Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. Mendel Leisk
    41,865
    Looks like a very effective can.
  2. Damagio
    Damagio New Member
    Visalia, CA
    2018 Prius
    I am happy to report that I was able to do the job....or most of the job, today. I wound up not taking off the EGR cooler. I can leave that for another day but I was able to...
    1) Remove the Throttle Body and Intake Manifold and clean everything really well, including the sensor.
    2) Clean the EGR Pipe and as far up into the EGR as I could.
    3) Install a new PCV and a long line, so when I figure out where to mount the OCC I just have to cut it.
    You guys weren't kidding about the coolant. I got a face full. :-( But no harm I got it back on quick...pulled just a little too hard before clamping it.
    The result seems to be good! I notice less hesitation and more responsiveness and it didn't knock when I started it. I hope it gets cold or damp tonight because it was like 80 degrees here today.
    Thanks everyone for the help! It was easier than I expected. Nutz About Bolts video is awesome. I would like to add that I found 4 little holes at the very edge of the intake ports and ran a brush in them...really nasty stuff came out and it seemed to drain to the EGR Pipe.
    Damagio
    #802 Damagio, Mar 31, 2018
  3. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    Well.... just starting getting cold engine knock for the first time this morning. eek. :eek: Time to get on this I think! Don't want to cause any damage.
    Damagio and Bay Stater like this.
  4. Mendel Leisk
    41,865
    How many miles on it? look into EGR circuit too, check @NutzAboutBolts videos. Apologies if I'm repeating myself, can't recall what all's transpired so far. :)
  5. Bgustafson
    259
    222
    Chicago
    Nothing has transpired so far. Purchased the car with just over 100k and knew I should execute EGR, intake manifold cleaning, and OCC install ASAP. Just was waiting for it to get a bit warmer. (still snow in the forecast here)
  6. Kingsway
    Kingsway Active Member
    118
    117
    Cambridge, UK
    2014 Prius c
    Active
    Could this make a good oil separator? Google this BMW part No: 11 15 1 705 237 (I've ordered one for UK £9.99 from eBay)
    kc410 likes this.
  7. Mendel Leisk
    41,865
    I went with this:
    Moroso 85474 Universal Air/Oil Separator
    It's working fine, very well built, and has a tap on the underside, so you can incorporate drain with oil changes. It is not cheap though. :(
    Bay Stater and scona like this.
  8. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    Looks like it might separate o.k. and then you need to drain it into something. One of the good features of the can is that it contains the residue, sort of an all in one unit.
    [​IMG][/QUOTE]
  9. Kingsway
    118
    117
    Cambridge, UK
    2014 Prius c
    Active
    I'm wondering if the cyclone action would make it more efficient. It's cheap enough I think I'll give it a try.
  10. Civiceg94
    Civiceg94 Member
    59
    44
    Nyc
    A though ran into my mind. What do you people think of running two oil catch can. I made my own little homemade occ. but i still found oil in the intake manifold. Not much just some drops of oil.
    #810 Civiceg94, Apr 3, 2018
    scona likes this.
  11. Mendel Leisk
    41,865
    There was a YouTube, a guy comparison testing two different cans, he would put them in series, one in the lead, then the other, to see which "scavenged" better. I'll. see if I can find it later, pretty interesting.
    Also Morosso for one sells some pair configurations, two small cans on a bracket in series.
    Bay Stater likes this.
  12. Civiceg94
    Civiceg94 Member
    59
    44
    Nyc
    Hhmm interesting. Need to see if i could find it also
  13. scona
    scona Active Member
    225
    207
    2013 Prius v wagon
    Here is a thread with some ideas for secondary filtering with a catch can. Just for some perspective...
  14. scona
    scona Active Member
    225
    207
    2013 Prius v wagon
  15. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
  16. Mendel Leisk
    41,865
    Here's that video, Moroso vs RX Performance:
  17. Civiceg94
    Civiceg94 Member
    59
    44
    Nyc
    That was a pretty interesting video
  18. Mendel Leisk
    41,865
    Yeah he's pretty painstaking. The RX Performance definitely came out ahead in the scavenge test. I'm happy with my Moroso though, like the look/build, the mounting system, and the tap on the bottom: easy to drain when doing an oil change from below.
    The RX looks to come with a more generous amount of quality black rubber fuel hose (3/8" ID, SAE-30R7), compared to the Moroso (think I got maybe 3.5 feet?), but that was enough for my install below, and you can pick that hose up at local automotive specialty stores, for maybe $1.50 per foot.
  19. JMJCATH
    JMJCATH Member
    91
    52
    Here
    My understanding is the Elite Ex-2 can is cheaper and has the same internals as the RX.
  20. Civiceg94
    Civiceg94 Member
    59
    44
    Nyc
    I check the prices on the rxp and i wont spend that kind of money lol.
