temps / ole PiP
    Any kinda heat I can get in winter, I'll take!
  8. Mendel Leisk
    41,920
    Block heater is just heating engine coolant.
  9. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    It's sure good to know that it checks it's self and reports an error.
    I do not miss grill blocking.
    Prodigyplace likes this.
  10. Trollbait
    12,689
    There are other types of coolant heaters out there that splice into a coolant hose, so heating the inverter coolant is possible. They might need to be modified since you don't want the inverter coolant getting as hot as the engine coolant does; that's why they are separate.
  11. Mendel Leisk
    41,920
    Would any amount of inverter coolant heating be beneficial? I'm thinking no, not sure.
  12. Trollbait
    12,689
    Yeah, most electronics simply don't like heat, and might do better with things cold.
    Jasinswift and Mendel Leisk like this.
  13. Jasinswift
    Jasinswift New Member
    ua
    Thanks for information.WOW :)
  14. vvillovv
    4,332
    1,515
    NY
    I believe that too cold is just as hard on the lectrical as too warm. Resistance goes up as temps drop. Check ohm on multimeter leads at -5 F than heat it up to 70 F and check them again. The cheaper the leads the better for noticeable results.
    The reason I asked was that I had a real hard time with my leased 14 PIP in temps below 0 F keeping the ICE off.
    I could do it by increasing the distance driven at below 5 mph for the first mile to 2 miles. Than I also had to keep the car below 35 mph for another mile or 2. Than it would drive normally in EV for the rest of the 8 to 10 EV miles I had left.. ( YEAH, I know that was a not recommended EV mode for the PIP )
    Today I used the heat pump for the second time logging how many EV miles it used ) about an EV mile every 4 or 5 minutes.
    I also checked the grille levers and they were open. I even drove it down the driveway and checked again, they were still open.
    Anyone know the grille block close parameters?
  15. Prodigyplace
    12,682
    11,832
    Central Virginia
    I do not know what vehicle you have, since your profile says Other non-hybrid. There is a video on the Gen 4 shutters that shows that at a certain low temperature they stay partially open so they do not freeze shut.
  16. vvillovv
    4,332
    1,515
    NY
    thanks
    I'll have to check the owners man for our plus
    I just found them 2 days ago while pulling stray leaves out of the grille
    It appears that they are stuck open. I'll keep checking for a while to see if I can figure out why before I bring it in
  17. Prodigyplace
    12,682
    11,832
    Central Virginia
    On the Gen 4 there is an error on the MID when they are stuck.
  18. vvillovv
    4,332
    1,515
    NY
    Both of us have different ideas about which dash lights mean what. There sure are a lot more toys in the prime than the PIP had. I it took me several months to figure out most the PIP dash toys, along with about 10 GB of pics and videos.
    edit: so far I've not noticed a grille block dash light
    service rep didn't know about it passive grille block and neither did the mechanic he asked.
    I'll have to try to find the one or two hybrid certified mechanics on staff (fingers crossed)
    #18 vvillovv, Jan 31, 2018
  19. Prodigyplace
    12,682
    11,832
    Central Virginia
    I meant an actual message. Here is an image from the gen 4.
    from Grille shutter Inoperative | PriusChat
  20. vvillovv
    4,332
    1,515
    NY
    Is that a gen4 or prime dash? I noticed the plus has a different dash set than John1701a's advanced
    <a href="Winter driving too cold weather MPG down | PriusChat">Winter driving too cold weather MPG down</a>
    I haven't been able to find either that CHG/ECO/PWR below the 82 F (in the picture above) screen on my dash
    In John's video I linked to that space is different 0 10 20 under the 7 F ( I can't find that one either in our plus )
