VVT Oil Filter? Poor MPG'S?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by edthefox5, Jun 4, 2010.
  1. DriverX5
    DriverX5 Junior Member
    I am also curious - I haven't yet seen mentioned what SIZE hex head is required? I received the P0011 error and figured this would be a simple way to troubleshoot the issue, but the hex bolt I am looking at seems very rounded out on the inside. This car has only ever been dealer serviced, and I can't remember them ever mentioning changing this filter, so I am wondering how it could have become so rounded out. I tried fitting an H7 in it, but it's way too loose, and H8 seemed like maybe it might fit but rotated freely when I turned it with my hands, and an H9 was way too big. Or is the hex bolt deeper than I can see and I really just need to jam one of these sizes further in?
    CSuirp likes this.
  2. CSuirp
    CSuirp Active Member
    202
    118
    US
    2014 Prius c
    Hi Driver! Yeah...I did this not long ago and posted the results on the Red Bullet forum pages. I should have posted it here too, I guess I forgot. Below is my post and picts so you don't have to go hunting for it. Hope this helps. Let me know if you have any questions.
    "Hey all. Well...as promised, i got the VVTI filter changed and just wanted to share with everyone how it went and some tips. Sorry for the delay in getting this out there to yas.
    As you probably already know....8mm hex socket works best. The shorter the better. The hex part of mine was long...so i went to the grinder and shaved that baby down...wasnt going to get this far to just be stopped by a hex head length. We take no prisoners. Lol. So...what i found most helpful when changing out the VVTI and the filter was to remove 3 things:
    1. the top right clip that holds the electrical line immediate to the right of the oil dip stick. It's attached to the air filter and thats easy to clip off. Squeeze the ends and gently pull out.
    2. The clip to the left of the dip stick, which is a little tricky. Just get a tiny flathead screwdriver to get to the bottom end of the clamp and push it up so u get the bottom released, then just get the top clamp.
    3. Remove the screw holding the oil dipstick in place. It's to the left of the stick. WD40 it a little because mine was tough. Once removed u can move the dipstick just enough to get to the VVTI and filter much easier...just done move the dipstick too much.
    The VVTI filter was not wanting to be bothered at all. Lol. Spray it with WD40 just a little, let it soak in. I used a long handled, fixed socket wrench and attached the hex to that. Then i used the back end opening of a bigger wrench to just get more leverage to pry it loose. I advise a breaker bar or rig something like i did to give u leverage. When loose, just be careful as u take the screw out b/c the filter may not be attached securely to the inside of the screw like it should be. Mine was immaculate, but i changed it and the washer anyway. The washer was stuck on the screw, so i just sharpened a small flathead and preyed it off, cleaned the inside of screw good, put new washer on, stuck new filter in the screw, then carefully got it back in its home. Reconnected everything and good to go.
    Hope that helps u guys if u wanna do this. Really rather simple...just tight spots and ya gotta go slow to avoid dropping things. Lol. (y) "
    Priusjames and SFO like this.
  3. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Raytheeagle and CSuirp like this.
  4. DriverX5
    Yes, excellent! Great writeup CSuirp!
    Thank you both!
    CSuirp likes this.
  5. CSuirp
    202
    118
    US
    2014 Prius c
    No prob Driver. Glad it helped ya! Thanks SFO too.
    SFO likes this.
  6. Chris Temple
    Chris Temple Junior Member
    San Jose
    This thread guided me down the filter replacement and I wanted to contribute my experience and thank everyone that contributed to it.
    2008 Prius - 211,000 miles - I bought this a month or so ago and I've done the following work to it:
    - Complete hybrid battery reconditioning (1 bad module replacement and then two weeks reconditioning using two 8 port RC chargers/dischargers)
    - New aftermarket cat and resonator pipe
    - New upstream and downstream O2 sensors
    - Replaced cheap aftermarket spark plugs (they were new) with the original OEM plugs
    - New MAF sensor
    - New engine air and cabin air filter
    - Cleaned the intake
    At this point in the process, I went from red triangles of death, battery codes, engine codes, 28-32 mpg at best, erratic high idling, etc. to now 45-47 mpg, car runs very well, Dr Prius app tells me the battery health is 90% + - New Condition
    However, I still felt like the engine didn't have the power it needed when I needed it. I wasn't sure because I've never owned a Prius so I went down the path of this little tiny filter replacement.
    This filter replacement really restored power to the Prius, I can definitely tell a difference which blows my mind really. Ive never even heard of such a thing before this car and I've worked on LOTS of cars in my lifetime.
    What I wanted to share was mostly around the 8mm Hex tool that is needed for removal. The previous posts talk about using a quality tool and not a Harbor Freight one. That is the most important thing to do with this process, WHICH I DID NOT DO. So the first thing that happened was it slipped when I attempted to remove it and jacked up the bolt.
    I then pulled out my e-Star / Star bit kit that I have for my BMW's and found that the T50H bit fits PERFECTLY for this bolt. In fact, I wish I would have know that before because it has much more BITE to it than the Hex.
    This is the kit
    This is what happened to the bolt
    Comparing the two bits
    Side view
    Look at how dirty / nasty this was. I bought a brand new one from Amazon for $10
    Again, thanks for everyone's input on this!
    ydpplqbd, George W, ozzy1 and 5 others like this.
  7. alfa164b
    alfa164b Junior Member
    Sonoma County California
    So this is worth doing on a gen 2 prius with 190,000k and no symtpoms?
