Intake Valve Location/questions - 2011
Discussion in 'Gen 3 Prius Technical Discussion' started by An2TheTwan, Aug 11, 2022.
  1. An2TheTwan
    An2TheTwan Junior Member
    97
    New York
    Where are the intake valves located in the generation 3 Prius? If these are carbon fouled/stuck/need cleaning, could that cause engine shaking? I believe I have a blown head gasket but not 100% sure because I am not getting the normal symptoms (loosing coolant/milky oil etc..)
    see my other thread for more details:
    Considering Head gasket replacement - 2011 Prius - 215k miles - P0303 misfire | PriusChat
  2. Tombukt2
    13,757
    2,491
    Like my 2013 you may be running on three cylinders That's what happened to my 2013 and it didn't run long like that either I I stopped very quickly once it started making that racket The reciprocating mass turned and didn't hit a lot but just a little corner of the break and the rod kept smacking against the lower portion just below the girdle in the open deck assembly and when I pull the engine out I saw the break in that piece and of course I took pictures of it but that was that so there was no doing a head gasket I didn't think after the kid put the head gasket on and shouldn't have but that's another pile of mess..
  3. An2TheTwan
    97
    New York
    @Tombukt2 - sorry this happened to your 2013 but trying to stay on topic here. I feel a head gasket kit is cheap enough to try and save my 2011.
    Trying to be diligent and do anything/everything that is cheap that has a small chance at fixing the problem. A lot of the things I have been trying are general maintenance that should be done anyway.
    Are the intake valves in the intake ports?
  4. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    If the light is right or you use a flash light you can see them through the intake ports /
    So yes, they are just behind the ports /
    An2TheTwan likes this.
  5. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Here's a picture that shows where the valves are. You can see the valve stems at the back of the intake:
  6. An2TheTwan
    97
    New York
    Thanks everybody!
