What is this and how does it work? Thx
Discussion in 'Gen 2 Prius Main Forum' started by Brando714, Jun 14, 2020.
  1. Brando714
    Brando714 Member
    101
    Anaheim, CA
    Im pretty sure its to cool down the battery but if it's air being blown where does it come from and what is this part called?
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Just a tube to vent potential battery nasties, nothing to see here.
    M in KC, TMR-JWAP and Raytheeagle like this.
  3. Brando714
    Brando714 Member
    101
    Anaheim, CA
    oh ok, thanks
  4. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    I think the air goes by plastic tube. This is a rubber tube, and is attached to a plastic container, in my opinion, could be washer liquid. Can you make a closed picture with the container?
  5. Brando714
    Brando714 Member
    101
    Anaheim, CA
    I tried to follow the tube but it went under the seats or something and I put the battery pack together.
    skip to 1:11:23
  6. AzusaPrius
    AzusaPrius Senior Member
    1,875
    822
    It is a vent for the hybrid battery that comes from the hybrid fan.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,910
    Columbia, SC
    It is exactly as @SFO stated.
    The other info posted is inaccurate.
    The 28 modules inside the battery case each have a relief vent, which will open if the module experiences high internal pressure. There are 2 rubber 'hoses' inside the HV Battery that each link 14 of these vents and then are connected together on the passenger side of the battery. They're connected together by that white plastic "y" shaped tube. That white plastic tube is then connected to the black rubber hose, which passes through the floor to direct any "battery gases" to the car's exterior.
    There is no "air flow" through that tubing. Zero.
  8. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    Can you take a picture from this direction?
    I keep my opinion it is related with water not with air until further info...
      File size:
      98.2 KB
  9. dolj
    dolj Senior Member
    7,651
    3,860
    Wellington, New Zealand
    Window washer fluid (if that's what you mean) does not route through here. If routes via the RHS under the door sills then up to the hatch. Sorry, but SFO and TMR are correct.
    MickyMatter likes this.
  10. ChapmanF
    15,576
    For crying out loud.
    After the original poster asks a question and both SFO and TMR-JWAP give the correct answer, could we have a little less filling the thread with "alternative" answers that will just miseducate future readers who find it?
    It's item 28885 here.
    The battery modules are filled with potassium hydroxide. It will eat you. They should never need to vent in normal operation. If they ever do, the hose carries the stuff out of the car (you can see it goes through a grommet in the floor). The hose has to be made of stuff potassium hydroxide will not eat.
    By the way, because you are made of stuff potassium hydroxide will eat, be very careful handling that hose, or ever being under the car where the end of it sticks out.
    There should normally be nothing in it, because none of the modules should ever have needed to vent. But then, if you could count on that never happening, the hose wouldn't be needed in the first place.
    #10 ChapmanF, Jun 14, 2020
  11. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    Yes, I am possible be wrong, I am sorry to polute this topic, as our colleague
    ChapmanF says...
    But for educational reasons, please, make a picture with the plastic container where the tube is attached.
    later edit
    to be better informed, I post here the parts and locations for the battery pack.
    But I am a little confused about recognising that hose...
    #11 GabrielD, Jun 14, 2020
  12. ChapmanF
    15,576
    What "plastic container"?
    The hose is connected to two long collecting tubes (28875 and 28876 in the picture above) that run the length of the battery, fitting over the safety vent valves on the modules. There are two tubes because the modules face alternate ways (− to + and + to −), and the vent valve is nearer one end of the module, so each collecting tube fits over the valves for half the modules.
    You can see that in the diagram, right?
    The two collecting tubes join into the single rubber tube, and that does not go to any "plastic container". It exits the car through a grommet right through the floor, pointed at the road.
    That's where any of the potassium hydroxide will go if any of the modules should ever vent.
    Do you want more pictures? This forum is teeming with pictures of people's battery disassembly projects. Why not search some up?
    later edit:
    Did you find the label 28885 in the illustration in #10?
    Photo by hobbit of the collecting tubes removed from the battery:
    #12 ChapmanF, Jun 14, 2020
  13. TMR-JWAP
    6,225
    5,910
    Columbia, SC
    Here is a photo of the passenger side of the hybrid battery (one I have in the shop, where you can see the white plastic piece), and another photo showing the vent tubes with the rubber hose attached.
    Mendel Leisk and Raytheeagle like this.
  14. Brando714
    Brando714 Member
    101
    Anaheim, CA
    Oh ok thank you. Ya I figured i
    Oh oh thank you.
    #14 Brando714, Jun 14, 2020
  15. Brando714
    Brando714 Member
    101
    Anaheim, CA
    Hey so the top of my cover for the hybrid battery is a little caved in because someone probably rested their body on it while working on it to take it off and install it back on. Is this pretty crucial in circulating cool air efficiently?
  16. AzusaPrius
    1,875
    822
    Yes
  17. ChapmanF
    15,576
    That's incorrect though. It has nothing to do with the venting system that cools the battery through the fan.
    It is only an escape path for the flesh-dissolving potassium hydroxide inside the battery, if it ever needs to vent from an overpressurized module. It leads straight out of the car through a grommet in the floor.
    There is normally nothing in it, because the battery modules are not ever supposed to vent pressure in normal conditions.
    But it should always be handled carefully as if it could contain something, and as if the something it might contain could be a serious skin and eye hazard.
  18. Brando714
    Brando714 Member
    101
    Anaheim, CA
    Damn. Like how bad is a caved in cover? Would ot be ok or u would def replace it?
  19. Brando714
    Brando714 Member
    101
    Anaheim, CA
    Thanks for the clarification. At first it I thought it was stupid to ask what it was because I was for certain it was another method of cooling down the battery but now I know its so harmful byproduct from the battery can escape
  20. Mendel Leisk
    38,715
    Should be possible to just bend it back? Say lay it upside down on a carpet or exercise mat (something supportive but able to "give" locally, place a small block of 2x4 on the cave-in spots, smack with a small sledge hammer?
