Upgrading the QI charger (with pictures)
Discussion in 'Prime Accessories and Modifications' started by Patric88, Oct 28, 2020.
  1. Patric88
    Patric88 Junior Member
    34
    Chicago
    2018 Prius Prime
    So I browsed around a bit about how to change my Prius prime qi phone charger out, since the stock one won't even charge my tablet-like phone (Note10+) and when it did charge it would be slow, over heat, and turn off after 10 seconds.
    So I bought a wireless charger from Amazon, and fitted it to my car. It works so well, as good as a desktop wireless charger. I can even get samsung quick charging through this. It is 100% stock appearance but the internals are now different.
    Now everything works amazing. I can toss my phone into that cubby with an otterbox case on and the phone starts charging perfectly and does not heat up at all(not abnormally).
    In the future I'll open it back up and install a push button for power into the existing button that just sits there now.
    Click the picture for my comments/steps/walkthrough
    #1 Patric88, Oct 28, 2020
    citiprius, TGrracie and AldoON like this.
  2. Patric88
    34
    Chicago
    2018 Prius Prime
    Click on the pix to see my comments/steps
    pghyndman likes this.
  3. Salamander_King
    Salamander_King Senior Member
    11,023
    8,962
    New England
    Very cool. Yeah, the OEM Qi charger was so weak, I gave up on using it after only a month or so on my previous 2017 PP Premium. Now I have 2020 PP LE without a Qi charger, this maybe a good mod to add such functionality.
    One question, did you try splicing the power that feed the OEM Qi charger to drive your new charger? I think the power is at 12v, do you still need to reduce to USB 5v, but that would free the all the cord at the 12v outlet on the rear seat. Now, since you have the 12v outlet on the rear seat side of the console box, your car must be pre-2019 model. Starting 2020, they replaced this second 12v outlet with two USB charge ports (2.1A?).
  4. Patric88
    34
    Chicago
    2018 Prius Prime
    Yeah it's a 2019 pp premium. And by keeping the usb in the back it gives me the option to unplug the charger all together and use my usb socket for other chargers if needed. And yeah the existing harness is 5v not 12. Also the 12 cigarette lighter socket usb connector I use is a samsung fast charger which the qi charger will use. So I must use Samsung's charger or it will only wireless charge. If I have it plugged into Samsungs socket I get the exclusive super fast wireless charger.
    Hope that made sense lol.
    Now I did think about splicing my own 12v plug under the console but as you can see it was night time when I finished and was using a flash light, so I didn't have time to keep playing with it. At least it works great now.
    I did this about 2 weeks before posting this so I could see if it would have any issues and so far I use it daily for like an hour and never have had issues
    Salamander_King likes this.
  5. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    I don’t see any pictures in your post. Can u check?
    iPhone ?
  6. Elektroingenieur
    2,515
    3,287
    Three Touring
    Thanks for sharing. Have you noticed any electromagnetic compatibility issues between the new charger and the smart key system?
  7. Patric88
    34
    Chicago
    2018 Prius Prime
    None at all, if keys are in the charger slot, it all works perfectly still
    Are you using data saver or something? Try loading in desktop mode and not through safari
  8. patcoghm
    patcoghm Junior Member
    57
    The original wireless charger, is it reconnected to the plug and where did you hide it. Do you know what would happen if it was unplugged. It must do more then just wireless, maybe the usb plugs in the center console. A lot of electronics in the metal box for wireless compaired to what you installed.[/QUOTE]
  9. Elektroingenieur
    2,515
    3,287
    Three Touring
    As far as I know, the mobile wireless charger cradle assembly has no other functions. Disconnecting it is unlikely to turn on a warning light, cause a diagnostic trouble code to be stored, or cause other problems.
    The disconnected harness and connector should be properly fastened in place, of course, so they won’t rattle or interfere with the mechanical cable for the parking brake, which runs underneath the center console.
    The charger cradle assembly made by Panasonic for Toyota includes a moving coil; had to meet government and Toyota standards for safety, reliability, durability, electromagnetic compatibility, and so on; and is a design that’s now several years old.
  10. Patric88
    34
    Chicago
    2018 Prius Prime
    [/QUOTE]
    I routed my wire to the rear seats 12v outlet. The original harness is now ziptied to other words and unplugged fully. No codes, lights, or problems have occured. I still use this charger for at least an hour a day since installed. Not a single problem.
    That large charger I removed wireless charged, and the charging coils inside actually moved up and down and left and right to center itself onto your phone. It also had some processing for current and voltage and it had different operating frequencies. As stated in the owners manual by holding down the wireless charger power button for a few seconds, it will change the frequency and perhaps improve your am/fm radio signal.
  11. Silverfun
    Silverfun Junior Member
    Central Florida
    2018 Prius Prime
    Four Touring
    Thanks for this article. I will use your steps for mine as well. Great job!
  12. Darien Day
    Darien Day Member
    126
    35
    SW USA
    2022 Prius Prime
    Do you remember if there's space in there to splice one of these in (without that mounting plate it comes with) and leave it in there with a USB PD charger plugged into it?
    12V DC socket:
    USB PD charger:
    It's going to be for a MagSafe charger that will be semi-permanently mounted.
  13. PixelRogue
    488
    86
    US
    Hoping we can reboot this thread for those joining late :LOL:!
