Strange whirring sound coming from rear offside wheel
Discussion in 'Gen 2 Prius Main Forum' started by MotorisedRollinghams, Apr 30, 2018.
  1. MotorisedRollinghams
    MotorisedRollinghams Junior Member
    17
    London, UK
    I have been the proud owner of a 2004 Toyota Prius since January. Full service history, bought from a relatively reputable dealer. This forum helped me a lot when I was dopey enough to run the battery down shortly after buying it. Today I need help with a new potential problem...
    Recently it has developed a strange whirring sound on the rear offside wheel, like a quiet "whooosh...whooosh...whooosh" while inside the car. It is slightly more noticable outside the car.
    Any ideas what might be wrong? What should I look at to diagnose this problem?
  2. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    Brake indicator rubbing on worn out rear brakes.
  3. MotorisedRollinghams
    17
    London, UK
    I've listened to videos of the brake indicator and I don't think that's the right sound. I think it might be that a the wheel bearing is worn. Does that sounds like a possibility to you?
  4. bisco
    52,098
    yes, or a bad tire. move the tires around to eliminate that possibility.
    also could just be something stuck in there, open her up and have a good look. turn the wheel to see if you hear anything. are they discs in back?
  5. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    Yup and that was my first thought. Prius are known for wheel bearing issues. After driving it for a good bit, carefully touch the center portion of that wheel and compare to the other side. It's not an expensive fix but shop around.
  6. Mendel Leisk
    41,649
    Feeling for unusually hot wheels I'd assume?
  7. fotomoto
    5,638
    3,814
    So. Texas
    Yes, the center cap portion in particular.
  8. MotorisedRollinghams
    17
    London, UK
    Sorry for the long delay but I've been on holiday. I took the car to a mechanic. He has diagnosed it as corroded brake discs. He wanted to replace all the brake discs but quoted a very high price - nearly £600.
    I am interested in car mechanics so I want to consider doing this myself. First I will get the car back and confirm his diagnosis by taking the wheels off and having a look around with a torch. Then I'll order parts and get a family member to help me do the job. My haynes manual is inside the car so I don't know what the requirements are right but based on some googling I think I'll need to replace the brake pads when I replace the brake discs. I don't have space or tools where I live (urban area) so I'll have to take it to a DIY mechanics where they lend you the space and the tools.
    Does this sound like a sane plan?
  9. Mendel Leisk
    41,649
    I'm a little skeptical, thinking it might still be the bearings. First step as you say, would be to have a look for yourself. With the wheel raised, even before removal, turning it might help pinpoint the sound. Maybe @Patrick Wong , @edthefox5, @JC91006, @ChapmanF or other savvy sages can comment.
  10. Patrick Wong
    18,210
    6,511
    If the problem is due to rusty discs, it may be possible to "sand" off the discs by getting the car up to 50 mph or so on a road with no traffic behind you, then shift to N and apply the brakes moderately, to slow the car down to a slow speed, then accelerate back up to 50 mph, shift into N, apply the brakes, etc. The point of shifting to N is to force the friction brakes to operate instead of relying mostly upon regenerative braking. A light coat of rust can be removed after applying the brakes a few times.
