Installed Android/Carplay HU on Prius 2010, but sound quality is awful!
Discussion in 'Gen 3 Prius Audio and Electronics' started by Dhanish Jabbar, Aug 14, 2021.
  1. Dhanish Jabbar
    Dhanish Jabbar New Member
    Uk
    I recently installed a android px9 head unit from alibaba into my 2010 Prius T Spirit. The carplay functionality and ability to watch youtube when parked up is amazing.
    However the sound quality from the soeakers is noticeably less “punchier” than the stock toyota HU. Previously the old HU would literally rattle my rear view mirror from the bass. But this new head unit alothough it has DSP, I can seem to set the EQ right to get that same level of bass no matter what I do? Its like it is bypassing the sub.
    Am I doing something wrong? Does the headunit need a amp or something?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    I suggest that you contact the maker of your new head unit.
    Dhanish Jabbar likes this.
  3. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    From a post by PC members TroyAndEddie in 2015: Headunit upgrade with JBL | PriusChat
    Scroll UP to post #6 for a long post that may contain info pertinent to your issue. Read particularly: WHEN INSTALLING IN A JBL-EQUIPPED CAR: (read all the steps in that segment).
  4. prius2010II
    prius2010II Member
    269
    us
    You need a canbus adapter if your car.has JBL.amp. There are at least 2 different wiring harness.. Take a picure of the back of your factory radio or factory harness. Email to your dealer.
    There should be a menu setting to turn on factory amp.
  5. Evoking
    Evoking Junior Member
    91
    Pomona
    I have an android head unit and the factory jbl system and I absolutely love the sound.
  6. JamiFids
    JamiFids New Member
    Four Touring
    If you installed the Android device separately from the stereo system, it is possible through the incompatibility of the devices. Try to buy the original.
  7. Robolord
    Robolord Junior Member
    Oregon
    For future readers: Joying (and probably most Chinese Android HUs) have extremely low-voltage output on the RCAs. It will never sound as good as you’re expecting with the factory amp. You will need to replace the amp with one that accepts high/speaker-level inputs or get a “line driver” like the AudioControl LC1i to get enough juice to the factory amp.
    I spent way more time and money than is reasonable to learn this lesson. Please don’t make the same mistake.
  8. tamo3
    tamo3 Junior Member
    CA, USA
    @Robolord
    I got joying head uint too. I notice it's lower power volume.
    How do you hook up AudioControl LC1i?
    Joying Android Head unit - LC1i - Speaker harness?
    Do I need to purchase different amp too?
  9. A.J
    A.J Junior Member
    59
    Worldwide
    May i ask what version of CAN Bus you use?