    I am getting close to upgrading the Qi in a 2021 Prime.
    This tutorial is great and I will follow most of it. The one change desired, and maybe others encountered, is the power. I'd prefer to wiretap, possibly in the same console. I'd be open to installing a plug inside the console, however would prefer to not use exposed ports (ie. 12v.) in the cabin.
    Anyone wiretap or wire the Qi other ways?
  14. The Beast1
    The Beast1 Junior Member
    France
    Go to AutoZone and buy a dual cigarette adapter splitter. It basically turns one cigarette adapter into 2.
    Take scissors and cut them so they're all separated. Using the female ends, expose the wires (positive and negative leads) and splice this to your car's 12v source. Ideally using the power source for the older charger.
    Take a USB C to 9v car adapter and test it first to make sure it has an appropriate power output to charge the Qi charger. Plug this into your cut up 9v adapter.
    Use some duct tape and the wire and adapter into the socket to make sure it never comes out.
    Before buttoning up the vehicle, turn car on and make sure your phone charges appropriately and enough to actually give it a charge. Adjust as necessary.
    Plug the other end of the USB c cable into the disassemble Qi charger innards that will be powering the replacement qi charger for the car.
    Button up the car, congrats your fudged up wireless charger has been fixed and retains the OEM look.
    Kudos to OP for the idea but I hate mods where the USB cables come out of the plastic. The above will allow you to retain the appearance of an unmodded vehicle.
  15. PixelRogue
    488
    86
    US
    Just tested out (and like) a wireless carplay adapter, which has upped the ante. Goal now:
    • Upgrade the Qi charger (hardwired behind the scenes) - keep the OEM
    • Change out the USB-As for USB-Cs.
    • Change out the cigarette lighter for USB-C. (might pull this under the QI charger if there is enough wire.)
    • What is the supported wattage for existing USB-A ports? Presume these can be changed to C w/o clunky adapters?
    Qi2 charger delivers 15watts (5w of Qi1) Qi2 25 over USB-C. Would using a buried cigarette lighter not support 15w 25w?
    • Using a cigarette lighter would then require another adapter for USB-C - would prefer to tap into sources.
    #15 PixelRogue, Jul 24, 2025
  16. PixelRogue
    488
    86
    US
    @The Beast1 - thank you for responding. would you mind rephrasing the thoughts there or elaborating further; ELI5?
    --examples of questions that surfaced--
    There are many types, most hard shell versions. Presume you were referencing this type?
    Where were you thinking...splicing into the wire that feeds the cigarette adapter in position one under armrest (left of usb-a port?)
    Take a USB C to 9v car adapter and test it first to make sure it has an appropriate power output to charge the Qi charger. Plug this into your cut up 9v adapter. (maybe this would be the first step, before purchasing a cutting up the dual cigarette adapter?)
    Theoretically we spliced into the 12volt supply, but now talking 9v car adapter? Example of a 30W adapter.
    Would you mind elaborating or rephrasing this step?
    Use some duct tape and (affix?) the wire and adapter into the socket to make sure it never comes out.
    Is this all happening under the OEM Qi charger bay, or are you up in the arm rest cubby at this point for existing cigarette lighter?
  17. PixelRogue
    488
    86
    US
    Writing, years later, to say thank you for posting. I used this as the model for the modification and added a few changes that I am documenting here for others who may be interested....and I expect this will work for current and future models.
    • The charging pad was upgraded to Qi 2 using an Anker puck from Amazon AND wireless carplay using Carkit 5.0. There was no need to crack it open either..it works out of the box and will show below. Note 2.1 is now out thought might be some time before devices utilize or chargers are available. Apx. $75.00 total to upgrade to wireless carplay and better Qi charging pad.
    • Didn't want to cut a charger apart, nor use superglue. Using the puck above allows me to change it out (or take it w/me sometimes) in the future. Wire modification was not needed.
    • The USB-C and 12volt was pulled out and pushed into the space below the cup holders. Yes, on purpose so no wire modifications were needed. I purchased a 12v cigarette adapter that has a USB-C port, USB-C wire and USB-A wire. This allows me to run a spare power charger for the passenger of if fast charging is required.
      NOTE: outstanding solution needed for adequate caps over the old port locations. No, do not need or want additional ports.
    • The shell, which looks like an internal hard drive, can be opened and after pulling out the guts you can place the power puck in place (using same duck tape method above.) Then roll some extra duck tape to fill up the gap between the puck and the enclosure. Screw the enclosure together and your charger will stay fixed to the pad above. The screw it all back together and it looks like an OEM assembly. I used duck tape around some of the opening to prevent chaffing.
    • Plug the cigarette lighter into the adapter and tape it up.
    • Plug the Carplay kit into the usb-c adapter and tape it up. Note you need to use the same USB c adapter from the console.
    • Reassemble.
      Image the guts on the white background - that is essentially all trash.
  18. PixelRogue
    488
    86
    US
    Ok. So, having a moment where after a rather successful upgrade to a nearly invisible Qi 2 (still looking for cap solutions,) it is appearing useless. The charger works - yea! But iPhones have camera bumps preventing them from sitting flat. So this 'invisible' charger isn't really cutting it because of the camera notch.
    Anyone else run into this, solve this? Would the right case get the charging reconnected. Almost seems as though the invisible charging puck needs to be visible mounted to the top of the pad and then put the phone on that.
