12V Battery Cable help ASAP
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priuspubescent, Nov 16, 2020.
  1. Likeawind
    Likeawind Member
    109
    Houston
    are they not balanced? so do I need to attach the computer only?
  2. rjparker
    10,348
    6,475
    They are new. No balancing bs needed.
  3. Likeawind
    Likeawind Member
    109
    Houston
    Is there a diy for attaching the ECU?
  4. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
    #84 alftoy, Mar 7, 2023
    SFO likes this.
  5. Likeawind
    Likeawind Member
    109
    Houston
    Thank you! this is very helpful as there no videos available for ECU swap, I have decided to buy a brand new battery from the Toyota dealership for $1635 plus tax and install it myself. Apart from the things you mentioned above, do I need to take any other precautions?
    BTW I'm from Calgary and have recently moved to Houston.
  6. alftoy
    1,132
    518
    Take pictures of old hybrid battery, both sides. Only puzzle might be the 3 orange cable routing if you forget to take a pic.
    #86 alftoy, Mar 7, 2023
    Brian1954 likes this.
  7. Likeawind
    Likeawind Member
    109
    Houston
    Yeah I was wondering about that, thanks for the heads up!
  8. Likeawind
    Likeawind Member
    109
    Houston
    If there is corrosion on the Ecu connector then what? Does it need to be replaced?
  9. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    If cleaning the corrosion (or replacing the harness) fails to relieve the stored OBD2 code(s), then a replacement would be the next option.
  10. Likeawind
    Likeawind Member
    109
    Houston
    How can I clean it up?
  11. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
  12. Likeawind
    Likeawind Member
    109
    Houston
    I absolutely wanna make sure it’s the HV battery before I buy a new one. I replaced couple of cells last time which were 6.2volt with 7.2volt, is that low as well? All other cells were above 8volts. Red triangle showed up again after 5 miles.
  13. jdenenberg
    jdenenberg EE Professor
    3,946
    1,942
    Trumbull, CT
    2020 Prius
    LE AWD-e
    When replacing cells, you need to charge the "new" cells to the same voltage as the other cells in your battery or the ECU will flag an unbalanced battery.
    JeffD
  14. dolj
    dolj Senior Member
    8,490
    4,308
    Wellington, New Zealand
    ... and the "new" modules need to be of the same general capacity as the existing old modules.
  15. Likeawind
    Likeawind Member
    109
    Houston
    How do I charge them?
  16. Likeawind
    Likeawind Member
    109
    Houston
    You mean above 8volts in my case?
  17. jdenenberg
    3,946
    1,942
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You use a hobby battery charger - about $40
    JeffD
  18. Likeawind
    Likeawind Member
    109
    Houston
    Thanks, after I charge them do I need to discharge them? Do I have to do this cycle few times? Also how would I discharge them? Is through the same equipment?
  19. rjparker
    10,348
    6,475
    And at the end of the day a bunch of diy leaves you with an unreliable battery and no warranty.
