Prius V -2012 rear brake caliper pins "seized"
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by syscon, May 8, 2018.
  1. syscon
    syscon Member
    329
    43
    Edm. Alberta
    When I took a Prius for a check-up they quoted me $740.00 CAD to replaced Mounting Bracket and Pins on rear brake caliper.
    I took a wheel off remove the first two screws and caliper cylinder, that was easy.
    But when I try to rotate the sliding ping will not rotate at all. I took a wrench (size 14) and pound it with a hammer, no luck; the upper sliding pin will not move at all. Lower I was able to rotate it a bit but upper will not move. I spray it with WD-40 still upper sliding pin will not move at all.
    It seems to me the mechanic tried move the sliding pin same way as I see some damage on the pin.
    What are my options?
    The bracket is held by two screw, so I think I need to replace the bracket and the pins.
    52,849
  3. Mendel Leisk
    42,343
    I'm just a duffer with a few pet peeves, and the main one, the 3rd gen rear brake parking mechanism, is not applicable to the v; it has a mini drum brake in the rotor.
    I would think just replace the caliper mounting bracket, pins and boots. Lube the new pins (if kosher lube is not supplied) with something like Sil-Glyde Brake Lubricant.
    Then repeat, at least every 3 years or 30K miles, whichever comes first.
    #3 Mendel Leisk, May 8, 2018
  4. bisco
    52,849
    thanks mendel, i didn't realize they were different.
  5. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Thank you for confirmation.
    That is what I was thinking. I just finished checking front and back. Front pins are OK gliding easy IN/OUT.
    Rear pins on both sides are seized :-/
    Though the brake pads after 120K Km still look like new, especially on the front.
  6. Mendel Leisk
    42,343
    Were fronts and rears serviced semi-regularly? It seems a little odd, that the front caliper pins are ok, vs seized rears.
  7. syscon
    syscon Member
    329
    43
    Edm. Alberta
    I never touched them. I don't think dealer did anything to it either. They informed me last year that the rear pins are seized and need to be replace.
    I'm looking on-line for Rear Caliper bracket for Prius V 2012 but they are not cheap about 150.00CAD/ea
    I think the part numbers are:
    Caliper Bracket (Rear Right): 47721C
    Caliper Bracket (Rear Left): 47722A
    Sliding pins: 47814
  8. syscon
    syscon Member
    329
    43
    Edm. Alberta
    I think I printed incorrect part number. It should be:
    Toyota Part No.: 47821-47080
    MOUNTING, REAR DISC BRAKE CYLINDER
    According to this web-page:
    47821-47080 - Genuine Toyota MOUNTING, REAR DISC BRAKE CYLINDER
    For: 2012 Toyota Prius V United States Of America; ZVW41L-AXXEBA
    (Canadian models have same number on the door: ZVW41L-AXXEBA
    They are listing same bracket for both left and right side, are they the same?
  9. Mendel Leisk
    42,343
    Maybe you can hone the barrels and fine emery cloth the pins? Depending on the pin condition. Didn't realize the costs!
    I guess dealership goofed off, didn't follow Toyota schedule. I get the sense they're too busy pushing injector cleanings, can't be bothered with basics.
    Yeah look in the book, should be every 30K or 3 years, per regular Prius.
  10. syscon
    syscon Member
    329
    43
    Edm. Alberta
    That "sliding ping" has some find of rubber/plastic ring on the tip inside (maybe 5mm width), I don't know what is the function of that plastic/rubber ring. If I can not rotate the pin (hitting the range with a hummer), there is no way I will be able to remove the pin after I take the bracket off.
    If I heat up the bracket, that rubber inside will melt and make the things worse. Poor design!
  11. syscon
    syscon Member
    329
    43
    Edm. Alberta
  12. ChapmanF
    19,020
  13. Mendel Leisk
    42,343
    Maybe just buy new pins, try to hone the barrels the pins go into, see how that goes.
  14. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    I recently worked on our 2012 V's rear brakes...post is here :
    Hi all, new Prius v owner | Page 3 | PriusChat
    I warn you...the pics are horrifying ( the brakes were in really poor shape ). You can see the mini-drum parking brake in all it's rusted glory. I plan on doing another post with pics after I install the new parking brake kit. For now the old parking brake components are reinstalled after being cleaned up the best I could.
    I also had a completely seized up caliper pin...the caliper socket was also rusted out. I 'reconditioned' the caliper socket with, believe it or not, WD40 soaks, and scrubbing with a plastic 'pipe cleaner' scrubber. Replaced caliper pin and it now works great.
  15. syscon
    syscon Member
    329
    43
    Edm. Alberta
    How can I hone the barrel when I can not remove the pins? The pins will not even turn.
  16. syscon
    syscon Member
    329
    43
    Edm. Alberta
    When removing caliper on all wheels I did not disconnect the 12V battery cable; but I was making sure nobody opens the door when caliper is taken out.
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    farmecologist and Mendel Leisk like this.
  18. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
  19. syscon
    syscon Member
    329
    43
    Edm. Alberta
  20. padroo
    padroo Senior Member
    2,763
    2,253
    I would make sure the pins are available and then go ahead and heat the outside of the bracket, if they are seized what do you have to loose. I'm surprised Toyota didn't use some kind of plating that would resist seizing inside the bracket.
