P3190 Code & Death After Oil Change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Too Many Prii, Apr 15, 2023.
  1. Too Many Prii
    Too Many Prii Junior Member
    25
    The Lone Star State
    OK, I know there are a lot of threads regarding P3190. At the risk of overlapping similar previous posts, here's my story:
    I took my wife's 2008 Prius (~150,000 mi) in for an oil change. It's had no reliability issues since I replaced the brake actuator 2 years ago. The oil change guys (independent shop, but "quick-lube" vibes) did nothing more, as far as I know, than drain the oil, replace the filter, and open the air cleaner housing to check the air filter. They removed the filter to show me some tree debris that it had caught, but knowing it's a young filter I told them not to worry about it and put the filter back in.
    Upon leaving the lube place, after literally 1/2 block I notice I'm on battery with the triangle of death, VSC and ABS lights illuminated. I made it to the next light and pulled into a side street before the car came to a stop. I checked the oil level (fine), connection to the oil pressure sender, and all other visible connections. that could have been disturbed, but found no issues. After a few Hail Mary attempts to restart I had it towed home. (Thanks, USAA!)
    One factor I considered is that critters have been under the hood and left acorn shells and droppings around the air cleaner cover, so possibly something dropped in when the oil guy opened it up. Indeed I found one rat/mouse turd on the butterfly valve and fished that out. But I did not find any issues with the MFC.
    So, I know correlation is not necessarily causation, but it seems likely something happened during the oil change. I've checked and double checked all the connections I can see, and found nothing amiss. I plan to take off the MFC tomorrow and clean it as described in other threads, but am not hopeful. I don't want to make recovery more difficult by running the traction battery even lower with restart attempts.
    So I throw myself at the mercy of the court: what else should I look for or do before I tow it to the dealer?
  2. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    If cleaning up the MAF sensor, and briefly brushing the throttle body/butterfly valve with a toothbrush and alcohol, then disconnect the 12v to reset the fuel trims. After reconnecting the 12v, it will take two (2) attempts to 'ready' the vehicle. What is MFC again?
  3. Mendel Leisk
    41,778
    Ask the oil change place what else they might have done. Let them know the current state of your car too.
    MAF sensor disconnected? Air filter housing lid incorrectly replaced? Air conduit not pushed back on properly or clamp left loose? PCV hose disconnected?
    did you ask for just an oil change, or agree to a “look over” as well? Not that that would stop them…
    Did you see this thread:
    Stranded in sulphur LA with a P3190 after oil change | PriusChat
    and yeah: what is MFC?
    #3 Mendel Leisk, Apr 16, 2023
  4. Too Many Prii
    25
    The Lone Star State
    Eh sorry, my engineering roots poking through. MFC is "mass flow controller". I meant MAF sensor, of course.
  5. Too Many Prii
    25
    The Lone Star State
    Sorry, I meant MAF sensor and MFC (Mass Flow Controller, used in semiconductor process tools) came out. :confused:
    When my wife picked me up we went back to the lube shop, and the owner was kind enough to drive to the Prius and look it over, and did not find any issues. I did not ask them to check the air filter, but I know they check fluids and give the engine a look-over. It is the first time they've tried to sell me a new air filter, but they seem like pretty decent folks so I don't mind. The car was within my sight the whole time, and while I couldn't see everything they were doing I didn't see anything concerning. I strongly expect some inadvertent "adjustment" was made to account for the problem, but it's not visible yet.
    Thanks for the link to the P3190 thread. I know there are a bunch, and I see that thread links to another good one. There are few decent YouTube vids also. Other than ensuring the MAF sensor is clean and properly connected, and the possibility of air leaks, I haven't seen much else to check. I will take off the MAF sensor today to inspect and clean, and ensure proper electrical connection. I'll also double check teh PCV hose as you suggest.
  6. ChapmanF
    18,412
    The thing is, the P3190 code tells you only that the engine is producing a small fraction of the torque being asked of it.
    That's a symptom description, not a diagnosis. The human just has to check all the things a human would have checked in the olden days when an engine was running poorly and producing a fraction of its output.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Debris in the oil filter and you tell them to put it back on? There should be no debris in your oil filter. An oil filter is cheap come on....
    You may have really bad mice damage. The AC cabin filter behind the glove box and the engine air cleaner are now a Days Inn for mice. And when there in that free hotel they like to snack and they have probably chewed on many a wire in your car.
    Your car lives outside.
    Also take the back hatch out and look in the spare tire area there's alot of mice infiltration there too.
    This is a very common issue with a G2 Prius and they can do an amazing amount of damage. They can total a G2. This is a very common issue on this site. The wires in a G2 are soy based and mice find them delicious.
