Install Cruise Control on Toyota Prius 50
Discussion in 'Gen 4 Prius Audio and Electronics' started by Geryy, Jun 17, 2019.
  1. Geryy
    Geryy New Member
    Dubai
    Hi. Anybody can help with information about connecting cruise control to ECU on Prius 50?
    Need find 2 pins CCS and ECCS.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Is yours an early car without Cruise Control?
    There was a thread a while ago regarding this:
    Adding cruise control to Prius 4 | PriusChat
  3. Geryy
    Geryy New Member
    Dubai
    Thanks. But
    This answer was not exhaustive. Need information about ecu like on other cars.
  4. Elektroingenieur
    2,515
    3,281
    Three Touring
    If you’re trying to add cruise control to a car that wasn’t built with it, see these previous threads:
    Howdy Guys Cruise Control On A Prius | PriusChat
    Adding cruise switch to basic version | PriusChat
    The CCS terminal on the hybrid vehicle control ECU is F3-14. I don’t know of a terminal called ECCS; the ground connection for the cruise control switch, ECC, is from F21-2 to ground point FA, all shown in the Electronic Technical Manual from which the printout in your image “p6 (1).jpg” was taken.
    As I wrote previously, however, I don’t know if adding the switch and wiring is enough to enable cruise control on fourth-generation (ZVW5#) Prius cars, as it was on other models. If it works, please do let us know.
    I’m afraid there are very few exhaustive answers, mine included, in this forum. The people who could give such answers work for Toyota and its suppliers, and as far as I know, don’t post here.
    PtPri, bisco and alanclarkeau like this.
  5. Stanleysymak
    Stanleysymak New Member
    Hong Kong
    Anybody found 2 pins CCS & ECCS ?
  6. Pypok
    Pypok New Member
    Russia, Siberia
    Technology AWD-e
    Привет всем. Ловите решение
    Hi everybody. Catch the solution
    Three wires to pull
    from the brake pedal 5 pin, to the ECU block
    from the steering wheel connector, 1 pin to the ECU unit, 2 pins to the ground
    Tomorrow I will post a link with detailed diagrams, the newly registered does not give links to post immediately
    #6 Pypok, Aug 4, 2021
    Awais ishfaq likes this.
  7. Pypok
    Pypok New Member
    Russia, Siberia
    Technology AWD-e
    htt ps:// vvv.drive2.ru/ l/595347339485412136/
  8. Pypok
    Pypok New Member
    Russia, Siberia
    Technology AWD-e
    correct the Internet address, the forum does not allow you to post it in a normal form. There are diagrams, and photos. not difficult
  9. Awais ishfaq
    Awais ishfaq Junior Member
  10. Awais ishfaq
    pleas can you share your pictures i need to install it thanks in advance
  11. Awais ishfaq
    pleas can you upload pictures what have you did because that site can't open in my country .
