HV Battery Rebuild - Success Rate
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Usman Afzal, Jan 11, 2018.
  1. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yes but none of that matters when you are limited by the inverter in the Toyota hybrid and the electric motors after it. If you have a battery pack capable of powering a small city hooked up to a Prius inverter and MG1/MG2 combo, you don't make any gains.
    And you have to account for a LOT more than just "current overload" and "discharge protection". They are NOTHING alike compared to NiMH.
    Having designed battery packs for the automobile industry including "big name players" from the US, Germany, Japan, and Korea, that is a poor assumption to make.
    fotomoto and Prodigyplace like this.
  2. Prodigyplace
    12,657
    11,827
    Central Virginia
    The Gen 4 NiMH modules have been used successfully in a Gen 2 by Todd at Tampa Hybrids. The Gen 4 cells use a higher grade of nickel, according to Toyota,
    It is currently unknown whether the Gen 4 Li-Ion modules work in the US plugin Prius that also uses Li-Ion modules.
  3. bisco
    52,351
    lion.
    Prodigyplace likes this.
  4. Prodigyplace
    12,657
    11,827
    Central Virginia
    Do you have any way if telling whether Gen 4 (or Prime) Li-Ion modules word work in a PiP? I know you have a lot of battery knowledge here.
  5. bisco
    52,351
    to answer the o/p's question, we don't track battery rebuilding reliability. anecdotally, it is pretty bad.
  6. Civiceg94
    Civiceg94 Member
    59
    44
    Nyc
    Its a 4.4 kwh li-ion battery
  7. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Hmmm. Building that, isn't just ....you've got to take into cognizant, safety precautions, and how do you incorporate those into the car?
    The whole battery car weight would ha e to be revisited.
  8. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    @2k1Toaster Hey just got around to checking this out. Best wishes for your new venture.
    Just some thoughts
    You can get unprotected 18650 type cells as an OEM but all the safety responsibility and liability is on you.
    If before you had battery trouble you cleaned up the bus bars on say a yearly basis and could replace them every few years the original packs might last decades. Once the cells have been compromised your pretty much screwed and might as well start new.
    A 3 to 6 mile drop in fast charge plug in pack for the HB would suit me just fine if it could be done with out losing hatch space. But I'm an oddball who doesn't do the "bigger is better to excess" thing.
    #28 JamesBurke, Jan 16, 2018
  9. Civiceg94
    Civiceg94 Member
    59
    44
    Nyc
    I couldnt understand what you were trying to say
  10. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    lion
    LiOn
  11. bisco
    52,351
    exaxtsley.(y)
  12. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Take a look at #30post by @fotomoto . That's what I meant
  13. Old Wrench It
    Old Wrench It Member
    58
    51
    Plug in uses lithium
