If I posted this or something similar before I am sorry, I can't find it anymore. I own/drive a 201
Discussion in 'Prius c Main Forum' started by tgpii, Sep 3, 2018.
  1. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
    If I posted this or something similar before I am sorry, I can't find it anymore. I own/drive a 2012 Prius C with about 90,000 miles. I currently live near Chicago, IL. I might be relocating to Ketchikan, AK. Should the car make the trip? Any advice?
  2. fuzzy1
    10,602
    You have posted this before. The car is still relatively young, so answers shouldn't have changed much. From the fact that you are asking yet again, I'll guess that you didn't go either previous time, otherwise you'd already know well enough from personal experience.
    Road trip Chicago to Anchorage. | PriusChat
    I think I may have asked this before. If I have asked this or there are similar forums please let m | PriusChat
    So I currently live near Chicago, Illinois. I applied for a job in Fairbanks Alaska making really good money. I was w (Wainwright: rentals, condos) - (AK) - City-Data Forum
    a400ryan likes this.
  3. bisco
    52,352
    it's just broken in! make sure your maintenance is up to date and you're good to go. no worries!(y)
    ztanos and fuzzy1 like this.
  4. tgpii
    tgpii Member
    382
    63
    Thank you. I didn't go before because the job offer fell through. I am currently working on the job, I interviewed for.
  5. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    Any (old/new) car can make the trip, BUT no matter what, you should be checking tire threads/tire pressure, fluids (oil, coolent, transmission, etc) hopefully periodically and most importantly before any long trip.
    You don't need to be a mechanic or do your own maintenance to check tires or fluid levels to know the probability that your car might leave you stranded or blow a tire
    ALSO, don't think that if you keep up to date maintenance your car won't breakdown, do a quick check of all important fluids and tires before taking off on a long trip
    #5 SwhitePC, Sep 5, 2018
