Short Journeys
Discussion in 'Gen 3 Prius Fuel Economy' started by Padraig, Oct 5, 2019.
  1. Padraig
    Padraig New Member
    Ireland
    Hi
    Have 2 small kids and need to drop them to school a lot of the days due to rain etc. I walk when I can.
    The journey is only 1.2km to the school, turn of car for a few mins drop them off and then 1.2 km home again. The journey never gets above 50 kph and little traffic.
    I know the Prius has good fuel efficiency especially in traffic etc.
    However, with the journey above, is the car even warming up enough to achieve anyway decent fuel efficiency?
  2. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    Your fuel economy will be very bad, but take comfort in knowing it is as good as almost any other gas-burning car can provide. I suppose the engine temperature probably reaches 130-140 degrees F when you arrive at the school, and that your heater is just beginning to blow warm air. When you arrive home the engine is probably close to its normal operating temperature, which you can verify by feeling plenty of good heat from the vents.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The only thing I can recommend is to combine trips. Schedule your other tasks out of the home to use the same trip, so you warm up once. You may get the best mileage if you drive the longest leg first.
  4. Padraig
    Padraig New Member
    Ireland
    Thanks for the replies.
    So these very short journeys are very bad, even for a Prius. Duly noted.
  5. Mendel Leisk
    38,313
    Block heater will help a bit. We have similar duties sometime, and one of the school's up a great #%|~!! hill.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Very short journeys are ideal for an electric car, as there is nothing to warm up. The Prime may be worth trying as your next car; it has 25 miles of electric range according to the US EPA, (40 km) but can use readily available gasoline (petrol) beyond that.
    Mendel Leisk mentions a Block Heater, you may also wish to try grill blocking in colder weather. Newer Prius have built in grill shutters that open and close as needed. Owners of older cars have to remove them by hand in warm weather.
    Here is an example, a hardware store locally should have them
    www.amazon.co.uk/Climaflex-Insulation-Length-I-D-35mm-Thickness-13mm/dp/B01BVVDJF4
    #6 JimboPalmer, Oct 5, 2019
  7. Padraig
    Padraig New Member
    Ireland
    Hi
    What is a block heater?
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    A block heater fits in a hole for it in your engine and allows warming the engine while parked.
    One member in Ireland got his from
    "toyota pentagon sheffield part no is tpz434-g0790-3z del to me was about 113 uk pounds" - UK engine block heater | PriusChat
    I found a How to for a Prius C, using a North American plug. The details will differ for the Gen 3 with a type G plug, but he was a pleasant man who showed lots of views.
    #8 JimboPalmer, Oct 5, 2019
  9. Padraig
    Padraig New Member
    Ireland
    Ah ok. Thank you regarding the block heater
  10. Mendel Leisk
    38,313
    Some info here, I happen to be having troubles with mine:
    Block heater failed | PriusChat
    The Toyota style block heater is a little different to what I'm accustomed to with Honda, which are immersed in coolant. The Toyota block heater fits in a core, outside of the coolant, and a heat-transfer lubricant is used to transmit heat. It seems that lube may dry up over time? Not sure.
    I am going to replace mine, just waiting for dealership to get more in.
  11. bisco
    49,056
    can you financially handle a 2012 plug in prius?
    Lovec1990 likes this.
  12. Padraig
    Padraig New Member
    Ireland
    Hi. Sorry for delay. No not really b
  13. bisco
    49,056
    ah, now i know why i posted this in your other thread. (sorta:cool:)