  8. Godzilla007
    Godzilla007 Junior Member
    Phoenix
    Asking same question here. Location if yes. Thank you
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    I don't know exactly where the filter is on a G3 engine. I do not see any talk about it either `
    except this thread. The filter may have been deleted on the G3. But it does have a VVT oil control solenoid.
    And yes a clogged VVT oil filter will kill performance.
    A VVT variable valve timing engine uses a rotational adjustable intake cam that uses oil pressure to advance its timing. No oil pressure becasue the filter is clogged no timing advance as engine speeds up the engine will be a dog.
    The filter pic posted on Chris Temps post is a poorly maintained engine that uses probably was using dino oil. Very heavy sludge. Below is a picture of my engine at 150,000 miles using very high quality oil. No sludge and no oil eating as the piston rings are not clogged. I would imagine Temples car eats alot of oil also. The G2 is a very clean running engine but you have to run high quality oil.
    I also posted a pic of my throttle body that has not been cleaned in over 40,000 miles. Notice the pcv hole inlet on the side the TB not one drop of sludge. High quality oil.
    And it has the standard pool of oil in the bottom of the intake.
    Its well worth the expense of using very high quality oil in the long run.
    But if it does have a VVT filter I can tell you its hex head bolt is on very very tight. Do not use a crappy harbor freight bit on it because it will fail and round off the hex socket and then your screwed. Make sure its the exact size bit (8 mm for G2) its not a star bit its a hex head bit. You have one shot at this.
    Clean the hex hard hole out with spray carb cleaner get a Craftsman bit and going to need a breaker bar because at least on my G2 it was on there super super tight. Its got thread locker on it too.
    Its easy to find on any VVT engine its going to be next to the intake manifold and right next to or below the VVT Solenoid that's sticking out and has a black electrical plug on it.
    Btw, I just installed a Red Bullet high performance VVT valve on my G2 and it increases engine power. Many G3 users reported increase also. Mine for a G2 was $123 delivered. It works. It increases oil flow over stock which brings in timing advance much quicker. Really improves the car's drivibility.
    I wrote it up in:
    G2/technical forum.
    #69 edthefox5, Oct 31, 2020
    SFO and Aaron Vitolins like this.
  10. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    The post with the Gen3 filter location (below) doesn't offer easy access. Hoping @Mendel Leisk can update us with any new knowledge.
  11. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Looks like valve cover has to come off. Probably good idea to buy a new valve cover gasket at the dealer and an excellent time to replace the pcv valve as its screwed into the valve cover. Easy to take that valve off with the cover off the engine. of course the cops have to come off and when you do pull them off take a picture of the spark plug well see if any oil is seeping into that hole which is pretty common. the new gasket will fix that. Its like $17.
  12. ChapmanF
    18,257
    Also, be careful and observe the torque specs when removing/reinstalling the cam bearing cap.
  13. prius_newb66
    prius_newb66 Junior Member
    62
    17
    Chicago
    Hey guys I just ordered the filter 15678-21010 and metal washer 90430-14008 to do this job but I’m a bit confused by talk of an O-ring — is there an O-ring that needs replacing too? Does it come with the filter? If not, does anyone know a part #? Thanks!
  14. Priusjames
    Priusjames Member
    91
    68
    Irvine, CA
    Observation/comment: These numbers might be different by model-year?
    Toyota parts website says my 2006 uses:
    *Washer #90430-14009, which they call a ‘gasket’. (90430-14008 shows as a ‘drain plug’)
    *Filter #15678-21010
    *Plug (w 8mm hex inset) #90341-14013
    *VVT #15330-21011
    I don’t remember anybody posting these screen shots of the Toyota parts pages, so I thought I might contribute these here. Have fun! 27B70D3E-D434-4B92-B768-0E029AF75A6B.jpeg D7079F5D-AF4F-43CE-B5EF-C4115CBFB26E.jpeg CFD2DB49-6C4E-4DF0-A4F2-AACF4D816E8C.jpeg 8A0E3C0C-D18E-458E-96EC-6FEFA9991FBE.jpeg 763AA957-0E65-479A-9D99-5AEDB279D559.jpeg 84AC7876-6780-4FD4-B149-D1819A064ABA.jpeg 17863CE2-F1AA-4CA6-8196-9A90EC5FCAFA.jpeg AEDC3213-0650-4D90-B468-6ACB7EAB9C87.jpeg
    SFO likes this.
  15. luis perez
    luis perez Junior Member
    49
    17
    HELLO!
    A quick question: What oil do you use? How many miles did the car had when you changed this filter?
  16. Priusjames
    Priusjames Member
    91
    68
    Irvine, CA
    Three videos to document removing and replacing the VVT solenoid and the screen filter in a Generation 2 Prius.
    Removing filter:
    Installing filter:
    Remove and replace VVT solenoid:
    By the way, I noticed a *definite* improvement in acceleration response with the new parts. I must have needed it! Already changed both batteries with OEM, have still been chasing performance.
    priumium likes this.
  17. ChapmanF
    18,257
    The outcoming filter looked pretty good to me. What was that mileage?
  18. Priusjames
    Priusjames Member
    91
    68
    Irvine, CA
    Mileage is just short of 139,000. It does look real good, but I had the part and so replaced it.
    I wonder if the fact it wasn’t attached to the plug and just kind of floating in there means if it was being bypassed and that’s why it looked so good? There was some gritty looking residue on the open end of the filter shown in the video that concerned me a bit. Was glad I had that pick-tool, for sure!
  19. ChapmanF
    18,257
    I'm pretty sure if good oil has been used, and changed at reasonable intervals, that could stay looking that good for a long long time.