    Btw, the oil joints use an Alldata car info bible for oil capacity and the G2 info in that book is wrong. It states 5 quarts for a G2 when the car takes 4 so if you throw them the keys and say oil change you get 5 quarts of the worst vat oil ever. So I would bet your engine is very over filled by 1 quart of oil maybe more. That may cause the warning lights you see.
    Here's a link to the Search Forums on this site about mice damage. Lost and lots of reading:
    https://priuschat.com/search/413853164/?q=mice+damage&t=post&o=relevance
  8. Too Many Prii
    25
    The Lone Star State
    Sorry if I wasn't clear--the debris was in the engine air filter. Just a coupled oak tree pollen dispersers, whatever they're called. In my view that's just the filter doing its job.
    edthefox5 likes this.
  9. Too Many Prii
    25
    The Lone Star State
    Yes, so I've learned. I'll reply more fully below.
  10. Too Many Prii
    25
    The Lone Star State
    OK, problem solved! My theory about critter debris turned out to be the right answer. I pulled the MAF sensor and peered into the barrel to find some organic debris (leaf fragment? shell husk? See pic.) draped over the hot wire and the thermistor. I sprayed it out with MAF sensor cleaner and reinstalled, and voila, engine starts normally. I cleared the codes with my code reader and took it for a drive to charge up the traction battery. I was a bit worried about having run the battery dry, but after charging it seems to be behaving normally. I put the car back into service and told my wife not to worry about it. :cautious:
    I do wonder if Toyota might be able to provide a more specific code for MAF sensor issues, The P3190 code is so non-specific as to be hardly useful. Clearly the computer knew something with the MAF sensor was amiss, as it would not even start the engine. More specific guidance seems possible, and would save a lot of guesswork. Admittedly, in 15 years they may have improved on this. (y)
    Thanks to all for replies and advice!
  11. ChapmanF
    18,412
    It didn't though; that's the thing. There it was, happily running its engine, basing the fuel injection on the MAF reading as it is programmed to do, and suddenly what it was programmed to do, which was working great a moment before, now only produces sucky under-20% power. It doesn't know why. Even if it noticed an abrupt drop in the MAF reading, it has no independent way to know whether the sensor just did that, or a sock just got sucked into the intake and the lower MAF reading is correct. Or the problem could be something else entirely. So it says "hey boss, the engine won't make much power, I'll need your help to figure it out."
    There are MAF-sensor-specific codes it can set if the signal from the sensor is recognizably bogus. In that case, you'll get one of those codes. I don't think those codes even do prevent it from starting the engine, by the way; it just says "I know I can't trust the sensor, so I'll just guess on the fuel injection based on throttle position and RPM" and the engine can usually run sort of OK that way.
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Your finding is the first thing that came to my mind when you described your maintenance visit. One thing you can do is follow up with the maintenance shop and explain to them what you found. They need to know so they're a bit more careful when removing and installing air filters. Your experience is not the first for this exact 3190 scenario.
    Too Many Prii and jerrymildred like this.
  13. Mendel Leisk
    41,778
    1/4” steel mesh (rodent/bird mesh) over the engine air intake. (y)
    Attached is our 3rd gen, but sim I think could be done:
  14. ChapmanF
    18,412
    TMR might have the simpler, critterless story: somebody checked the air filter, and let a little bit of something drop from the dirty to the clean side.
  15. Too Many Prii
    25
    The Lone Star State
    I completely agree. They seem like honorable folks, and I will let them know what happened.
  16. Too Many Prii
    25
    The Lone Star State
    Yup, precisely what happened. They should have blown out the crud before opening the filter housing.
  17. ChapmanF
    18,412
    Sometimes I forget and picture the way Gen 3's air box is arranged, where the dirty side is below and the clean side is above, making it harder for a little bit of something to 'drop' in. But then I remember, the Gen 1 and 2 air box was not that way.
  18. dolj
    dolj Senior Member
    8,495
    4,313
    Wellington, New Zealand
    I'm pretty sure it is that way on a Gen 2 as well as I just did the engine air filter inspection on my Gen 2 yesterday. Unless I'm not understanding precisely what you're meaning.
  19. Mendel Leisk
    41,778
    looks like air enters from underside of air filter, flows up.
  20. ChapmanF
    18,412
    But then it reverses at the cover and goes back down through the air box, which sits right over the throttle body.
    So if there's debris on the underside of the filter and you take the filter out and the debris drops into the box, it can end up in the engine or the MAF sensor.
    Contrast the Gen 3 air box, where the duct from the box to the throttle body comes from the lid.
    For your debris dislodged from the air filter to fall into that duct, it would have to fall up. (It would also have to get through the non-replaceable carbon filter that lives in the lid. :))
