2015 Prius v Electrical Problem
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Carl Mims, Dec 11, 2022.
  1. Carl Mims
    Carl Mims Junior Member
    Bozeman, MT
    2015 Prius v wagon
    I have a 2015 V all the dash lights are on, but no error codes, according to Dr Prius Special Features page. The hybrid battery was at 69% 2 months ago and shows 2/3 full on dash. Dr Prius shows all the cells as green. But again with not start and all dash lights on. The 12v battery is 1 year old Duracell. It was reading 6.78v, took it to Batteries plus and they said it was 11v., kept it 24 hours and charged it. Came back up to 13.3v and cranking amps was down less than 10 amps from spec. Said it was very good. So put back in the car and the same thing. Read 13+ at both the battery and at the Charge port in the fuse box.
    Does reading at the charge port mean the 125a fuse is good? I can't find it (see photo). What do I try next? A tow will be about 50 miles to the Dealer, only option I have. BTW it has been outside in - temps, was working fine, sat for the night, and would not start.
    Can someone point me to 125a Fuse, Could it be one of the fuses under the dash or someplae else.
    #1 Carl Mims, Dec 11, 2022
  2. Carl Mims
    Bozeman, MT
    2015 Prius v wagon
    BTW what is under that square box at 45 degree angle lower left of the pic.? Think that is a really box that has Toyota sticker on it
  3. bisco
    52,396
    you might do better in the v forum, and you probably need a better code reader
  4. Carl Mims
    Bozeman, MT
    2015 Prius v wagon
    Recommendations for code program on an iPhone.. have VeePak le Bluetooth
  5. bisco
    52,396
    no idea, there are lots of threads here. tech stream is the gold standard, after that some are better than others
