Torque app
Discussion in 'Gen 3 Prius Technical Discussion' started by Manhal K Alrashdan, Oct 11, 2016.
  1. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    16
    jordan
    Good evening ,
    How can I check the voltage and the status of the HV battery . I have the OBD2 module and Torque app on my android phone . 1476201905850.jpg
  2. eman08
    eman08 Active Member
    360
    187
    US
    The only software that has that capability is the ToyotaTech Stream software. You would need a Mini VCI cable. Torque is not designed specifically for Hybrid cars as it uses generic protocols primarily designed for gas convential cars to track performance. Not even a regular genetic OBDII scan tool tell you everything about the Prius if it's not dealership level one. The mini VCI is about as best you are going to get with the most detailed information about a Toyota and it's Hyrbid system since that's what Toyota dealers use that charge you to scan your car.
    Manhal K Alrashdan likes this.
  3. marlinsmobile
    marlinsmobile Active Member
    103
    128
    Sandy Springs (Atlanta), GA
  4. Redpoint5
    Redpoint5 Senior Member
    1,024
    497
    Portland, OR
  5. ImranAs'hab
    ImranAs'hab Junior Member
    JORDAN
    Dears..
    is this applicable to Prius C 2015
  6. Buphagus
    Buphagus Junior Member
    Montvale,NJ
    How to find or create Gen1 custom pids (try to figure out terrible mileage in my 2003 prius 162k miles. Has fallen fast from 45 to 32. Local shop says car is fine, they replaced 4 engine sensors, didn't help. Is only option to get a dealer diagnosis?
  7. TAPnAR
    TAPnAR New Member
    Fayetteville, AR
    Go into the app and load the Gen 3 PIDS. you can monitor each module of the Hybrid battery.
Loading...
