Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v
Discussion in 'Prius v Accessories and Modifications' started by Tideland Prius, Sep 28, 2018.
  1. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    drove around for 50 miles yesterday with tech stream running. Fans kick on 203 and goes to 205-208 for few seconds then drops back to 199 F
    both codes are gone. P3190 and P148F
    I swapped the new throttle body that came with the new engine to old one then bleed the coolant system by pressing the radiator hose by thermostat and loosening the temp sensor up to to let air out.
    RightOnTime likes this.
  2. ChapmanF
    18,449
    I think if the ECM wants the pump to do 3650 RPM and the pump is doing zero RPM, it doesn't even matter whether the impeller has separated. :)
  3. EH6TunerDaniel
    55
    29
    I think burping it fixed your issue. I used the gen 4 throttle body on both swaps I did because lower miles.
  4. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    yes that is what i am thinking too. I think the main problem with raised tank was there was extra coolant that block the return hose on the tank
    also was getting p3190 which led me to believe i might have a faulty throttle body. So i cleaned my old one and installed it.
    Do you think swapping it back to the one that came with new engine introduce air in system?
  5. Mendel Leisk
    41,820
    Quite possibly.
    Apatel1101 likes this.
  6. EH6TunerDaniel
    55
    29
    Probably because of the Toyota version of the fit valve whatever they call it.
  7. Prius_10_inside
    Prius_10_inside Junior Member
    LA
    in the books… Drove to California the day after finish install at Mark’s shop in Beltsville, MD. No issues. 160,000 car with 35,000 engine.
    Thanks for the few tips at Prius Chat, you know who you are… (thumbs up)
    Mendel Leisk and Air_Boss like this.
  8. Air_Boss
    Air_Boss Senior Member
    4,218
    1,188
    New Yawk
    Someone should produce a summary, parts requirements, and a series of work cards for this mod, which sounds like the way to go when an engine replacement is needed. Thanks for the play-by-play.
    RightOnTime and Mendel Leisk like this.
  9. EH6TunerDaniel
    55
    29
    Its pretty much already here on the forums. The engines are externally the same just swap it in and use the gen 3 intake and exhaust and extend 1 sensor for easiest plug and play.
  10. Mendel Leisk
    41,820
    Just watching the videos over and over helps. I'd say for anyone thinking to take on a summary, a marathon viewing session would be mandatory; there's lots of little details. I get a kick out his "asides" too; lots of funny insights.
  11. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    P148F is back. I am lost at what to check other than bleeding the system in maintenance mode and cracking open the temp sensor.
    my last option is to drain the coolant and cutting the jiggle pin off on thermostat
  12. ChapmanF
    18,449
    As I understand it from this post, that code was added for the 2011 model year. At the moment, my TIS subscription isn't paid up, and the only downloaded repair manual bits I have are from 2010, so I haven't got the details of that code.
    However, I don't believe it is triggered by any of the things you're talking about checking for it. So I think you'll probably get further faster by looking up what does trigger it (its "detection condition") in a repair manual of the proper vintage, and following the troubleshooting steps found there.
  13. DinoBravo
    DinoBravo Junior Member
    Grand Rapids, MI
    Where can I find your gen4/gen3 swap write up?
    just did the head gasket and water pump on my 2012 V with 206k on it and less then 500miles later it developed a slight oil leak:(
  14. farmecologist
    farmecologist Senior Member
    1,959
    1,799
    Southern MN
    We have a 2012 Prius v wagon with 178K on it now...and like clockwork it has developed a head gasket leak.
    Here is what I did...I don't recommend it to everyone and I'm trying it as an experiment and am updating the thread below every now and then. So far it is holding up well...but it is not a long term solution by any means.
    Hi all, new Prius v owner | Page 12 | PriusChat
    The funny thing is...I was planning on getting rid of the car this year sometime....but that planning was done back when vehicle prices were reasonable. Now I'm rethinking things...hopefully the vehicle market will loosen up in a reasonable amount of time.
  15. Mendel Leisk
    41,820
    Most on-topic:
    Engine swap question | PriusChat
    Stop Leak Will Come Back To Bite You | PriusChat
    25k mile update since my Gen 4 short block | PriusChat
    Said Goodbye to My Prius | PriusChat
    And this page lists all the threads he's started, where I'm finding the above (I might have missed some):
    https://priuschat.com/search/308976366/
    To find his page (seems difficult on PriusChat), I just searched with google, for:
    cnc97 priuschat
    First hit was his personal page, and there you can find a link to all his postings, and on that page you can narrow it down to threads he's started (last link above).
    SFO likes this.
  16. Tombukt2
    13,270
    2,396
    It'll buy you some time just buy you a JDM spec engine gen4 or 3 whatever your poison. You'll get 150K plus out of that so you know that that's a decent that shouldn't cost you much it should be able to get out of that for around 18 19 if you good.
  17. DinoBravo
    Grand Rapids, MI
    **don't give that too aggressive of whack with the impact screwdriver ~ I broke the corner off of mine
  18. ChapmanF
    18,449
    Yeah, doesn't take much. The screws are really not outrageously stubborn, just need to be surprised a tiny bit, then they spin right out. Light taps on a hand impact driver, or something like a Lisle or Thexton seized-fastener removal tool with a very light feathery touch on the air hammer trigger.
    DinoBravo likes this.
  19. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    I’m still around too. I look in from time to time. Out of all the forums (car related and otherwise), this page has been the most entertaining and educational of all of them. Lots of great reading here. Don’t be afraid to ask direct questions. It’s been four years, but I’ll help any way that I can.
    DinoBravo, Mendel Leisk and SFO like this.
  20. DinoBravo
    Grand Rapids, MI
    OK ~ I'm looking for a head check, verification/validation that I grasp the basic yet crucial details of the Gen 4 swap.?,?
    Gen 4 engine (A/B)
    Gen 4 plugs & coil packs
    Gen 4 water pump
    Gen 4 t-stat ~ jiggle pin up/12 o'clock ~ don't lose that coolant flow restrictor
    Gen 3 intake manifold
    Gen 3 wiring harness
    Gen 3 exhaust
    Gen 3 EGR system
    Gen 3 flywheel and damper
    Gen 3 dipstick
    Gen 3 engine mount
    Gen 3 or Gen 4 oil filter housing
    8x1inch galvanized pipe
    Pex 3 way splitter
    EGR sensor extension ~ either purchase one or splice while engine is out
    Grind off nub by EGR cooler while engine is out
    2 ground wires relocated
    Gen 4 also has an oil level sensor that will not get plugged in ????
    Flywheel Bolts: Use Red loctite, 36ft.lbs. + 90 degrees (14mm 12 point socket)
    Damper Bolts: 22ft.lbs.
    Motor Mount Bolts: 45ft.lbs.
    Engine to Transmission Bolts: 24ft.lbs.
    Make sure that the dowel/alignment pins for the engine and transmission aren't doubled up
    Importance of air bleeding of coolant system
    @Ragingfit ~ coolant plumbing diagram
    review @Ragingfit swap series again on you tube
    #1080 DinoBravo, Jul 22, 2022
    Ragingfit, SFO and Mendel Leisk like this.
