Torque app
Discussion in 'Gen 3 Prius Technical Discussion' started by Manhal K Alrashdan, Oct 11, 2016.
  1. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    jordan
    Good evening ,
    How can I check the voltage and the status of the HV battery . I have the OBD2 module and Torque app on my android phone . 1476201905850.jpg
  2. eman08
    eman08 Active Member
    360
    192
    US
    The only software that has that capability is the ToyotaTech Stream software. You would need a Mini VCI cable. Torque is not designed specifically for Hybrid cars as it uses generic protocols primarily designed for gas convential cars to track performance. Not even a regular genetic OBDII scan tool tell you everything about the Prius if it's not dealership level one. The mini VCI is about as best you are going to get with the most detailed information about a Toyota and it's Hyrbid system since that's what Toyota dealers use that charge you to scan your car.
    Manhal K Alrashdan likes this.
  3. marlinsmobile
    marlinsmobile Active Member
    106
    131
    Sandy Springs (Atlanta), GA
  4. Redpoint5
    Redpoint5 Senior Member
    1,026
    508
    Portland, OR
  5. ImranAs'hab
    ImranAs'hab Junior Member
    JORDAN
    Dears..
    is this applicable to Prius C 2015
  6. Buphagus
    Buphagus Junior Member
    Montvale,NJ
    How to find or create Gen1 custom pids (try to figure out terrible mileage in my 2003 prius 162k miles. Has fallen fast from 45 to 32. Local shop says car is fine, they replaced 4 engine sensors, didn't help. Is only option to get a dealer diagnosis?
  7. TAPnAR
    TAPnAR Member
    37
    31
    Fayetteville, AR
    Go into the app and load the Gen 3 PIDS. you can monitor each module of the Hybrid battery.
  8. Scott Caputo
    Scott Caputo Junior Member
    37
    Los Angeles
    I have a Carista OBD2 reader and I thought it would work with Torque pro. I have an iPhone. Is this not going to work? I got Torque (couldn’t find the pro version in the App Store), and tried to synchronize to the Carista reader to no avail.
