2022 Prime Door Handle Illuminated Buttons
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by eow, Dec 16, 2021.
  1. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    Are the door lock buttons on the driver’s door handle to be illuminated like they are on the passenger door handle?
    My Driver’s door handle:
    iPhone ?
  2. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    No it's not supposed to be all illuminated. There isn't anything wrong with your switches. Toyota took those lights out for whatever reason.
  3. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    Thanks for the insight.
    iPhone ?
  4. Tideland Prius
    16,504
    Yeah they used to be on 2017-2019 models.
  5. bisco
    51,540
    classic decontenting
  6. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    Here's the difference between the years.
  7. BiomedO1
    3,156
    1,669
    SacTown, Ca
    You can also accidentally turn-off those lights by cranking the dimmer switch all the way down. Only your dashboard and radio will be lit, all other switch lamps will be off - including your PARK button. You need to go one up on the dimmer switch to get the lights back.
    Don't know if they fixed that on the 2022; that's how it works on the 2021.
  8. Salamander_King
    Salamander_King Senior Member
    11,010
    8,940
    New England
    Thank you for the pictorial explanation of different models. I have owned all three iterations of the door handle switches on my 2017PP Premium, 2020 PP LE, and 2021 PP Ltd. But to be honest, I have not noticed any difference in those three models on the switchboard illumination until I read about it on PC. Nor have I ever been inconvenienced by the lack of illumination in the latest model. Admittedly, I rarely drive at night, but even when I do drive when the switches are illuminated, I can't think of any time, I actually had to look down to operate any of those switches.
    BTW, did you know the switches are all interchangeable, but retrofitting older models illuminated switched onto the newer models will cost you $$$.
    Read this thread: Question about 2021 Prius Prime Door Lock Switch | PriusChat
    in summery:
    • MSRP: $346.28 for parts#84040-47070, through December 2018;
    • MSRP: $542.35 for parts#84040-47090, from December 2018 through July 2020;
    • MSRP: $238.94 for parts#84040-48210, from July 2020.
  9. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    Thanks everyone for all the info.
    I just wanted to be sure it was not an issue that I should make a warranty claim for.
    iPhone ?
  10. Mendel Leisk
    40,987
    We were picking someone up with our 2010, at night: outside doors were locked, and I can recall looking down at driver's door arm rest: there was one speck of light, impossible to even tell what button it was. Toyota fail.
  11. Marine Ray
    1,139
    947
    Sparks, NV
    I have not done any switches to the switches:) Here's some info from an owner that did.
    Salamander_King likes this.
  12. Salamander_King
    11,010
    8,940
    New England
    You have no reason to switch to newer switches. Your PP is a 2017 model. Out of the three switches, you showed photos, I think the 2017 model one is the most informative and functional. I could not open the link you posted. I don't have a facebook account.
    Marine Ray likes this.
  13. Tideland Prius
    16,504
    I have a 2018 Prime and it looks like the 2017. Just FYI.
    But for 2018, Toyota removed the silver trim around the power driver’s seat switches.
  14. Marine Ray
    1,139
    947
    Sparks, NV
    Thx.
  15. Salamander_King
    11,010
    8,940
    New England
    The parts for the 2017 model, parts#84040-47070 were used through December 2018. Maybe it was mid-model-year change for the 2018 model, or maybe the 2018 model production was finished on Dec. 2018 using the same panel as the 2017 model. And the 2019 and the 2020 models were using parts#84040-47090 from December 2018 through July 2020.
    Again, I must have had all three iterations of the switches on my 2017, 2020, and current 2021, but I honestly can not say that I remember any difference.
    Tideland Prius likes this.
  16. Marine Ray
    1,139
    947
    Sparks, NV
    Good info to know. So like the oil filter - some early 2017s had canister, then they all had spin on. Thx.
  17. Tideland Prius
    16,504
    Possibly. My car is an October build though.
  18. Salamander_King
    11,010
    8,940
    New England
    That is within the 2018 December cut-off for the parts#84040-47070 used for the 2017 model meaning it must have been used for at least some of the 2018 models. The question is are there any 2018 model PP built after Jan 2019? If not, then both 2017 and 2018 share the same switch panel.
    #18 Salamander_King, Dec 18, 2021
  19. Marine Ray
    1,139
    947
    Sparks, NV
    Due to all your input, changed my pic.
  20. Mendel Leisk
    40,987
    Too bad "Team Toyota" or whatever their name was, have departed this forum; would be interesting to hear their take on this "progression".
    Again, my 2010 is even worse: IIRC there's ONE effing pinpoint of light, completely unidentifiable in a dark car.
