2020 Prime XLE / burning rubber smell
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by JJWax, Jan 18, 2020.
  1. JJWax
    JJWax Junior Member
    34
    Los Angeles
    2020 Prius Prime
    Seeing if anyone has experienced a strong burning rubber smell on 2020 Prime when utilizing its self charge mode (when you long press the HV/EV button, making the car use the gas engine to charge the electric battery for pure electric driving later)?
    Brand new car, has only 350 miles on it. I took it to Culver City Toyota’s service department to have it checked out but they were quite dismissive, telling me it’s normal for a new car to have some burn-off like that. Maybe, but my spidey sense says something is off. It’s distinctly related to the self charge mode function - and I’ve bought new cars before that didn’t have burning rubber smells linger this long.
    Any advice would be much appreciated. CC Toyota claim they checked it and saw nothing wrong but their dismissive attitude and the fact they were trying to convince me that you just can’t change the backup beeping (something I’ve now done on my own with OBD2 dongle) did not inspire confidence they know what they are doing.
    Thank you!
  2. Diemaster
    Diemaster Active Member
    295
    262
    so. cal
    I noticed a burring rubber smell when i got my 2017 prime. I just dismissed it. Figured if something wasn't right, it would get caught in my 2 years of maintenance. If i saw smoke or it caught fire, I'd call the NHSB, a lawyer, then Toyota corporate in that order.
  3. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    There is a new car burn-off that comes from the exhaust system initially. Engaging Charge-Mode so early, prior to completing break-in of the vehicle, would exacerbate that situation. You're best off just waiting to see if it continues, especially at times of high demand like forced charging.
    pghyndman likes this.
  4. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    Maybe park outside until you're sure.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    The only time I noticed burning rubber smell is when I light up the tires at a stop light:p.
    But the times I've used charge mode, nothing I've noticed on our 2019 with 17k miles now;).
    So probably new car break in stuff(y).
    jerrymildred likes this.
  6. motch6
    motch6 Member
    44
    34
    UTAH
    2020 Prius Prime
    I wonder if its not really a burning rubber smell, but rather a burning Oil smell. One in which you smell when the Oil pan is now running dry because the Oil has been pulled up into the Engine... Therefore the Oil is burning off the hot Oil pan.
    Just a thought, since that is what i'm experiencing when my ICE kicks on right now (brand new 2020).
  7. MarkL
    MarkL Junior Member
    colorado
    2015 Prius v wagon
    I've noticed some burning rubber type smells over the first 1000 miles of use on my 2020 prius prime while using the heater and the engine (I only really used the engine for heat for the first 1000 miles, as most my local driving was EV only). I didn't get it checked out and just figured it was just the engine breaking in during the winter. at 4000 miles, I still occasionally smell a slight burning rubber smell, particularly at very high speeds on the highway, but I'm not entirely sure that they aren't outside smells.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    :eek: I hope it's not running dry. That would be a shame, especially on a brand new car.
    There's all sorts of stuff that needs to bake off some fumes on a new car. Especially in the exhaust system.
    motch6 likes this.
  9. motch6
    motch6 Member
    44
    34
    UTAH
    2020 Prius Prime
    I should clarify... not really "running Dry" its like when you make a climb up a hill and the Oill pools in the back of the oil pan. The pan itself is hot and therefore some oil burns off.
    I do now wonder if there is more to this burning off smell... Break in period....
  10. Tahsin Shamma
    Tahsin Shamma New Member
    Massachusetts
    2022 Prius Prime
    I have a new (under 1k miles) 2022 Prime Limited. I'm experiencing the same the same thing and came here glad to see similar reports. That tells me it's likely incidental and not a cause of concern.
  11. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    During the first 2,000 km of our 2022 PP, we had a burning oil smell when working the ICE hard. I attributed it to oil on the exhaust system. Now that we have over 3,000 km and working the ICE-even harder now that it is winter, there is no smell.
    iPhone ?
    Tahsin Shamma likes this.
  12. BiomedO1
    4,013
    2,109
    SacTown, Ca
    Welcome Tahsin; with your low mileage; it's more than likely the new rubber and plastic off-gassing/burn-off. If your still smelling it after 5k mile and you didn't just run over a skunk ;):eek: - I'd be concerned. You've got a 36 month bumper to bumper warranty and a 10 year 150K EV drive-train warranty - so if your cooking a bad wiring harness - it's covered.
  13. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    Well stated!
    iPhone ?
  14. ColoradoBoo
    ColoradoBoo Senior Member
    1,264
    870
    Monument, Colorado USA
    For you folks breaking in your vehicles, it's a common practice to change out the engine oil after around 1,000 miles to get rid of anything leftover from the manufacturing process. (I changed mine at 1,500)
  15. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    I do not believe the ICE in my PP even ran for its first 1,500 miles. So an oil charge at 5,000 makes more sense for my situation.
    iPhone ?
