Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. Mendel Leisk
    41,941
    You've got the can, getting a bracket, have a location, I'm lost. ;)
    Colton and Burna J like this.
  2. StarCaller
    StarCaller Senior Member
    1,280
    732
    Cedar Crest, NM, USA
  3. Burna J
    1,071
    3,340
    53
    Long Beach, CA.
    This is how I used my bracket... :ROFLMAO:
    KRE PER (Build ?)
    Colton likes this.
  4. Colton
    Colton Member
    61
    27
    Raleigh, NC
    I mean what size fittings/hoses/clamps I will need. I’m new to this, I’m cleaning everything out when I install and this will be the first time I open up an engine and do all my own work (my 2nd car, 20 y/o)
  5. Colton
    Colton Member
    61
    27
    Raleigh, NC
    The way that cleaned up, I want to do that to mine now lol
  6. Mendel Leisk
    41,941
    Ah, read through the first few pages of this thread.
    scona and Colton like this.
  7. Mendel Leisk
    41,941
    The hose I'm using is 3/8" ID fuel line SAE-30R7 (SAE-30R6 should be fine too). It's commonly available from automotive specialty stores, for 1~2 dollars a foot. Get more than you need and cut the lines generous at first, fine tune later.
    A lot have used brass Pex splices. I used hose barb style, since that was all I could find on short notice. They are a pain to pull off though, if you make any revisions, very tenacious. I would look for the Pex style splicers, or blunt the sharp edges on the barb style. Both are available at hardware stores.
    Clamps you can also get at hardware stores, just bring along hose and test fit, if you're unsure about size. You can also get kosher automotive hose clamps, though they're a little finicky, getting the right size.
    A few zip ties?
    Colton likes this.
  8. Colton
    Colton Member
    61
    27
    Raleigh, NC
    What about couplings? I’m thinking of using the idea of cutting the original PCV hose in half and doing that. Two 3/8 couplings?
  9. Mendel Leisk
    41,941
    Yeah, what I called splices. They're readily available at hardware stores. I used these:
    But these are preferable, especially if you ever want to pull the joint apart:
    Robert Holt, scona and Colton like this.
  10. Colton
    Colton Member
    61
    27
    Raleigh, NC
    Oi! Thank goodness, I purchased two of these along with two 1/2 inch ones as well just in case (before you replied). They are technically called splicers on the packaging, along with 4 ft of 1/2 inch hose and 4 ft of 3/8 inch hose along with hose clamps! Thanks for your help!! I’m installing mine this weekend!
    CR94 and Mendel Leisk like this.
  11. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    BTW, you don't need to clamp any of the connections. They're plenty tight, and aren't going anywhere -- there's no pressure on them.
    Mendel Leisk, Colton and scona like this.
  12. Colton
    Colton Member
    61
    27
    Raleigh, NC
    Considering I’ve already purchased them, it can’t hurt, right? I noticed how tight they were when I was getting it ready earlier.
    mikey_t and Mendel Leisk like this.
  13. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    If you are not concerned with visibility issues then clamp them by all means. There have been discussions about loss of warranty concerns when an obvious change has been made to the PCV system. Not using the clamps and putting the oil catch can beneath the engine as in the installation of Mendel Leisk makes the whole installation almost invisible. I am not sure if loss of warranty could be a problem in NC or not, but there have been several responses from Californians who say that it is there.
    Colton likes this.
  14. StarCaller
    1,280
    732
    it's not about the warranty, the californians have problems with the smog test, because you can't bring a catch can in line with carb (California Air Resources Board) regulations /
    so if you want to keep it installed, it pretty much has to be invisible /
    scona and Mendel Leisk like this.
  15. Mendel Leisk
    41,941
    Mine is below the intake manifold, and pretty much invisible, even though it's polished aluminum. I think if I were to paint it mat-black, and take off off (or paint) the shiny hose clamps, it would be invisible.
    Raytheeagle and scona like this.
  16. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Mount it low and put it in a tin can:).
    Very tough to discern ;).
    And if they are lazy (or you know someone), you ain’t got nothin’ to worry about(y).
  17. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Just read into your signature links and coming back to this post...
    Any updates and conclusions of this 1oz to 5 gallon TC-W3 oil testing?
    Raytheeagle and SFO like this.
  18. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    At 90k miles - not sure what more to say. It allows for smoother engine operation and small boost in MPG - especially with the winter ethanol blended fuel. I make sure to add 1 oz per 5 gal every tank. If I forget - I get reminded due to the small but noticeable engine noise and vibration.
    I have tried it on other vehicles with positive results.
    100k miles from now, if I still have the car, I'll post my oil consumption rate and let you know if I've got the original fuel pump.
    I especially recommend it for an oil burner. Maybe try it and report back?
    Pixel XL ?
    #1478 mjoo, Oct 4, 2019
  19. UngaBunga86
    UngaBunga86 Junior Member
    Just installed my OCC kit today. Took maybe 30 minutes total from start to finish. I went from underneath by removing the entire splash guard instead of removing the intake manifold to get to the pcv. I used a new OEM Toyota pcv tube, cut it in half and used 3/8 barbed splices to connect everything together instead of trying to fit 3 different sized hoses. I only used about 6ft (combined) of 3/8 fuel hose. Used the recommended Ruien OCC. Put some #1 steel wool inside the OCC for more vapor catching duty and closed it all up. Car seems to run a little smoother, but it could just be my head saying it is.
  20. pingd
    pingd Member
    97
    61
    Twin Cities, MN
    @UngaBunga86 thank you for that summary!
    I wonder though, where and what brackets you used to mount it?
